Thetford Porta Potti-
Submitted: Wednesday, Sep 15, 2010 at 10:13
ThreadID: 81348 Views:4609 Replies:3 FollowUps:1
Just a query as to whether anyone knows if possible to disassemble (pull apart) top tank on 365 model. Have to get inside top tank as flush jet and pipe has decided to come away with o ring and is inside tank.
No obvious screws etc so not sure whether it can be done.
Reply By: Member - GeeTee (NT) - Wednesday, Sep 15, 2010 at 17:43
Hi there,
Have a look here : Thetford toilet repair
It may help.
AnswerID: 430430
Reply By: Road to Discovery - Wednesday, Sep 15, 2010 at 22:58
I recommend you contact Thetford service centre via email or phone.
Our Thetford cassette loo just had some problems, and James at service centre there was wonderfully helpful. Had parts and repair instructions/diagrams in the mail to us in a flash. It was a very streamlined process, with just a 'twist' and no need for any screwdrivers or tools.
Chances are, the portapotti also has its own little 'twist' and you'll be solving your problem in no time.
AnswerID: 430464
Reply By: Mav1 - Thursday, Sep 16, 2010 at 08:53
Yes thanks for replies. Did a bit of research online and it appears to replace flushpipe and end nozzle you remove push bellow and go in thru there. I'll try BCF for spares.
AnswerID: 430490
Follow Up By: aggie - Friday, Oct 01, 2010 at 17:34
hi mav 1
Have replaced my pump needed to cut bellows to access pump on Thetford Pottie. Is an easy task. Purchased replacement pump from BCF. Replacement is complete with sealant aready in place. only need to twist old pump and break seal.
FollowupID: 702720
