AGM Battery under the hood
Submitted: Saturday, Sep 18, 2010 at 00:41
ThreadID: 81396 Views:4830 Replies:9 FollowUps:5
Hi all,
Sold the camper trailer, now have van.
Sold the camper with wet cell deep cycle from under the hood of the 80 and kept the 120 amp Fullriver AGM from the Camper.This will go in the new van. Plan to fit the the original van battery which is a 100amp AGM under the hood of the 80 to replace the original wet cell.
Will the AGM under the hood be OK with the heat etc?
thanks GUY
Reply By: Peter_n_Margaret - Saturday, Sep 18, 2010 at 06:55
I am lead to believe that AGMs don't loke the heat.
OKA196 Motorhome
AnswerID: 430659
Reply By: Member - Phil G (SA) - Saturday, Sep 18, 2010 at 08:39
Should be OK under the hood of the 80series if you use the factory battery tray that provides great protection from the heat and locates the battery behind the headlight.
AnswerID: 430666
Reply By: Rockape - Saturday, Sep 18, 2010 at 09:59
Guy,
I have a 75 series which are renowned for the amount of heat under the bonnet.
Both batteries are spiral wound AGM's and I have never had a problem getting many, many years of service out of them.
Have a good one
AnswerID: 430668
Follow Up By: Battery Value Pty Ltd - Saturday, Sep 18, 2010 at 15:41
Hi Rockape,
interesting you mention spiral wound AGM batteries.
Do you give them occasional boost charging at a higher voltage, or is alternator charging all they ever get to see?
How deeply and how often do these get discharged?
For anyone interested in the maths:
In order to find out the relationship between life expectancy and battery temperature, you can use this simplified formula:
x=y*(1-((z/168)*(1-0.55^a)))
x...life expectancy in years
y...design life in years which is based on 25°C
z...average number of hours driven per week
a...exponent (increases by 1 for every 10°C step, i.e. under bonnet temperatures: 25°C a=0; 35°C a=1; 45°C a=2; 55°C a=3; and so on)
I've based the formula above on the Arrhenius factor of 45% for every 10°C temperature increase.
e.g:
y = 8 years
z = 30 hours
a = 3
If your under bonnet temperature is 55°C, then you can plug your 30 weekly-hours-behind-the-wheel into the formula,
and the result is: x = 8*(1-((30/168)*(1-0.55^3))) = 6.8 years
If the battery isn't going to last this long, then it's because the charging voltages aren't adjusted according to the battery temperature, and/or the charging current exceeds the max specified value.
cheers, Peter
FollowupID: 701531
Follow Up By: Rockape - Saturday, Sep 18, 2010 at 16:38
Peter,
this is the history of the batteries.
The yellow tops I have are ex mine winder batteries, they spend 2 years on and off the skips, one week powering the radios and one week on the chargers, being a critical part of the system they are replaced every 2 years and I am lucky enough to get them for nothing. Up until 3 yrs ago they were charged with Smartcharge BC-012-15A chargers, these have now been replaced with 15a ctek units, again only because they are safety critical. The charging stations sit in full sun with no airflow and summer temps are normally 40 to 45 degrees C so the batteries would be around 60 degrees C during the day. The early batteries were discharged down to around 11 volts, the newer ones don't get below 12 volts as the skip radios now don't report as often.
I got a total of 9 yrs out of one and 8 yrs out of the other. I don't discharge them below 12 volts. My main starter is a red top 5 yrs old which I killed when the charger was accidentally turned to power supply mode and left on. I use the red and yellow batteries in parallel for starting most times because of the 6.5 chevys size and compression.
I now have a time clock on the charger and it runs approximately .5 of an hour in the cool of the morning 5 am.
My alternator is set at 14.2 volts and the smartcharger at 13.8 volts. The engine bay temps are high but nowhere near as high as the old 2H motor.
Have a good one
FollowupID: 701532
Follow Up By: Battery Value Pty Ltd - Saturday, Sep 18, 2010 at 17:00
Rockape,
the secret to the batteries' longevity in your setup is the shallow discharge of the batteries.
And because the spiral wound AGMs have the best chemistry of all of them (pure lead/tin), they're pretty forgiving in terms of high temperatures.
That's because there's nothing much prone to corrosion inside them (compare this with calcium and associated alloying metals like aluminium which get eaten away in no time under high temps and then leave the positive grids brittle and thin).
If you'd discharge them deeper, you wouldn't get away with the 14.2/13.8V charging setpoints though.
In such a case you'd let the terminal voltage rise to 14.8V, and after a few hours, the batteries would be fully charged.
But congratulations, you've found a pretty good charging routine for your app!
cheers, Peter
FollowupID: 701533
Follow Up By: Rockape - Saturday, Sep 18, 2010 at 18:11
Peter,
thanks for the info and Guy may also benefit from it.
Have a good one and may all the rocks you kick turn to diamonds.
FollowupID: 701540
Reply By: Alloy c/t - Saturday, Sep 18, 2010 at 11:47
The first AGM I bought was / is a Fullriver 80amp , now 8years old , all its life has been spent under the bonnet , 1st in an 80 series turbo diesel as the aux batt , for the last 18mths as the starter and one and only batt in the Rodeo dual cab also running the fridges , waeco 80 lt and engle 15 , 8years and still going strong.
AnswerID: 430673
Reply By: guy007 - Saturday, Sep 18, 2010 at 15:03
Thanks for your comments. Believe it should be ok under the bonnet.
regards
Guy
AnswerID: 430691
Reply By: chisel - Saturday, Sep 18, 2010 at 18:30
I had a 120AH AGM under the bonnet of my 100 series TD for a couple of years.
It had a basic heatshield around it. It "died" recently. I'm not sure if it was the heat that killed it. It hasn't bulged out at all. It still holds 12V mostly but is flat (11.6V) after 60AH of usage and it sometimes drops out to 6V - something clearly amiss. I definitely couldn't say for sure that the heat killed it but I'm not game to put another AGM there now.
AnswerID: 430720
Reply By: Member - Norm C (QLD) - Saturday, Sep 18, 2010 at 22:00
I've had a 90 AH Fullriver AGM under the bonnet for 5 years. Three years in Hilux TD, then two years in a 79 series. Still going strong, with no ill effects.
Norm C
AnswerID: 430747
Reply By: Member -Toonfish - Sunday, Sep 19, 2010 at 21:40
make sure you have a metal jacket surrounding the battery if you already didnt and if its not a genuine shroud just make sure the vent isnt covered.!
2013/14 around oz adventure bound
AnswerID: 430821
Follow Up By: Member - Phil G (SA) - Monday, Sep 20, 2010 at 18:52
Why do you say metal?
The factory shrouds are some sort of composite plastic for safety (short circuit) reasons.
FollowupID: 701657
Reply By: Member -Toonfish - Monday, Sep 20, 2010 at 20:37
the full river batteries come with a extra metal casing around the plastic case as they are known to expand due to hot conditions so they recomend their metalwork in under bonnet applications.
even the frpc2500 high crankers.
AnswerID: 430900
