Mobile Phones with Blue Tooth
Submitted: Sunday, Sep 19, 2010 at 15:32
ThreadID: 81421 Views:3707 Replies:5 FollowUps:5
G’day,
A friend, (Garryk ) is unable to login to site and has asked me to post this message
As the range of mobile phones available is so vast and ever changing I thought I would ask here for recommendations
What I want is a BASIC phone with blue tooth capability
In addition it should have good battery life and be robust and easy to use
As it will be used to make and receive calls and SMS messages
Most other features I see as of little importance as if I want to take a photo I will use a camera and if I want to send an email I shall use the computer and there are plenty of better ways to listen to music
My present carrier is Optus
Also do the flip open style phones have to be flipped open to receive a call via the blue tooth inbuilt to some cars
Pedro
Reply By: Robin Miller - Sunday, Sep 19, 2010 at 16:04
Many here, including us, used the Samsung A411 , and have since gone to its $99 replacement the Samsung C5220.
It has all of the above and in an easy to use flip style.
This means that with 1 finger you can open / close it to pickup or cancel a call even when phone is in a pocket, and in its normal state it is closed which reduces dust intake and makes it stronger.
You can also set the clock such that it display a normal - non digital clock face.
These and a number of other features mean it can usually be used without putting your glasses on.
Has the Telstra tick as well if you wish to plug into an antenna, and good sensitivity.
Battery life is good - but note when you have Blue tooth on - all phones have a shorter battery life.
AnswerID: 430794
Follow Up By: Member - Rod N (QLD) - Sunday, Sep 19, 2010 at 16:24
I have the same and find it a good unit.
No you don't have to open it for Bluetooth to work. My multi function device can auto answer even when phone is in my pocket.
Rod
FollowupID: 701590
Follow Up By: Member - John S (INT) - Sunday, Sep 19, 2010 at 19:25
I also find this phone pretty reliable, in day to day knocking about, I am on my second one as the first one drowned after falling out of my top shirt pocket, whilst fixing a fence across a creek, but it had previously lived to tell the tale of a dunking, when it fell out of my pocket whilst cleaning out a stock water trough.I have dropped the phone several times and it still keeps going. The moral of the follow up is they are good tough phones which get good reception in areas were it is available(mine is with Telstra) ,but i now keep it in my jeans pocket.
Cheers John.
FollowupID: 701596
Reply By: Member - Doug T (NT) - Sunday, Sep 19, 2010 at 17:59
I see you mentioned the $99 Samsung, well after yesterday's drama I can really recomend that phone, the Station owner here where I live just got one a week ago, he was out in the bush driving along the fence track when it fell off the dash onto the floor, then it must have vibrated itself to a hole in the floor and fell out, so I went along with him in the Triton to try and find it by making it ring, that didn't work too good because of the engine noise but we did stop at a couple of places where it was rough. So I stood in the back righ down the fence line and on the way back I noticed an object on the track...same color as the grey dirt, hey this phone must have been run over 3 times and it still works perfect.
Image Could Not Be Found
AnswerID: 430798
Follow Up By: Robin Miller - Sunday, Sep 19, 2010 at 19:19
Good one Doug.
Get him to leave Bluetooth on next time so it can be found from 30 or so meters away without needing to hear the ring or even have network access !
FollowupID: 701595
Reply By: Member - Graham H (QLD) - Sunday, Sep 19, 2010 at 18:17
If you want your phone to do this you must authourise the phone to accept the device and it will do it automatically
Then hide your phone in the bluetooth menu aor everyone you walk past may try to connect if theirs is open as well
AnswerID: 430803
Reply By: the redbacks - Sunday, Sep 19, 2010 at 19:09
Hi Peter R,
another thing to remember about the Phone bluetooth connection to the car's connection !!
A few new car Bluetooth maynot be compaitable with the Phone
ie: the Samsung was not able to connect with the Nissan system, so the telstra saleman took 3 different phones out to my car & tried all three, the only one that worked for me was the HTC snap,& i'm very happy with that phone
hope that helps a little
Dave
AnswerID: 430809
Follow Up By: Member - Gavin W (QLD) - Sunday, Sep 19, 2010 at 19:50
Peter,
I have the HTC Snap as well. I can be a little slow at times, but it is blue tick (country) reception. It is compatible with many stereo systems as well. I'm really happy with it.
FollowupID: 701598
Follow Up By: Member - Peter R (QLD) - Monday, Sep 20, 2010 at 17:32
GarryK , is still unable to login and would like to thank all those who put forward suggestions.
He is still making up his mind
Pedro
FollowupID: 701642
Reply By: tim_c - Wednesday, Sep 22, 2010 at 22:57
I'd suggest if you want something robust, avoid the flip or slide style phones. I've found Nokia phones to be pretty robust and my current phone is a 2730 Classic (I think "Classic" means it's not a flip or slide phone). It has pretty good battery life unless I use it for the things you said you're not interested in anyway (emailing and listening to music on the external speaker).
AnswerID: 431127
