wire amps
Submitted: Monday, Sep 13, 2010 at 23:56
ThreadID: 81322 Views:6485 Replies:9 FollowUps:4
Related Pages
To all the electrical gurus,
I want to hard wire in the engle to the back of the ute,will 15amp auto wire be
heavy enough to use,with and? anderson plug or T plug. I have both,but which to use.
Ann D
Reply By: Peter_n_Margaret - Tuesday, Sep 14, 2010 at 06:35
What is "15A auto wire"?
How big the wire needs to be depends on the maximum current drawn and the total length (including earth) from the battery and back again.
Voltage drop should be well under 0.5V.
VOTLAGE DROP =
[cable length (in metres) X current (in amps) X 0.0164] divided by cable cross-section in mm.sq. (from Collyn Rivers)
OKA196 Motorhome
AnswerID: 430252
Reply By: Robin Miller - Tuesday, Sep 14, 2010 at 07:37
Hello Ann
15amp wire isn't enough you need wire with 4 sq mm of copper in it.
You have to be careful as a common size of wire (probably what you have) is refferred to as 4mm wire but its really 2.5mm of copper covered with plastic which makes it up to 4mm.
If you can, get wire with 6 sq mm of copper. This is a common size and will allow you to run some others things as well without having to go back and put in another wire.
Battery and trailer places sell the wire.
As a rough rule of thumb 1 sq mm is rated at 7amp , so 4sq mm wire is often called 30 amp wire and 6 sq mm 50 amp wire.
AnswerID: 430254
Reply By: ABR - SIDEWINDER - Tuesday, Sep 14, 2010 at 08:21
Hi Ann D
We recommend TW60 twin core solar cable for fridge connections. This cable is 6mm2 and is excellent for fridges.
I use Anderson plugs, the 6mm2 is too heavy to easily connect into T plugs and sockets.
Derek from ABR
AnswerID: 430256
Follow Up By: Ray - Tuesday, Sep 14, 2010 at 08:52
Hi Derek,
when or if are we going to get some standards for auto cable??????
FollowupID: 701078
Reply By: WATTS2C - Tuesday, Sep 14, 2010 at 09:24
ABR and the others all make good points - make sure the copper is minimum 6mm.
Like ABR we use the twin core solar cable - then you can't go wrong.
mh
AnswerID: 430261
Reply By: Member - Phil 'n Jill (WA) - Tuesday, Sep 14, 2010 at 10:29
Hi Ann D
I took the 'easy option' and purchased the Engel kit from Ranger Camping for my Pajero.
Quite proud of my first effort into 'modifying' my vehicle - my mechanic gave it his tick of approval.
Been in for a year now and quite successful to date.
Cheers - Phil
AnswerID: 430271
Follow Up By: PradOz - Tuesday, Sep 14, 2010 at 11:39
I have seen the Engel kits on the shelf for sale in Repco for around $100 - $120 from memory. Makes it a simple job....
FollowupID: 701088
Reply By: Member - Michael P (QLD) - Tuesday, Sep 14, 2010 at 11:15
Don't forget the fuse.
AnswerID: 430275
Reply By: Member - Barry (NT) - Tuesday, Sep 14, 2010 at 15:41
This table shows mm2 to diam and current ect for wire
http://www.engineeringtoolbox.com/wire-gauges-d_419.html
hope it helps guide you but good advice above to use 6mm2 wire I see
cheers baz
AnswerID: 430300
Reply By: Maîneÿ . . .- Tuesday, Sep 14, 2010 at 19:35
Ann
When using a 50 Amp Anderson plug with #6 Contacts, the recommended maximum cable that will fit is 6 AWG, so use 6 AWG and you will get the least possible voltage drop.
Maîneÿ . . .
AnswerID: 430330
Reply By: Member - Murray R (VIC) - Tuesday, Sep 14, 2010 at 23:09
Ann
If you do a thread search for thread 79389 there is a chart there that might help you with auto wire sizes and what size you will require for the length of wire and current draw
Murray
Another Mexican
AnswerID: 430363
Follow Up By: Maîneÿ . . .- Wednesday, Sep 15, 2010 at 00:03
The search for thread 79389 gave me -> "Transporting a Folding Boat Trailer on Caravan"
Maîneÿ . . .
FollowupID: 701197
Follow Up By: Member - Murray R (VIC) - Wednesday, Sep 15, 2010 at 18:38
Ann & mainey
Sorry wrong thread number try 79390 this is the right one.
Murray
Another Mexican
FollowupID: 701243
