12 volt wiring for a coromal pop top caravan
Hello there
I have purchase a second hand 1989 17ft coromal pop top caravan with 12 / 240 volt systems... I would like to hook up a ext battery to run the lights but l don't now how this is done ..
I was wondering if anyone can share any ideas on this...
Thank you
Reply By: Member - Brian R (WA) - Sunday, Sep 12, 2010 at 22:55
Hi Markcus
I am basis of my thoughts on a 70's York we owned. The old van had 2 lights with a 12 volt and 240 volt globes each with a switch. If I was to update on such a van I would follow the following .........First take a look at some of the modern vans which are set up to run on 12 volt lighting. We now own a little A'Van which is what I would use as a guide. Replace the 12 volt globes with L E D lights...have the 240 volts connected to a smart charger so that your lighting is always 12 volts...if you have this 240 volts connected to a double socket you can connect you 3 way fridge to the other socket.
I HOPE THIS MAKES SENCE. I feel the good thing about these systems ,is that you only have LOW voltage wires running through the van.
Good luck and Happy travels
Brian
AnswerID: 430150
Reply By: sandk33 - Monday, Sep 13, 2010 at 08:32
Mount the battery in a box on the drawbar or wherever you may want to remembering that an acid filled one must be open to the atmosphere.
Run the appropriate size wire to an anderson plug at the rear of vehicle for charging via a duel battery system ( that is another question you can ask later) then simply run wires from the battery to a plug to matches (7pin flat or round) the one on the van and plug it in after you have unplugged it from the car there you go power to your lights providing the aux. wire is in the van with all things being equal that should be there as they have been wired that way for a lot longer than 1989.
AnswerID: 430160
Follow Up By: Markcus - Monday, Sep 13, 2010 at 08:41
So if l use a 7 pin flat connector which pin socket do l use .. electric brakes or reverse lights..
The battery will be mounted on the A frame in a semi enclosed box and its only to run the 12 volt lights in the caravan or run a outside shower / ext lights ...
Thank you
FollowupID: 700953
Follow Up By: sandk33 - Monday, Sep 13, 2010 at 08:56
#2 it is the reversing /aux circuit and it should be the black wire.
For the shower you may want to cut the ciggie plug of and just use clips straight onto battery.
Hope this helps ask again if it is not clear.
Kevin
FollowupID: 700955
