Uluru to Chambers Pillar
Submitted: Tuesday, Sep 21, 2010 at 22:48
stew1978
Can anyone tell me the best way to get from Uluru to
Chambers Pillar. Hope to do the trip in one day.
Looking at the Hema map of the area I was thinking of Lasseter Way, left on to Luritja Road, Right on to Ernest Giles Road, Left on to Stuart Hwy, Right on to Hugh River Stock Route. Then head south to Maryvale and onto
Chambers Pillar.
I could skip Luritja Road & Ernest Giles Road by spending more time on the Stuart Hwy but would prefer to spend more time "off road" if possible.
What are the above tracks like. Is there much to see along the way and how long will it take. Is there a shorter/faster way. Keep in mind that I will more than likely be travelling alone (one car).
Reply By: stew1978 - Tuesday, Sep 21, 2010 at 23:00
I could also head straight to the Stuart Hwy and then onto
Horseshoe Bend but on the map it looks like the track past
Horseshoe Bend is a private track. Are you allowed to use this track?? if so do you need permission
431018
Follow Up By: mikehzz - Wednesday, Sep 22, 2010 at 00:37
A post a few months ago mentioned that the private road into
Chambers Pillar had been closed. I'm not sure if it is the road you are talking about. As far as I know the only way in is via Maryvale station. Mike
701796
Follow Up By: equinox - Wednesday, Sep 22, 2010 at 19:12
I've been that way 5 years ago, then around anticlockwise to the pillar. The road is good all the way to the railway. I don't know if this track is out of bounds; the station people waved at me when I drove through..I forget the name of the station before however I stopped in to say gday and no one was home.
I'm assuming the "private road" mikehzz is the one south of Idracowra. When I drove past there was certainly a
sign stating "private", "no entry" etc etc...would be a great shortcut..
701866
Reply By: Motherhen - Tuesday, Sep 21, 2010 at 23:07
Hi Stew
Sounds like the best way. We have been on all of those roads except the Ernest Giles (with our caravan in 2008), but from others who have been through the Ernest Giles it is no worse. We found parts of the track into
Chambers Pillar from Maryvale about the worst - we had come down from
Alice Springs on the Old South (Finke) Road. We went on the Ernest Giles for a very short distance from the Stuart Highway to see Henbury Meteor Craters. The Hugh Stock Route was good (one section which was not as
well maintained had
creek line dips to watch out for). We travel solo.
A little further north of the Hugh Stock Route is the turn off to
Rainbow Valley. I particularly liked this small
sandstone ridge which is very different to others in the area, being colourful, smooth, soft and creamy. A great sunset viewing spot, but good at any time of day.
Are you towing?
431019
Follow Up By: Motherhen - Tuesday, Sep 21, 2010 at 23:12
Stew, you put your second post while i was typing my reply - so i was not referring to the
Horseshoe Bend Road, which i am not familiar with.
Mh
701791
Follow Up By: stew1978 - Wednesday, Sep 22, 2010 at 11:16
No, not towing. We will be driving our 100 series cruiser. It will be loaded up a bit as we will have two kids with us so a fair bit of gea r on board. Not over loaded however. Had no problems with a similar load on the vehicle at
Cape york last year
701823
Reply By: Peter_n_Margaret - Wednesday, Sep 22, 2010 at 15:47
In 2007 we drove from Uluru to
Chambers Pillar.
The Ernest Giles Road had the worst corrugations we have experienced (and we have experienced some doozies).
The Hugh River Stock Route was very good, just don't get lost crossing the rail line.
The Old South Road was "pretty ordinary".
Maryvale to
Chambers Pillar was OK.
None of that information is of the slightest use to anyone now though :-(
Don't miss
Rainbow Valley or the
art gallery at Titjikala.
431078
Reply By: rumpig - Wednesday, Sep 22, 2010 at 17:04
we did the Hugh River Stock Route a few months back from the Stuart Hwy to
Chambers Pillar. i'm pretty sure that's the route we took anyway, you turn right off the hwy about 30 klms North of the metorite crater turn off from memory?
the track (more like a graded dirt road really) was in really good condition back then, and your Landcruiser will have no problems, heck it was that good i probably could have driven a Commodore along it without a drama. there's a few gates to open and close along the way, you turn left after crossing over the train line (not right like you'd think), then follow the line North for a tiny bit, before turning East at the bottom of the train bridge (i think where you cross the river?) for the run towards Maryvale.
you'll easily do that drive in a day, the slowest part will be once you turn off at Maryvale to go in towards
Chambers Pillar. about 10 klms from the campground the track was quite corrogated, but the rest of the road had graders working on it when we were there, so was very easy going.
431086
Reply By: Jumankum - Wednesday, Sep 22, 2010 at 17:42
I recommend sticking to the Lasseter way.
We did 50odd klms along Ernest Giles Road from Rogers pass to Luritja Road after coming through the
Finke Gorge National Park in June this year.
Sections of very heavy corrugations in
places comparable to the worst sections of the Canning.
If you stick to the Lasseter - Stuart - hugh river etc you should have no problems getting there in one day.
Cheers Jim
431087
Reply By: Rod - Wednesday, Sep 22, 2010 at 20:19
I did Uluru to
Chambers Pillar via the Stuart Highway and Hugh River Stock Route about 6 weeks ago. The Hugh River Stock Route was very cut up and muddy in
places after the rain. There is a campground at a place called "Oak Valley" along the Hugh River Stock route if you don't quite make it. From memory, about 25 km from the eastern end of the route.
I was expecting a campground at the Maryvale store, but there is none. There were people camped in the township nearby, but it looked a very rough place with problems with the locals. I would not recommend staying there.
Do check out the Maryvale store. Sells a very wide range of products from frozen kangaroo tail, aboriginal artefacts, 3kg tins of bushells tea, clothes to a top loading washing machine.
Fuel sales close at 5pm from memory.
The track from Maryvale to
Chambers Pillar was very good.
All doable in a long day.
431103
Follow Up By: Rod - Wednesday, Sep 22, 2010 at 20:22
Sorry, I should say
Yulara to
Chambers Pillar... Obviously can't
camp at Uluru any more...
701878
Reply By: Ruffy-Dan - Wednesday, Sep 22, 2010 at 23:01
It was some years ago now, but upon returning from
chambers pillar we turned off onto a station track, from memory about 25km from the pillar, and headed west towards the train line. We followed the train line to the "big white tyre' where we again turned west and entered
rainbow valley from the back way. then proceed from
rainbow valley to the highway and onto uluru. I have no idea wether or not this track is still allowable or not but it was a great trek at the time. Easily done but somesoft sandy sections and dry creeks to negotiate.
Dan
431128
