Maco Mule Tyre Pressure
Submitted: Monday, Sep 20, 2010 at 21:23
ThreadID: 81450 Views:5878 Replies:3 FollowUps:0
G'day All
Anyone know what the correct tyre pressure is for a Dual Maco Mule? Have recently shifted house and can't easily locate the User Instructions that came with it.
Thanks in anticipation....
Mark R.
Reply By: Member - Bucky - Tuesday, Sep 21, 2010 at 07:54
Just pump them up to about 60 psi, and see how they perform !
May need 80 psi
maybe 50 psi
Concrete will be different to grass and gravel, but I am sure you can adapt
Bucky
AnswerID: 430930
Reply By: mike39 - Tuesday, Sep 21, 2010 at 08:01
Mine is a single wheel one which is used to manouvre a van with a ball weight of 180kg.
Because the ground is both uneven and sloped I find if the pressure is too high it simply does not grip.
I find that 45psi works well, although it does look a trifle flat at this pressure.
Hope that is of some small help.
mike
AnswerID: 430932
Reply By: Member - Mark R (SA) - Tuesday, Sep 21, 2010 at 21:43
Thanks Gentlemen for your feed back...
I've since found out that recommended pressure is 50psi (max).
Mark R.
AnswerID: 431013
