Best Battery for Camper Trailer
Submitted: Sunday, Sep 19, 2010 at 13:32
ThreadID: 81420 Views:5386 Replies:4 FollowUps:6
Hi Guys,
Have taken the plunge and got a camper trailer, since the kids have come swags just don't cut the mustard. I am currently wiring up the camper and would like to know which sort of battery would people recomend. Also do I need to ventilate the battery compartment while the battery is charging.
Thanks in Advance
Reply By: Battery Value Pty Ltd - Sunday, Sep 19, 2010 at 14:40
Locker,
most people nowadays are using AGM type batteries.
As long as you leave some small openings, there will be enough ventilation for the small amount of gas generated (hydrogen gas is extremely volatile and disperses quickly in the atmosphere).
Note that the best battery (which doesn't have to be expensive) is only as good as the charging system.
Once you've got the charging system right and matched to the type of battery you're going to use, things will work smoothly.
cheers, Peter
AnswerID: 430786
Follow Up By: Maîneÿ . . .- Sunday, Sep 19, 2010 at 18:42
Locker,
Read what Peter has said (above) and have no realistic future 12v power problems
Maîneÿ . . .
FollowupID: 701593
Reply By: Member - Josh (TAS) - Sunday, Sep 19, 2010 at 15:34
Not sure where you are but if in Melb go and have a look at the Obriens set up on their trailers. They are in Greens rd Dandenong. They have got it set up reallhy well. We have one of their trailers and the charging is spot on. It is quick and effecient.
Josh
AnswerID: 430791
Reply By: LOCKER - Monday, Sep 20, 2010 at 07:50
Thanks guys,
Your input is much appreciated
I am looking at getting a Fullriver 120Ah deep cycle, and hopefully have it all done by the October long weekend
thanks again
AnswerID: 430841
Follow Up By: WATTS2C - Monday, Sep 20, 2010 at 08:37
Fullriver's are good reliable batteries - can't go wrong there
mh
FollowupID: 701618
Reply By: Member - Captain (WA) - Monday, Sep 20, 2010 at 08:34
Hi Locker,
While AGM's are the "best" battery, they are not the cheapest and perhaps not the best value for money. Unless you also invest in a quality charging system, it may be more economical to go with a deep cycle wet cell battery. Do you plan to charge from the vehicle or add a battery charger to your camper? And if adding a battery charger, is it a 3 stage charger or just a cheapy?
There are many different answers to your question depending on your budget, how much power you plan to use and how often you will be able to recharge. Unfortunately there is not a "one size fits all" for battery questions.
Captain
AnswerID: 430842
Follow Up By: Maîneÿ . . .- Monday, Sep 20, 2010 at 09:24
Naahhh, Captain respectfully can't agree here, as you rightly say AGM's are the 'best' battery, so I would suggest Locker forget his budget today and buy the 'best' and *most efficient* battery available.
A good AGM may cost $100 - $150 more than the same "ah" wetcell battery, but the wetcell will take longer to recharge and it won't last as long as the AGM.
AGM's will save money in the long term because good AGM's are designed with a 10 year service life and will recharge much faster than wetcell batteries.
Another thing to consider is the charging voltage available to Locker, as some batteries NEED a very high voltage to fully charge - some don't :-)
Maîneÿ . . .
FollowupID: 701623
Follow Up By: Member - Captain (WA) - Monday, Sep 20, 2010 at 09:56
Hi Mainey,
I don't disagree that AGM's are better, but unless its sized for his needs and has a good charging system, it will get a poor life. So, if the battery is having a shortened life, a wet cell will likely last just as long as an AGM under poor conditions (may only be a few trips if run dead flat and not recharged properly - or overcooked with a cheap charger).
If one can afford an AGM and decent charger, its a better system at a cost of around ~$600 upwards. But if on a budget, a ~$150 wetcell being recharged from the vehicle and then a trickle charger will likley last as long (short!) as a ~$300 AGM battery. You would need to get twice the life to break even. All horses for courses.
I have had wetcells and currently have AGM's so am aware of their differences - AND their costs.
Captain
FollowupID: 701624
Follow Up By: Maîneÿ . . .- Monday, Sep 20, 2010 at 11:36
Captain,
Are you suggesting a wetcell will last longer under *exact same conditions* you've nominated ?
Maîneÿ . . .
FollowupID: 701626
Follow Up By: Member - Captain (WA) - Monday, Sep 20, 2010 at 12:12
Mainey,
Please read my post above S.. L.. O.. W.. L.. Y..
I said that under poor conditions "...a wet cell will LIKELY last just as long as an AGM...". Now, I will type this slowly as well, hopefully you will understand what I am saying.
Neither battery will last very long under poor conditions, however, as a wet cell is approx 1/2 the cost of an AGM, you will lose less money by buying a wet cell than an AGM if you are not going to treat your batteries nicely.
I use AGM batteries in my camper, they have many advantages but one big disadvantage, COST. I also have wet cells under the bonnet of my vehicle, heat is a killer for batteries so why put an expensive battery under the bonnet only to shorten its life with the heat of twin turbos?
I subscribe to the theory of using the appropiate, cost effective, tool for the application. There is no question that AGM batteries have many advantages, however they are NOT the answer for every situation and I was just trying to let the OP know that there are alternatives depending on your budget.
Anyway, enough hijacking of this thread from the OP.
Captain
FollowupID: 701627
