Happy Camper Double
Submitted: Tuesday, Sep 07, 2010 at 15:55
Member - Julie & John (VIC)
Gday...
Are you actually using one of these??
We are thinking of installing one of these filters to the van. There is a bracket that attaches to the outside of the van to which the Happy Camper Filter attaches.
What areas have/do you travel in and how effective are they?
Do you think they have been worth the outlay? For double filter + 2 cartridges + bracket + handle for changing filters it comes to around $350.
Image Could Not Be Found
Julie & John
Reply By: Member - res.q.guy (Vic.) - Tuesday, Sep 07, 2010 at 16:43
Hi julie & John
I made up my own filter, only a single filter with a Carbon ( or charcoal ), and only used it when the
water looked a little suspect.
You can buy a basic single filter fith a carbon filter on ebay for about $70.
Water Filter
Neil
429607
Reply By: Member - Toyocrusa (NSW) - Tuesday, Sep 07, 2010 at 20:01
Hi J&J. I bought a very similar looking twin filter system from BigW for $95.00. It came with the filter cartridges and tube fitting kit. Downside is the replacement filter cartridges are around $55.00 for the pair. Regards,Bob
429624
Follow Up By: Member - Toyocrusa (NSW) - Wednesday, Sep 08, 2010 at 06:58
Also found
this on the trading post website which may be of interest to you. regards,Bob
700412
Reply By: racinrob - Tuesday, Sep 07, 2010 at 20:43
I've never had or used a
water filter in many years of working and touring in the outback and haven't ever had any problems. Sure sometimes the taste is not great but I don't think a filter would make any difference. I always boil it and never drink it if the source is suspect. JMHO.
Rob.
429627
Reply By: Mick O - Wednesday, Sep 08, 2010 at 12:28
I’ve been using a similar system for a few years for outback
water purification. It’s worked a treat. The canisters are only about 2/3 the height of yours though and it was only about $120 including a pre-filter and a .05 micron filter, (good for several thousand litres). As most of my
water is taken out of any source I can beat the camels too, it’s necessary. I’d ask the question is it necessary for you to spend the $400 given that most
water you’ll be exposed to in everyday carravanning would be fit for human consumption (obviously different if you're spending a lot of time in remote areas). $400 buys a lot of 20 litre containers if you need a bit of extra
water for an isolated stay! The other thing is pressure. I’d imagine it will rely mainly on mains pressure when connected at parks etc. I’ve found that the flow rate will be very slow if relying on a DC pump like a flojet or sureflo.
Cheers Mick
429653
Reply By: Member - Heather G (NSW) - Wednesday, Sep 08, 2010 at 13:30
Hi Julie, check out this site.
http://www.bestwaterfilters.com.au/store/category2_1.htm
We use the white one which connects to our hose so can fill the tanks with filtered
water or just connect to mains pressure when in van parks. Approximately $110.00
We find them great, convenient to order online as
well. They are good for 5000 litres or so and then need to be replaced.
Heather
429659
