holden rodeo, 3 litre ITD or 3 litre vdci whats the difference?
Submitted: Saturday, Sep 11, 2010 at 16:52
ThreadID: 81266 Views:23283 Replies:2 FollowUps:0
I am looking at replacing my 1995 2.8TD rodeo(TF), can anyone shed some light on the difference between the 3.0 Itd nad 3.0 VCDI engines and any problems etc.
Reply By: Isuzumu - Saturday, Sep 11, 2010 at 19:03
From the resource I have done the 3.0 TDI prior to the new CRD (VCDI) is a good motor, seems they lacked in the power depend meant. Now the old 3 litre did not have an mechanical issues, the new one which is used in the Colorado/Isuzu D-Max are so far way ahead in fuel consumption than all the other crd 4X4.
The old 3.1 TD which we have in our MUs is a great motor but old tech still with out to much work I am getting 400 NMs of torque. Next vehicle for me will be a Isuzu D-Max, I think they may have a new motor coming shortly.
AnswerID: 430006
Reply By: Member - Porl - Saturday, Sep 11, 2010 at 19:25
Well haven't got either but am looking at both.
3.0ITD was the Rodeo RA that had the old style diesel engine and discontinued in 2006 with figures as follows:
» Max. Torque: 280Nm @ 2400rpm
» Max. Power: 96kW @ 3800rpm
3.0 VCDI is the common rail intercooled turbo diesel came out 2007 for a year or two before it was replaced by the Colorado, figures as follows:
Max. Torque: 360Nm @ 1800rpm
» Max. Power: 120kW @ 3600rpm
Also, as a point of difference, if your engine, apparently, ingests too much of a "bad" batch of diesel, if it's the old style (RA) then you just run it out and put some good diesel in, if you try and run it out in a common rail (VCDI) you may be up for some very expensive injector replacement. For my now dead hilux the injectors were $175.00 each, but on the common rail diesel hilux, injector replacement costs about $4000.00.
AnswerID: 430007
