Wednesday, Sep 15, 2010 at 21:42
Phil, you initially tell it the size of your
tank and when you fill it you fine tune the exact amount put in. I always* fill it so can't remember what happens to the overall '
tank' values stored. The current/today/yesterday values don't get affected. The few times I have done that I have just waited until I've filled the
tank again before selecting the 'fill up' setting so it knows the
tank is full again. In this case you wouldn't alter how much
fuel it was expecting. I've found once dialed in, it's very accurate. Last two fills have been under 1/2 litre different from gauge to bowser. Considering that's different days & different bowsers and both just over 100L of
fuel, I reckon that's pretty good.
Another nice aspect of it is you can keep reseting the current trip if conditions change (eg. dropping into low range, hooking up a van). You let it record the
fuel usage for a few minutes (since the immediate readout is also useless in such a situation) which gives you a quick idea of your
fuel consumption way before an 'average' like the cars trip computer calculates the likely range. You do need to do a bit of mental arithmetic (current usage &
fuel left) to do this though.
As mentioned, one of the best featues is the immediate readout of
water temp.
* have done partial fills a few times.
701266
