Can anyone offer any advice
Submitted: Friday, Sep 10, 2010 at 13:54
ThreadID: 81241 Views:4429 Replies:8 FollowUps:5
Related Pages
Hello everyone,
My husband and I are trying to decide on trading in our caravan and going with a Flamingo Out back. The reason for this is our caravan although is great doesn't give us the freedom to be able to go off road. It also costs us a fortune to tow as we do not have a diesel 4wd we have wait for it a Landrover Disco 3.9. Before anyone says anything...I know..We have had major problems with this car and spent many thousands of $$ getting it all fixed and in tip top condition so we may as well enjoy it now. This car runs on Gas as well as petrol.
Does anyone else have a similar sort of set up and would it be considerably cheaper to tow a Jayco style camper. Currently we get about 22 k's per litre of Petrol towing the caravan.
Are the Jayco's time consuming to set up...As we are planing on doing the Lap and would it become a chore.......
Thanking you all in advance......
Reply By: Andrea11 - Friday, Sep 10, 2010 at 13:57
Gee now that would be the worst fuel economy what I meant to say was 22 litres per 100 k......
AnswerID: 429875
Reply By: chisel - Friday, Sep 10, 2010 at 14:47
Suggest you check out myswag.org. Many jayco owners on there.
AnswerID: 429880
Follow Up By: willem269 - Friday, Sep 10, 2010 at 15:12
Gee Andrea, you must be a bit confused. 22 K's to the liter would be an amazing, Guiness Book worth fuel consumption. Let's suppose there's a standard 80 liter tank, you carry two jerrycans at 20 liter each, that's 120 liters at 22 K's per liter, your range would be 2640 K's. Almost Perth to Kununnura without a refill ;-)
FollowupID: 700686
Follow Up By: Andrea11 - Friday, Sep 10, 2010 at 15:33
Hiya Willem,
hahahaha I know I made a boo boo........What I meant to say was 22 litres per 100 ks.....
FollowupID: 700688
Reply By: Moose - Friday, Sep 10, 2010 at 16:49
Why not go to a Jayco dealer and get them to show you how long it takes?
What is a chore to one may be a pleasure to another.
BYW - 22Kms/100ltrs probably isn't that bad for towing a caravan. I'm sure I've seen that sort of number bandied around often. What do you get when not towing? If the difference isn't significant the Jayco may not improve things by much.
AnswerID: 429892
Follow Up By: Stu & "Bob" - Saturday, Sep 11, 2010 at 08:50
Moose, I think that you got it all a bit boxed up 22Kms/100Ltrs is very ordinary, one would need a fuel tanker following to get to the corner shop.
FollowupID: 700784
Follow Up By: Moose - Tuesday, Sep 14, 2010 at 07:59
Oops. Now that would be bad!
FollowupID: 701075
Reply By: Outbacktourer - Friday, Sep 10, 2010 at 17:17
Actually 22/100 is probably not too bad towing with that kind of rig. A diesel of the same vintage would probaly save you 5-6L/100 if that.
The other thing is that the Jayco will still not cut the air all that well either and you may be disappointed in the saving. You may be better to just live with the economy and go with a rugged normal van (like Goldstream or Supreme) and get both off road ability and ease of set up. They are not running out of unleaded last I heard and if you spend an extra $1K over a lap it will probably be worth the saved effort of a pop up.
OBT
AnswerID: 429896
Reply By: Motherhen - Friday, Sep 10, 2010 at 18:36
Hi Andrea
One thing i would consider in going from caravan to fold up is the issue of room for packing requirements, if you are going out bush or travelling for long periods.
Also consider the climate where you plan to go.
We went from an old wind up (which was very small) for short holidays to a full sized off road caravan for longer touring.
The only place we haven't been able to take it so far is Purnululu in the Kimberley, where camping out for a few days was an easy option. Other places we couldn't take the van were done on day trips (similarly we would have left a trailer to do day trips to these places).
The setting up was a chore (winding up on our older camper hard work, even when we changed to a geared winch), but once we got into a system, setting up or packing down probably took us about ten minutes. This estimate does not include time needed to put up the annex as we didn't use it. We were lucky we didn't meet any rainy weather, hence never had to put up the over bed flies, not set up in the rain. The slide out beds (and i presume the Flamingo is similar) are not good in cold weather. We nearly froze one camp, whereas in the full van we don't even notice it is frosty until we look.
This tiny trailer (smaller than the Flamingo) was cheaper to pull that a 3 tonne loaded large caravan; which by the sound of your tow vehicle is much bigger than your caravan.
AnswerID: 429907
Reply By: teabags - Friday, Sep 10, 2010 at 18:42
Hi Andrea,
we had an old Golf windup similar to the Jayco style camper. And yes we found the setting up and packing up can be a real pain. While winding the roof up and sliding out the ends doesn't take all that much effort, it it all thew extras that take up the time. End flies etc all add up, and don't forget that all your storage is down low so many things need to be packed away each morning and unpacked when you setup.
Our last trip with the old camper we encountered a lot of wet weather and found packing up and setting up in the rain was beyond a joke.
We now have a poptop van and wouldn't go back.
Having said all that we have a friend with a Jayco Swan which he swears by.
There are businesses that rent out campers. Why not rent one for a week and see if it really suits YOUR needs.
AnswerID: 429911
Follow Up By: olddigger - Saturday, Sep 11, 2010 at 00:26
With a Jayco, It's not the time winding it up, it's the time you spend sweeping out the staples and other fasteners which fall out when you tow it on a sealed road, never mind off-road.
Mine is two years old, had little use and now leaks through the roof. The water intake will not work with a caravan park hose (blows off all the time), the tap on the sink is a disgrace. The overall standard of finish of such things as silicon sealing s disgracefully bad.
Won't rave on further, but I wouldn't have another Jayco as a gift.
Cheers, Tony
FollowupID: 700769
Reply By: OREJAP - Saturday, Sep 11, 2010 at 08:43
Hi Andrea 11, We tow a Jayco Swan Outback behind our T/D Pajero auto & use about 14 L/100 sitting on all speed limits. It tows very well & doesn't seem affected by wind & is stable when big rigs roar past. There is a bit of winding,pulling & pushing setting up & down but that's the way it is, everyone seems to put a big importance on time....What is the hurry? It all depends on the $$$$ horses for courses so to speak.....if we all could afford the latest T/D Sahara Toyota & a nice heavy bushtracker..Hmmmm!! We have had our Jayco for a few years & have taken it into some country where you would probably not take a on road van. For a start Jayco make these items in a mass produced situation they are not OFF ROAD hence the name outback & the reponsibilty rest with the owners how they treat them. We put underlays under both beds & use our bagged flies this is good insulation we have found. I really like the open air scenarion with all the flaps zipped down the air flow through the Swan is great. The twin beds are good too. We have queen beds both ends & sometimes use both beds especially good when the weather is really hot we find sleeping together on a very hot night uncomfortable. The extra room when the beds are out is also handy. Storage is a bit of a problem because there are no over head cupboards...everything is below the waist. A bonus with a Jayco is that parts & accessories are available everywhere. On rough roads,mud & sand just drop your tyre pressures on the Jayco & vehicle take it easy, you shouldn't have a problem. Ask the dealer to show you how to set it up & down. Try and borrow one or hire one for a few days. Good luck
AnswerID: 429965
Reply By: Member - Porl - Saturday, Sep 11, 2010 at 18:43
Hey Andrea
Weight and size is your enemy when towing.
I'd look for lighter options if I were you, here's one, there's a few around:
http://www.polycampers.com.au/photos.htm
good luck.
paulPoly type camper trailer
AnswerID: 430003
