Any of you bought this battery brand?
Hi all,
Looking around to buy AGM battery and came across one on ebay selling. Looks not bad and I was told the battery is similar to the Fullriver.
12V 18AH deep cycle, it has a CCA of 225 every 5 seconds with 12 month warranty.
Any of you on Exploroz got this battery brand?
Site Link
This battery has a CCA of 255 every 5 seconds and has a 12 month warranty.
Hope to hear from you soon.
Thanks!
Reply By: Central Coast Timmy - Thursday, Sep 16, 2010 at 20:15
Southside Batteries is the company name
Southside Batteries
Picture:-
AnswerID: 430544
Reply By: pdm3006 - Thursday, Sep 16, 2010 at 20:39
No I have never heard of this mob before.
It's a very small battery. What will be your use for it ?
Peter.
AnswerID: 430547
Follow Up By: Central Coast Timmy - Thursday, Sep 16, 2010 at 21:24
Pretty much just for running fluro light at camping that is all.
FollowupID: 701368
Reply By: Battery Value Pty Ltd - Thursday, Sep 16, 2010 at 22:15
If it's got a CCA rating, it's a starter battery.
Flat plate AGM batteries are either starter batteries, or deep cycle designs.
Since you indicated a deep cycle application, this battery isn't optimal for you.
The other aspect I'd like to mention is the Dollar per Ah ratio.
$3.38/Ah isn't exactly cheap considering other pre-conditioned and load tested AGM batteries fresh from the factory are to be had for under 2 bucks per Ah.
cheers, Peter
AnswerID: 430562
Follow Up By: Central Coast Timmy - Thursday, Sep 16, 2010 at 23:11
Hi Peter,
Thanks for explaining about this to me. I'm new to all this and still a little confused.
What battery type am I supposed to be looking at for general camping use like the fluro lights?
I'm guessing you mean as long as it does not have CCA rating on the AGM battery?
Thanks Peter
FollowupID: 701382
Follow Up By: Battery Value Pty Ltd - Thursday, Sep 16, 2010 at 23:45
You're welcome Peter,
yes that's right.
A deep cycle battery doesn't have a CCA rating because it's got a smaller number of plates (electrodes), but they're thicker than in a starter battery.
If a small AGM battery is rated in CCA, it's a motorcycle battery.
But you want Ah, not CCA.
See how batteries can be grouped:
Overall weight: this determines the cost of the battery, and is taken to be the same when comparing the following properties:
High Ah: smaller number of thicker plates
CCA rating: higher number of thinner plates
Rule of thumb:
at equal battery weights, the Ah goes up while the CCA goes down and the other way around.
F.e. while the battery you're looking at weighs 6 kg and is rated 255CCA and 18Ah, another equally heavy (thus similar money) may have no CCA rating, but may offer 24Ah.
Because a deep cycle battery offers more Ah per Dollar than a starter battery, look for the lowest Dollar per Ah ratio you can find.
Hope this explains it?
cheers, Peter
FollowupID: 701383
Follow Up By: Central Coast Timmy - Friday, Sep 17, 2010 at 12:43
Thank you for taking the time to explain a more detailed picture for me.
I think I know what you mean.
Have been looking all over for a battery for little CCA and its giving me a headache.
Came across a powersonic battery 30ah battery that will power my 1amp fluro for about 20-25 hours before needing charging. Was told the CCA is not the same as maximum short duration discharge current, however teh figure is 168 amps.
Does this sound okay or should I keep looking? The more I'm looking the more I'm confusing myself of batteries out there.
30ah battery link
Thanks muchly Peter.
Cheers, Timmy
FollowupID: 701431
Follow Up By: Central Coast Timmy - Friday, Sep 17, 2010 at 12:49
Sorry, also forgot to mention it weighs 8kgs for 30AH.
FollowupID: 701432
Follow Up By: Battery Value Pty Ltd - Friday, Sep 17, 2010 at 14:07
Timmy,
the first battery you looked at was $3.38 per Ah.
The one you mention now is $4.30 per Ah.
So which one is better value for money ;)
If you can see the link to my profile next to our logo below, then you can click on it to discover what our company name is all about.
cheers, Peter
FollowupID: 701443
Reply By: Maîneÿ . . .- Friday, Sep 17, 2010 at 02:42
As Peter has said get a genuine "Deep Cycle" battery
Image Could Not Be Found
These are $3.90 per Amp, and I think they're good value, I'm not aware where you can get a Deep Cycle battery of this capacity for "2 bucks" per Amp, but Timmy I'm sure you will see shortly, now I've mentioned it :-)
Maîneÿ . . .
AnswerID: 430568
Follow Up By: Member - Barry (NT) - Friday, Sep 17, 2010 at 12:41
Pete
where do you get em so cheap agree with Mainey. We have 4 x 100 ah wet cell AGM's and av price as far as I can see in 4 states so far is $330
Cheers Baz
FollowupID: 701430
