Immobilizer stopped working how to fix
Submitted: Sunday, Sep 19, 2010 at 00:20
Member - MYPRADO
Immobilizer stopped working so i checked the fuses, all were okay, checked battery in hand piece all okay, i then pulled the plug from the signal box and bingo it reset itself, something i learned from the mines. Hope this can be of some help to someone in same situation.
Reply By: Shaker - Sunday, Sep 19, 2010 at 11:18
Where is the signal box located? Thanks.
430773
Follow Up By: Member - MYPRADO - Sunday, Sep 19, 2010 at 23:28
Under the steering wheel remove the large plastic cover, on the r/h side is a plastic pipe its hidden behind it, also on the same large plastic cover there is a red light follow the wires and it will lead to the signal box.
Cheers.
701612
Follow Up By: Shaker - Monday, Sep 20, 2010 at 09:05
Thank you.
701621
