Camper trailer suspension suggestion
Submitted: Friday, Sep 10, 2010 at 12:04
SmokeyD
I have a question re my existing camper
suspension set-up.
I have the simple spring (x 5) set up (basic semi off-road) with the axle above
the springs. I am wanting to raise the trailer's height, as it is too low - so my thought was to place the axle under
the springs, just to invert it. This would give me about 2 or more inches of lift. Is this something that can be done - will it work ok in this orientation?
Smokey.
Reply By: Member - Geoff H (QLD) - Friday, Sep 10, 2010 at 12:37
Hi Smokey,
I have done the same thing, or you could fit larger tyres, just check that your drop is long enough.
You can always dig a hole to drop the wheel into.
Geoff
429866
Follow Up By: Member - Geoff H (QLD) - Friday, Sep 10, 2010 at 12:38
Check out the My Swag
forum for all things Camper Trailers.
700651
Follow Up By: SmokeyD - Friday, Sep 10, 2010 at 12:43
Great - you wouldn't have photos of the same?
How do you go about it?
smokey
700652
Follow Up By: Member - Geoff H (QLD) - Friday, Sep 10, 2010 at 12:54
I don't have any photos, however if you have a look under the trailer you will see pretty quickly which nuts you have to undo, everything is pretty open and easy to get to.
Basically, take the
wheels and hubs off , undo the U bolts and move the axle from above
the springs to under
the springs and refit everything you took off.
I had a mate help me which made life a lot easier.
700655
Follow Up By: SmokeyD - Friday, Sep 10, 2010 at 13:33
Is there not a lug that the spacer locks into under the axle? Do you need to weld?
700665
Follow Up By: Dunaruna - Friday, Sep 10, 2010 at 17:09
Yes, there is a locating plate that centralises over the centre bolt. It will need to be welded on. You can just flip the axle 180 but if it has a camber bend (it should have) then it will need to be rebent first.
700705
Reply By: Moose - Friday, Sep 10, 2010 at 13:18
What size
wheels on the trailer?
429871
Follow Up By: SmokeyD - Friday, Sep 10, 2010 at 13:38
205/65 R15 I believe
700667
Follow Up By: Moose - Friday, Sep 10, 2010 at 13:45
Was half expecting you to say 14". Have you measured the distance under the axle and compared to the diatance under the lowest part of the vehicle? You might just be surprised. There is no need to have the trailer way up in the air. I have 10R15 tyres (which i appreciate are a bit taller than what you have) with a leaf spring setup (normal under axle) and it has heaps of clearance. I even have the spare tyre underneath as
well as a
water tank and have never had any problems off-road.
You do realise that even if you put the spring above the axle the lowest ground clearance point remains unchanged!
700670
Follow Up By: SmokeyD - Friday, Sep 10, 2010 at 17:07
Hi Moose,
Thanx for the reply - My main issue is the rear of the trailer, where there is a tail panel welded under the tailgate (houses the lights and number plate), it is only 4 inches off the ground. My car is raised and has more clearance than that. As it sits now, the car is higher than the trailer and the draw bar slopes up to the tow bar on the car.
I have a
water tank underneath also and it is in danger of being damaged. My other alternative down the track is to put on a another
suspension set.
Thanx.
700703
Reply By: Shaker - Friday, Sep 10, 2010 at 16:33
Make sure that your canvas will still reach the ground!
429890
Follow Up By: SmokeyD - Friday, Sep 10, 2010 at 17:09
Hi Shaker,
Yep, have been told that holes can be dug for the trailer
wheels, or tyres deflated if canvas too short. At present tent is a bit baggy anyway.
Cheers.
700704
Reply By: Bobjl - Friday, Sep 10, 2010 at 19:16
Smokey
In case you are unaware, I understand that if you raise the ground clearance of the trailer chassis that you must contemplate the length of canvas drop as it may be compromised and fall short of the ground.
429914
