What fuel mileage will I get if I lower my diff ratios
Submitted: Tuesday, Sep 14, 2010 at 20:07
ThreadID: 81337 Views:8030 Replies:14 FollowUps:13
Hi all
I'm looking at lowering the diff ratios on an auto turbo diesel 80 series.
It's got 33 inch all round mud tyres that I run at 40 on the road.
2 inch suspension lift.
A fair bit of extra weight making it about 2900 kg.
It's not the multi valve engine.
Cruise control.
No roof rack.
I want to lower the diff ratios one size, taking it back to about 31 inch tyres.
I mainly drive in a regional area with a few hills and corners and a little bit of highway and the odd gravel road here and there.
I check the fuel mileage every time I fill up.
I currently get about 6.8 km per litre / 14.7 litres per 100.
Around suburbia, I actually get better fuel mileage, probably because it doesn't have the hills and it's a diesel to. I get about 7.5 km per litre / 13.33 litres per 100.
If I lowered the diff ratios one size taking it back to 31 inch tyres, approximately what fuel mileage would I get?
Please I know that there's no perfect answer, just give me your best estimate before I go and spend all the money on the job. An estimate is better than nothing.
Thanks everyone.
Reply By: Member - Toyocrusa (NSW) - Tuesday, Sep 14, 2010 at 20:32
Hi there. Do you have a 5 speed manual. If so why not try driving around in 4th gear and see if the economy improves first. Bob
AnswerID: 430338
Follow Up By: bucky00 - Tuesday, Sep 14, 2010 at 20:43
No, I said in the post that it's an automatic turbo diesel 80 series.
FollowupID: 701171
Follow Up By: Member - Toyocrusa (NSW) - Tuesday, Sep 14, 2010 at 20:57
Sorry,missed that bit. Leave it out of overdrive then.
FollowupID: 701173
Follow Up By: StormyKnight - Tuesday, Sep 14, 2010 at 20:59
You could try then the 1:1 ratio 3rd gear rather than the overdrive (0.717:1).
FollowupID: 701174
Reply By: MrBitchi (QLD) - Tuesday, Sep 14, 2010 at 20:50
LOL, you're driving around in a 3ton truck and you're worried about fuel economy.. LOL.
Leave some of the "fair bit of extra weight" at home for starters. Do you NEED to carry it all around the burbs?
AnswerID: 430342
Follow Up By: bucky00 - Tuesday, Sep 14, 2010 at 21:04
I'm looking at lowering the diff ratios because it will help on road and off road performance and reduce wear on the drivetrain and improve engine braking when off road.
A handy thing with it, you said it, it's a 3 ton truck and the fuel mileage isn't flash and this will help it as well as helping performance and reducing wear on the drivetrain.
You obviously look at it as 'it's already bad, what's the point of making it better,' I look at it the other way, 'it's already bad, making it a little better is probably handy.'
Even if it didn't help fuel economy, I'd still do it, my main aim is to improve on road and off road engine performance and reduce wear on the drivetrain.
FollowupID: 701175
Follow Up By: bucky00 - Tuesday, Sep 14, 2010 at 21:10
The fair bit of extra weight is things that you can't take on and off every weekend, like a steel bull bar, heavy duty running boards, a kaymar rear bumper, a storage system, the odd little thing like a winch. It all adds up.
You've got the same attidude as Harrold Scrubby, convert a 100% suburban 4wd into an off road 4wd just before you go away and convert it from an off road 4wd into a 100% on road 4wd when you get home, like he's said before that we should take our bull bars off when we get home and only use them on weekends, not possible LOL.
FollowupID: 701176
Reply By: hotfishez - Tuesday, Sep 14, 2010 at 21:07
I would keep it as is, your economy at this point is pretty good for the vehicle....
You will regret it on the highway if you do change ratios...
AnswerID: 430347
Follow Up By: bucky00 - Tuesday, Sep 14, 2010 at 21:20
Sometimes I wonder if it would be better or worse on the highway to take it back a little, but not too much because when I've got 33's, every time I get to a hill on the highway, even just a 100 metre hill, I lose a bit of speed and the cruise control struggles and I have to put it back a gear.
Yea I don't want the engine working too hard on the highway, but I suppose you've got to admit that if it were practically sitting at idle, I'd be constantly changing gears and at the end of the day, it would be suburbia.
Overtaking is another thing to, if I lower them back to standard size tyres, it would have more overtaking grunt.
Driving in and out of towns.
I've driven other peoples cars with 35's and standard diff ratios and at the end of the day, I'd personally say that they were actually worse on the highway, they hated even the shortest hills and you couldn't overtake if you had to.
FollowupID: 701178
Follow Up By: hotfishez - Tuesday, Sep 14, 2010 at 21:53
I had the 33s on but I would do alot of highway ks living remote. If you go back to standard sure it may use less fuel, handle hills a bit better, rev a little higher at the end of the day as an all round package, if for arguments sake, if you improve fuel consumption by 1 L/100, that has only saved you $1.35 per 100 kms. If you really want gain power and economy, diesel gas it. Have it Dash switch activated so you can turn it on as you need it. Leave it off around town but put a trailer on or hit the dirt flick it on and she will come to life.
FollowupID: 701181
Reply By: Robin Miller - Tuesday, Sep 14, 2010 at 21:28
Hi Bucky
Your fuel usage will change in the direction of your revs and as a guide only at about 1/2 the change rate.
If changing from 4 : 1 to 4.5 : 1 then fuel use goes up 4.5/4 * 0.5 = 6% +/- 50%
I would try and change just transfer case ratios.
AnswerID: 430349
Follow Up By: bucky00 - Tuesday, Sep 14, 2010 at 21:35
Then how is it that 99% of people lose fuel mileage putting larger diametre tyres on their cars and most people who put huge lifts on their cars and lower the diff ratios improve fuel mileage and performance in most conditions.
I've lowered my diff ratios on past cars and it's helped mileage and on road and off road performance, it's had pretty much the same affect as having smaller tyres.
Fill me in, is there something I don't know?
FollowupID: 701179
Follow Up By: Robin Miller - Tuesday, Sep 14, 2010 at 21:55
Common mistake Bucky
Fuel use (over small ranges) goes up with revs because of engine friction.
Fuel usage does not go up because of having larger diameter tyres , it goes up
because when people fit larger diameter tyres they usually fit fatter ones
and fuel use here is related to energy loss in bending the fatter section of rubber.
So two 33 inch tyres 255/85/16 (which I use) uses less fuel than 285/75/16
in the proportion of width 285/255 i.e. 10% less for the tyre loss component of fuel use -- super roughly 5% less at 80kmh -- where air drag is not so significant.
FollowupID: 701183
Reply By: Joe Grace Doomadgee - Tuesday, Sep 14, 2010 at 21:55
yep you will get better mileage if you only change diff ratios and not the speedo cogs as your speedo will tell you that you are going a lot further but ya puttin in less fuel ....... and it gets a lot of people also ....
My advise......... do it, you seem like you have already put a lot of thought into it and i agree on most points also, worth a try and i dont thin k you will be worse off, most probally better off ....
Keep us posted as to the results, i will be interested ...
AnswerID: 430351
Reply By: Dave(NSW) - Tuesday, Sep 14, 2010 at 22:42
Bucky00,
I've got a patrol which weighs 3.3T, Originally it had 3.9 diff ratios after fitting 33" tyres I found off-road down hill engine braking was useless so fitted 4.3 diff ratios which brought it back better than standard, I found the the revs on the Hwy at 100 changed from 2200 to 2400 but it didn't struggle on hills any more and seems to have a lot better pickup. The fuel usage will be a bit better but will depend how you drive it with the increase power. If you go on LCOOL and tell them what tyres & diff ratios your running and what you want to do they should be able to give you all the info you need.
Cheers Dave..
GU RULES!!
AnswerID: 430358
Reply By: mikehzz - Wednesday, Sep 15, 2010 at 00:03
Correct me if I'm wrong, but a larger tyre has a larger circumference. For every rev of the wheel the speedo thinks you have gone so far when in fact you have gone a bit further. Therefore the only real way to measure how far you really travelled is to use a gps. Then you can get an accurate consumption figure. Using the speedo to measure how fast you are going or how far you have gone is wrong with different tyre sizes. With 31 in tyres 100 kms on the speedo might be 100 kms but with 33 in tyres 100 kms on the speedo would be closer to 107 actual kms. Lowering your gear ratio will not improve economy otherwise we would all drive around in 3rd gear all day. Overdrive was invented to get better economy. Putting larger tyres on acts just like overdrive. Mike
AnswerID: 430368
Follow Up By: StormyKnight - Wednesday, Sep 15, 2010 at 19:29
Yes that's right re the speedo error....
but each engine has a sweet spot where its most efficient - usually at the same spot of greatest torque....
However in real life situations we have things called hills & unless you have mega torque, the engine is going to drop below that sweet spot & then become less efficient & also again when you change down a gear & the revs rise again its less efficient. Overdrive is a compromise & works well on flat ground....
If you had a constantly variable gearbox you could keep the engine at the sweet spot for a greater range of speeds....but I assume they are too expensive or they still have a greater friction loss than a normal manual or lockup auto.
FollowupID: 701246
Reply By: Member - Phil G (SA) - Wednesday, Sep 15, 2010 at 02:06
Changing diff ratios won't help anything.
For an 80series Cruiser with the 1HD-T motor, the first improvement will be to change to a 3" exhaust as the standard exhaust is restrictive, particularly over the rear diff; the second will be to add an intercooler.
If it was me, I'd do the exhaust first, and see how you go. If you want a bit more then go the intercooler.
AnswerID: 430369
Reply By: ross - Wednesday, Sep 15, 2010 at 10:13
The old fashioned auto boxes sap a lot of power from the engine. A 5 sp conversion might work out better.
I drive a HZJ75 series non turbo with a 500kg camper on the back(about 2700kg all up) and get 13-14 litres/100 everywhere I go.
I dont really have any complaints about power on the open road.
Most hills can be tackled in 5th gear if I have enough speed,otherwise ,a quick flip back to 4th keeps it moving at a steady 95-100.
I reguarly do shark bay to Perth in 8 1/2-9 hours with 3 breaks,not bad for 800klms.
Im running 235x85x16 which are relatively narrow and are about 32 in
Maybe a dyno test to see how much HP you are getting would be good place to start.
I use to drive my bosses 93 80 series turbo ,5sp,and tow a 1 ton excavator and it had more than enough power for the hills
AnswerID: 430392
AnswerID: 430393
AnswerID: 430394
Reply By: bucky00 - Wednesday, Sep 15, 2010 at 20:08
I've spoken to 4wd specialist mechanics today.
They seem to disagree with a lot of things being said.
Prime example, they've told me that it will help the fuel economy and this is how one described it:
You're riding a push bike and you're in a high gear and when you get to a hill, you're using up a huge amount of energy trying to get up, sure it requires less rotations of the pedal, but you're still using more energy and it's heaps slower.
Let's say you're on a push bike taking off in a high gear, sure it's less rotations of the pedal per metre, but you're still using more energy and you're heart will be beating harder and it's slower as well, worst of both worlds.
They also told me exactly what I said about the highway.
Lowering the diff ratios back to standard size tyres helps it on the highway just as much as makes it worse because let's say you've got high diff ratios / large tyres and you get to a hill, you'll slow down and have to change back a gear, with smaller tyres, you'll cruise up without slowing down much and at the end of the day, you're fuel mileage will be just as good if not better.
These mechanics have owned cars with altered diff ratios and said that that's what happened to them, so it's not just cars they've modified, it's cars they've owned and set up in their own workshops.
AnswerID: 430448
Reply By: Member - Phil G (SA) - Thursday, Sep 16, 2010 at 18:28
Out of interest, have you done the maths on the $$$$ if you were to go that way?
Assume you change from 4.1 ratio to 4.3 (about 4.5%).
Best case scenario would save 0.63 L/100k. (optimistic in my opinion)
That would save 82cents per 100k
Cost of chnaging diff ratios I've guessed at $4000.
It would take you 487,804km to recoup that cost.
Am I missing something??
AnswerID: 430537
Follow Up By: bucky00 - Friday, Sep 17, 2010 at 17:39
The mechanic has quoted me about $1800 including labour.
It won't just save me on fuel, it will reduce a little wear and tear on the drivetrain, engine, tranny etc.
I'm also reconditioning the diffs while I'm at it, so I won't have to do anything to them for a while.
FollowupID: 701454
Follow Up By: Member - Phil G (SA) - Friday, Sep 17, 2010 at 20:16
$1800 to recond both F&R diffs and replace both crownwheels and pinions is incredibly cheap! You might want to double check it.
On Ebay, a pair of aftermarket crownwheel and pinions and diff rebuild kits will set you back about $1600 alone in parts.
FollowupID: 701468
Follow Up By: bucky00 - Friday, Sep 17, 2010 at 20:42
That's what a 4wd specialist quoted me, but there's the old saying, 'If it sound too good to be true, it normally is.'
I'll look into it.
FollowupID: 701476
Reply By: fisho64 - Friday, Sep 17, 2010 at 23:48
"If I lowered the diff ratios one size taking it back to 31 inch tyres, approximately what fuel mileage would I get? "
the easy way would be to put a set of 31's on for a week and try them to see what the difference is.
AnswerID: 430657
