Extension lead
Submitted: Thursday, Sep 09, 2010 at 12:52
ThreadID: 81220 Views:7777 Replies:11 FollowUps:46
Related Pages
Hvae just read a few old posts about 10 amp and 15 amp leads. To overcome the problem of whether a park may have 15 amp or 10amp outlets, i see BCF carry 15 amp leads with 10 amp plugs. Is this safe for a camper trailer (and or the park)?
Reply By: equinox - Thursday, Sep 09, 2010 at 13:08
Perfectly safe, however I cannot understand why having a 15 amp lead with 10 amps plugs will overcome the problem of whether a park may have 15amp or 10 amp outlets.
AnswerID: 429746
Follow Up By: Findanomad - Thursday, Sep 09, 2010 at 13:13
i'm not sure but i believe a 10 amp plug will fit a 15amp socket but not the other way around?
FollowupID: 700528
Follow Up By: equinox - Thursday, Sep 09, 2010 at 13:18
that's correct, however if you have a van or similar with a 15A plug (flush) you still wont be able to plug a 10amp socket into it.
FollowupID: 700530
Follow Up By: Member No 1- Thursday, Sep 09, 2010 at 14:47
This post has been read by the moderation team and has been moderated due to a breach of The Inappropriate Rule .
Forum Moderation Team
FollowupID: 700537
Follow Up By: Member No 1- Friday, Sep 10, 2010 at 08:06
This post has been read by the moderation team and has been moderated due to a breach of The Moderation Complaints Rule .
FollowupID: 700621
Reply By: Notso - Thursday, Sep 09, 2010 at 13:12
There is an australian standard that sets the standard for this type of lead.
Check it yourself, but I think the legalities of it require that the lead must have a circuit breaker in it that limits the current draw to 10 amps.
AnswerID: 429748
Follow Up By: Findanomad - Thursday, Sep 09, 2010 at 13:17
That makes sense, so a 15 amp lead with 15 amp plugs and an adaptor to 10 amp socket would suffice all situatiions. (I think)
FollowupID: 700529
Follow Up By: Notso - Thursday, Sep 09, 2010 at 13:20
Hi again,
Not too sure but I think I read that the Circuit breaker must be Hard Wired?
FollowupID: 700531
Follow Up By: Member - Graham H (QLD) - Thursday, Sep 09, 2010 at 15:03
No it wont an adapter with a 15amp on one end and a 10 amp on the other
IS DEFINITELY ILLEGAL to use in any situation.
Even if you have your van at home and plug it in to a house outlet.
Definitely End of Story.
The anfibian is the only legal solution.
FollowupID: 700539
Follow Up By: Notso - Thursday, Sep 09, 2010 at 15:16
I would say that any competent electrician could make a device that would comply with the Aust Standard.
FollowupID: 700541
Follow Up By: Member - Graham H (QLD) - Thursday, Sep 09, 2010 at 15:21
They probaly can but untill it has passed and been approved by the relevant authority its still illegal
The device mentioned is fully approved and so can be used.
FollowupID: 700543
Follow Up By: Notso - Thursday, Sep 09, 2010 at 15:25
From Caravan and Camping Sales Tech Talk
"It is still not permitted to fit a 10A plug and a 15A socket onto cable of any size because there can be no certainty that it will not be used to carry 15A.
The new rules also provide for retaining the 15A inlet and 15A supply capability, but to use a 10A plug and special cable (that has a built-in 10A circuit breaker, thus providing its own protection) where only 10A supply outlets are available.
Standards Australia advises that such a device might be constructed from proprietary components by a licensed electrician “who will ensure that the rating of the components and the enclosure are appropriate for the circumstances in which it will be used and comply with electrical principles… [the electrician] will also decide if consultation with the State electrical safety authority is appropriate” (#8). "
FollowupID: 700544
Follow Up By: Shaker - Thursday, Sep 09, 2010 at 16:39
BCF couldn't sell them if they hadn't been passed, they would be wide open to litigation!
FollowupID: 700562
Follow Up By: Notso - Thursday, Sep 09, 2010 at 16:44
Nobody is suggesting that the Amp Phibian is illegal, all I am saying is that any competent electrician could also make one.
FollowupID: 700563
Follow Up By: Member - Graham H (QLD) - Thursday, Sep 09, 2010 at 17:08
What BCF is selling is more accurately described as a heavy duty 10 amp lead for use on building sites.
I have one bought at Home Hardware in Port Augusta
IT DOES NOT PLUG ONTO CARAVAN
FollowupID: 700566
Follow Up By: oldtrack123 - Friday, Sep 10, 2010 at 20:17
i
FollowupID: 700529 Submitted: Thursday, Sep 09, 2010 at 13:17
Findanomad posted:
That makes sense, so a 15 amp lead with 15 amp plugs and an adaptor to 10 amp socket would suffice all situatiions. (I think)"
NO ,It will not fix the the problem legally.
The AS/NZS 3001 standards clause 5:1:1 says "The supply lead shall be in one length"
An adapter is a joint ,you would have a TWO piece lead [not approved']
An extension lead [this includes an adapter} SHALL have the same rated plug & socket [AS/NZS31299]
The ONLY way you can have a different rated plug & socket is with an approved lead fitted with complying ,olcb .enclosure ,ETC
The Amphibian lead is approved & meets the requirements
FollowupID: 700730
Reply By: Member - Andrew (QLD) - Thursday, Sep 09, 2010 at 13:36
A "15 amp lead with 10 amp plugs" will NOT plug into a fixed 15A (caravan/camper trailer) socket.
Andrew
AnswerID: 429752
Reply By: Just some guy - Thursday, Sep 09, 2010 at 14:05
Gidday Findanomad,
I think saying a 15 amp lead with 10 amp plugs is just a complicated way of saying its a heavy duty lead. The leads I have in the shed are exactly this but they are just called heavy duty leads in the local tool shop.
If you want to plug a 15amp device (like a camper trailer) into a 10 amp power point, you firstly have to know its not going to draw more than 10 amps, and secondly use something legal to change the plug size - i have read about the Amp Fibian on various forums - this is their website: amp fibian website
I don't know if there are other versions around - this is the only one I have heard of and they claim on the website that its legal and safe - it has a built in circuit breaker and a decent length lead on it...
Cheers!
AnswerID: 429755
Follow Up By: equinox - Thursday, Sep 09, 2010 at 14:38
Just Some Guy,
Have you any affiliation with this company?
FollowupID: 700535
Follow Up By: Member - Graham H (QLD) - Thursday, Sep 09, 2010 at 15:04
What if he does what he says is true.
FollowupID: 700540
Follow Up By: Just some guy - Thursday, Sep 09, 2010 at 15:42
Hi equinox,
I no affiliation with them. I probably should have mentioned that!
I don't have one, have never seen one but when I get a caravan (hopefully soon) I intend on getting one!
FollowupID: 700549
Follow Up By: equinox - Thursday, Sep 09, 2010 at 15:57
no problem - it certainly sounded like it thats all. It gets up my nose when salespeople try to pretend their someone they're not.
Graham - you know it would go against forum rules so why do you even ask
FollowupID: 700551
Follow Up By: ModSquad - Thursday, Sep 09, 2010 at 16:11
Ok now boys, lets take a breath and relax. Yes it would be against the rules and could lead to a post being moderated but all looks good here so lets enjoy the excellent info that's being shared.
Regards,
The Moderation Team.
Moderation is just rules
FollowupID: 700556
Follow Up By: Member - Paul F (INT) - Thursday, Sep 09, 2010 at 18:55
Hello all.
Am wondering after reading posts how does a person get to use a single phase "brand irrelevant" welding machine which requires a 15amp supply, keeping in mind that our normal power points supplied are 10 amp in 99% of places I have seen.
Bearing in mind that to ensure your "warranty" is covered the plug must remain 15 amp, and not be filed or fooled with as it is illegal
So where does that leave the poor bloke that want's to do a bit of handyman stuff at home? let alone a caravan park workshop for repairs if needed.
Am thinking that maybe common sense would prevail in this circumstance
I must point out that although there are machines out there that are rated and supplied with a 10 amp plug they are only good to tack tin plate ( maybe)
Paul
FollowupID: 700575
Follow Up By: Member - Graham H (QLD) - Thursday, Sep 09, 2010 at 21:08
Get a sparky to fit a dedicated 15amp plug wherever you want it in your house then.
FollowupID: 700589
Follow Up By: Motherhen - Thursday, Sep 09, 2010 at 23:29
Getting a 15 amp outlet fitted at your house would be cheaper than buying an Amphibian. Buying one just to take with your caravan or camper is probably just taking another piece of stuff that will take up space and weight you'll probably never need. I am not knocking the Amphibian as such, which tradies may find a necessary piece of equipment when working at different houses and building sites.
Mh
FollowupID: 700603
Follow Up By: oldtrack123 - Friday, Sep 10, 2010 at 21:54
Member - Paul F (INT) posted:
Hello all.
Am thinking that maybe common sense would prevail in this circumstance "
Hi Paul
Probably you , like many others, are not aware that those welders draw up to 30amps & have to have a 15amp plug to be approved for sale.
The smaller one with 10 amp plugs draw up to 18amps.
The rules are not silly as may seem .
They take into account a diversity factor which is time actually welding over total time in a 10minute period
This "OFF" time while deslagging, fitting another electrode, etc allows the wiring plugs,sockets etc to cool down.
The wiring plugs , sockets can carry higher currents for a short time & by applying a diversity factor ,allowances can be made.
YES the poor bloke should get a 15 amp dedicated outlet installed.
Now what better common sense would you suggest to cope with THOSE sought of current draws than what has been taken into account when drawing up the standards [ diversity factor]
Diversity factor is taken into account in many areas of the standards, or you woud not have more than one or two 10amp outlets on a domestic circuit.
Your mains in would be the size of welding cables except for diversity factor.
THE STANDARDS USE A LOT MORE COMMON SENSE coupled with common sense about safety than many would understand
FollowupID: 700752
Follow Up By: Motherhen - Friday, Sep 10, 2010 at 22:14
When we purchased a welder some years ago (back in the days of fuses which you put a fuse wire into each time they blew; before RCDs). We were in rental accommodation which was tied to the Government job. We called in an electrician to fit a 15 amp circuit. He fitted a 20 amp one to be most suitable for the load. We moved within two years and did the same again at the next houses, with around two yearly moves. The answer back then by some (maybe they are now members here with their files or home made cheater leads LOL), was to replace the fuse wire with a piece of fencing wire when it blew. How simple it is to do something the right way, and how foolish to do it the wrong way.
Mh
FollowupID: 700756
Follow Up By: oldtrack123 - Saturday, Sep 11, 2010 at 14:20
O wise Mother hen
Well done & well put
FollowupID: 700813
Reply By: Dust-Devil - Thursday, Sep 09, 2010 at 14:11
I have been told and verily believe, that revolutionary and innovative dudes like yourself who cruise the caravan parks of Australia - have been known to 'aquire' a patch lead made up of a 10amp plug, 15amp cable & 15amp socket so that they can hook up their rigs to 10amp plug profile supply outlets. (Usually in residential buildings)
I have also actually seen a 15amp caravan lead that had the Earth pin on the plug re-profiled to fit a 10amp profile outlet.
In view of the above it is obvious that where there is a will, there is always a way.
As to the legitimacy of such practises - well there is always more than one on this forum who just can't help themselves in commenting on what others do and don't do, so I'll leave that side of things up to them.
DD
AnswerID: 429756
Reply By: Member -Pinko (NSW) - Thursday, Sep 09, 2010 at 16:41
There is a device called an AMP-FIBIAN.
The 15amp. extension plugs in one end and the AMP-FIBIAN plugs into the house hold outlet.
Having said that, I don't own one but in the highly unlikely circumstance that a fire should occur when your motor home or whatever is plugged into your mates place down at the beach, insurance companies could get very pickey if the filed down variety of extension lead is discovered to have been the cause of the fire.
AnswerID: 429765
Follow Up By: OREJAP - Thursday, Sep 09, 2010 at 17:31
Hi Pinko, I have a heavy duty lead with a 15 amp one end (into van) & a 10amp the other. I plug my house hold extension lead into the 10amp end & use 240 power to power up the van. I do this to keep my smart charger trickle charging my van batteries. Is this unsafe or illegal?
FollowupID: 700568
Follow Up By: Member - John B2 (VIC) - Thursday, Sep 09, 2010 at 17:43
illegal?
FollowupID: 700570
Follow Up By: Cruiser .- Thursday, Sep 09, 2010 at 17:48
OREJAP ,
Both !!!!!
Cruiser
FollowupID: 700571
Reply By: Motherhen - Thursday, Sep 09, 2010 at 17:46
This topic keeps shooting off course to the 15 amp one end and 10 amp the other end leads - not the question that was asked.
QUESTION: As most caravans these days require a 15 amp female fitting, has anyone ever been to a caravan park and found that they could not use a 15 amp lead with 15 amp male fitting?
I have not checked this at all the caravan parks we have visited (not a lot), as we generally take unpowered sites. If caravans built in the last 12 plus years all need 15 amp sockets and leads, i can't imagine caravan parks having only outlets suitable for 10 amp plugs. Unless anyone has found caravan parks like this - where is the problem? Just carry a normal 15 amp lead with 15 amp ends.
For those who want to plug in at home, get an electrician to fit a 15 amp outlet.
AnswerID: 429768
Follow Up By: Old Dave - Thursday, Sep 09, 2010 at 18:19
Hi Motherhen
The only one i have come across was at the Murchison about two years ago.
regards Dave.
FollowupID: 700572
Follow Up By: PradOz - Thursday, Sep 09, 2010 at 21:09
caravan park in Gerroa, NSW
FollowupID: 700590
Follow Up By: Motherhen - Thursday, Sep 09, 2010 at 23:22
Thanks for the replies Dave and PradOz. I wonder what would happen if the average caravanner came in to one of these CPs with his proper 15 amp cord and asked how he could use the powered site he had just paid for? I wonder what would happen if something went horribly wrong when someone used a bodgied 10 - 15 amp cord, and if some blame would go back to the caravan park?
FollowupID: 700602
Follow Up By: time waster - Friday, Sep 10, 2010 at 07:31
Mission Beach council park ony had 10amp outlet on a couple of there sites.
FollowupID: 700619
Follow Up By: Findanomad - Friday, Sep 10, 2010 at 09:28
Thanks Motherhen
This is the answer i needed " Just carry a normal 15 amp lead with 15 amp ends." Thats what i will buy.
Thanks for all the comments Cheers
Ian
FollowupID: 700637
Reply By: Maîneÿ . . .- Thursday, Sep 09, 2010 at 19:21
Findanomad,
You say: "i see BCF carry 15 amp leads with 10 amp plugs"
These cables should be rated at the minimum rating, which is only 10 Amps, even if the cable was 100 Amps, they should only be 10 amp rated, because the plugs are only rated @ 10 Amps, so they are effectively only a 10 amp capacity lead.
However, the plug design may be different?
Maîneÿ . . .
AnswerID: 429775
Follow Up By: Member No 1- Friday, Sep 10, 2010 at 08:12
nothing wrong with having a 15a lead with 10a plugs and yes the package should only be rated at 10a
dont know how they are doing cos the earth pin MUST be bigger to comply with 15a current carrying capacity..as far as I am aware
FollowupID: 700623
Reply By: Member - Chris & Debbie (QLD) - Thursday, Sep 09, 2010 at 19:47
Slightly off subject but I cannot understand the thinking that if you plug a 15amp lead into a 10amp outlet your house is going to catch fire and burn down. Yes I know its highly illegal but why would it catch fire?
I am not an electrician so I will stand corrected if wrong but as I understand it, a 15amp circuit in a house has the same size wiring as a 10amp circuit. The breakers are the same size on both circuits, 16-20 amps, the only difference is that you are only allowed 2 outlets on a 15amp circuit whereas you can have upto 20 outlets on a 10amp circuit. So would someone explain, except being illegal, why it is so dangerous to put a 10amp plug on a 15amp lead.
Chris
AnswerID: 429782
Follow Up By: Member - John B2 (VIC) - Thursday, Sep 09, 2010 at 20:09
You have me being inquisitive here, you say you are not electrician but have quoted you can have 20 outlets on 10 amp circuit but only 2 on a 15 amp circuit.
Can you also explain why it may not catch fire and burn you house down, a lot of house fires do stem from electrical faults.
Just remember electricity, has no smell, no sound, cannot be seen, but if you touch it, it can kill!!!
Had a lot of workmates killed and they were trained linesmen.
What I am trying to say lets not be the ultra male, as you might leave a loving family behind.
FollowupID: 700580
Follow Up By: Member - Chris & Debbie (QLD) - Thursday, Sep 09, 2010 at 20:30
Hi John, I'm a diesel fitter actually and I did say I would stand corrected if anything I mentioned was wrong.
Yes I understand that a lot of house fires are caused by electrical faults, but I was not referring to a fault but a properly made up 15amp lead with a 10amp male plug, plugged into a 10amp outlet.
I do understand the dangers of electricity as I work around it every day, just trying to understand why this is such a dangerous practice that people seem to get so worked up about when we know a lot of people do it.
Chris
FollowupID: 700582
Follow Up By: Member - John B2 (VIC) - Thursday, Sep 09, 2010 at 20:47
Hi Chris,
You can have 15 amps going through a 10 amp plug and the heat build up can create a fire.
Same as when someone has an electrical fault in their vehicle and the 10 amp fuse keeps blowing, so they put a 15 amp fuse in and then they have a fire or or melted wires.
Same scenario a 10 amp plug is rated 10 amps, not 15 amps as the cable is.
FollowupID: 700583
Follow Up By: Member - Chris & Debbie (QLD) - Thursday, Sep 09, 2010 at 20:56
Now we may be getting somewhere John, but what is the difference between a 10amp plug and/or outlet when it looks like its only the size of the earth pin?
FollowupID: 700585
Follow Up By: Bonz (Vic) - Thursday, Sep 09, 2010 at 23:39
You are spot on Chris and Debbie, the earth pin is the only difference on the plug. The lead itself is a larger diameter cable, the plug isnt an issue, and I dont believe a 10A plug is a danger on a 15a lead, but it is illegal. The earth pin doesnt carry any load at all, so it doesnt really matter how big it is
FollowupID: 700604
Follow Up By: Member No 1- Friday, Sep 10, 2010 at 08:15
"The earth pin doesnt carry any load at all, so it doesnt really matter how big it is"
it may in certain Fault conditions
FollowupID: 700625
Follow Up By: Bonz (Vic) - Friday, Sep 10, 2010 at 17:30
yep MN1 you are quite correct and in that case, the fuse would be the weak point of the fault current path, certainly not the earth pin of a extension lead
FollowupID: 700707
Follow Up By: oldtrack123 - Friday, Sep 10, 2010 at 22:26
Chris
Hi Chris
See my post 9 of 9 above
Diversity factor based on what is believed to be the way each circuit may be used
I do not understand why so many with little knowledge, of ALL the factors involved& that have to be taken into account, are so reluctant to accept that those drawing up the standards do know what they are doing.
Just a short list of factors involved:
Equipment likely to be used.
Max demand of that equipment.
Assumed diversity factor for that equipment & circuit
Circuit length ,active & neutral
Possible voltage drop
Circuit loop impedance .This can be affected by joints .plug connections ,etc & is one of the concerns with joining extension leads.
It should also be remembered that the rules have to take into account that: not all homes are wired with 20 amp cable for the power circuits.
Not all homes have circuit breakers , in fact I would say a very large number are still fitted with rewirable fuses & has the home handy man with his welder stopped that fuse from blowing, by putting in the biggest wire he can??
A LOT MORE INVOLVED THAN MOST ARE AWARE OF
FollowupID: 700759
Follow Up By: Member - Chris & Debbie (QLD) - Saturday, Sep 11, 2010 at 09:38
Oldtrack, while I agree with you list of factors surely the ones drawing up the standards do not allow for people doing the wrong thing?
I would assume that if a house was not wired with 20amp cable then It would/should not have a 20amp fuse/circuit breaker fitted.
Do they allow for the handyman that has replaced his fuse wire or breaker with a higher rating who may then go and plug a high current draw appliance into each outlet in his house?
Chris
FollowupID: 700793
Follow Up By: oldtrack123 - Saturday, Sep 11, 2010 at 13:53
Hi Chris
They try to see what may happen & WARN of possible problems such as some of those mentioned on this thread.
All are well aware of the problems with rewirable fuses & people doing the wrong thing
One of the reason olcbs are now mandatory
Unfortunately that does not stop those who have the wedge type fuses holders fitting the wrong size miniature olcb.
RE:"Do they allow for the handyman that has replaced his fuse wire or breaker with a higher rating who may then go and plug a high current draw appliance into each outlet in his house? "
That's where the much spouted theory of common sense falls down & of course there is no practical way available except hard wired olcbs.
The other problem is that the rules are not retrospective.
Changes can only be enforced if an alteration or addition is made & unfortunately some sparks do not follow this rule.
FollowupID: 700809
Reply By: Member - Serendipity(WA) - Thursday, Sep 09, 2010 at 21:24
Just a simple google search states it is now 'legal' to use 10 amp leads and connections with your camper so long as you have a circuit breaker according to the change in Australian/New Zealand Standard AS/NZS 3001:2001 - Electrical installations - relocatable premises.
Read further.
http://www.caravanandmotorhomebooks.com/articles/cable_rules.htm
AnswerID: 429798
Follow Up By: Motherhen - Thursday, Sep 09, 2010 at 23:39
Collyn also says -
"Australian caravan parks that provide mains electricity have, for some years, been legally required to install safety-protected 15-amp outlets. It is now permissible to use an outlet of another rating or configuration . for specific anticipated types of relocatable premises 1 . In practice however caravan parks will continue to provide service pillar mounted 15-amp outlet sockets, circuit breakers, and residual current devices."
"At caravan parks that only have 10-amp outlets. You should move on, or forgo mains power as it's odds on that obligatory safety devices are not installed either. This leaves users at risk as these safety devices are now relied upon to provide safety protection in otherwise potentially lethal fault conditions."
Mh
FollowupID: 700605
Follow Up By: oldtrack123 - Saturday, Sep 11, 2010 at 14:05
Hi Mh
Your extract from Collyns book give the full story .
It is amazing how some will only read or believe what they want to believe.
He does not suggest that plugging in a van with a 15amp socket into a 10amp outlet is legal.
FAR FROM IT, yet many have reading his book claim that is what he has said!!
IT is still legal for a vehicle with a10amp inlet socketto plug into a 10amp power supply using an APPROVED 10ampx10amp lead, that is what he is referring to
FollowupID: 700810
Reply By: kev.h - Thursday, Sep 09, 2010 at 21:36
Main problem l see is after the fire the insurance assessor will sift through the ashes and if he finds a 15 amp appliance plugged into 10 amp source ( be it a welder or caravan ) they will deem it to have been the cause and walk away.
You then have to prove your illegal act was not the cause - don't like your chances
Cheers Kev
AnswerID: 429800
