Transporting gas cylinders
Submitted: Wednesday, Sep 22, 2010 at 14:25
bdare
I'm planning my first 4WD trip and want to take one 3.7kg and one 2kg gas cylinders. I drive a Prado with good roof racks. I know you must not transport them in the car, but are they ok to be tied on the roof racks in the sun? Is it essential I buy a storage rack?
Reply By: MrBitchi (QLD) - Wednesday, Sep 22, 2010 at 14:27
I carry a 2kg on my roof rack no problems. Strapped on with a GOOD ocky strap.
431071
Reply By: pmk03 - Wednesday, Sep 22, 2010 at 14:37
Same here, I carry a 4kg on the roof rack against one side & held there with a decent ratchet strap. Never had a problem, but check the strap each time I'm out of the vehicle.
I don't think sun is an issue, when you think of it all the caravans have gas bottles exposed to the sun on the draw bars.
PMK
431073
Reply By: Member - Redbakk (WA) - Wednesday, Sep 22, 2010 at 15:37
Yep, same here....just strap it down on the roof rack and sometimes in a plastic milk crate style of thing.....no issues with the sun etc BUT never inside a vehicle and that goes for petrol as
well......a leak , a spark and BOOOOOM and you will be travelling faster than a space shuttle.
431077
Reply By: Andrew & Jen - Wednesday, Sep 22, 2010 at 16:00
So, you are travelling along at 100kph with your 4 kg gas bottle on your roof rack, held on, mind you (and I quote) "by a GOOD ocky strap". You have a collision, or a roll over, and the gas bottle breaks loose and continues on at 46 m/sec. [In this situation, an ocky strap would be near on useless at holding the bottle in place.]
Having gone through another car's window, the top of the bottle ruptures, releasing gas and it explodes, incinerating the occupants.
At a later date in the coroner's court, you are asked how you secured the gas bottle - "with a GOOD ocky strap, your honour", you reply. Expert witnesses then give evidence that any strap/webbing used for this purpose should have a SWL of at least 220kgs (I'm guessing here but it would need to quite strong).
In handing down the report, the coroner recommends that charges should be laid against those responsible for securing the gas bottle, as the method used clearly broke the law re the safe securing of loads.
Just a scenario ---- but food for thought!
Andrew
431080
Follow Up By: Member - Graham H (QLD) - Wednesday, Sep 22, 2010 at 17:19
Of course it will never happen LOL
Till it does then It wasnt my fault your Honour.
701848
Follow Up By: Member - Duncs - Wednesday, Sep 22, 2010 at 17:28
You would have to be unlucky. If you start worrying to that extent about every little thing that could go wrong you would never get out of bed.
Then again you should probably not go to bed because statistically more people die in bed than anywhere else on earth.
Yeah you should properly secure your load but how long since you checked your 220kg strap. Are there rust stains, nicks or cuts in the strap, is it faded by the sun? What about the hooks and ratchet are they in perfect order?
Duncs
701849
Follow Up By: Andrew & Jen - Wednesday, Sep 22, 2010 at 17:47
So Duncs, are you going to say to the relatives of those killed "
Well, you would have to be unlucky - they were clearly in the wrong place at the wrong time". This is the nature of accidents - people being in the wrong place, etc. The court does not accept this as a valid excuse. It is an avoidable consequence.
Commercial operators have to secure their loads. We need to accept our responsiblities as
well. Ignorance of the law is not a defence - let alone your sense of guilt afterwards - the "if only I had ........" conversation.
Andrew
701850
Follow Up By: MrBitchi (QLD) - Wednesday, Sep 22, 2010 at 17:55
Point taken.
But of course, "it will never happen to me, your honour" ;-)
701851
Follow Up By: Member - Duncs - Wednesday, Sep 22, 2010 at 18:07
Andrew,
I take your point.
In my job I face the very real possibility of an encounter with the Coroner and it is not something I take lightly. I work in what is an inherently dangerous workplace. As a result I constantly conduct risk assessments and plan changes to work practice to avoid that encounter. So far so good.
Now I wonder if you got
mine.
The scenario you created is extremely unlikely. I know you were only inventing something to make your point but lets be a little rational. I used to carry my spare on the roof. It was held in place by a 5/16 nut and bolt, as dependable as sunrise. A friend of
mine who just happens to be a metalurgist once comented that he was not sure it would hold the spare in case of a high speed accident. How far should I go?
The requirement to secure your load is there to prevent loads falling off under normal circumstances. In the course of my work I have attended the scene of numerous fatal motor vehicle accidents. In most cases where there has been a load secured to the outside of a vehicle that load has come loose. In a couple of cases that has contributed to the damage caused in the accident, never to the fatality. Never have I ever heard of a driver being convicted for losing a load in an accident. I have seen a driver charged when the loss of the load caused the accident.
Duncs
701854
Follow Up By: Andrew & Jen - Wednesday, Sep 22, 2010 at 18:40
G'day Duncs
Confession - I am playing the devil's advocate a little :-) But there is an element of seriousness in what I am doing :-( We need to think of consequences BEFORE the event. Too many people just give consideration to securing the load in order to stop it rattling, or chafing, or whatever. It is all a matter of risk analysis that includes others, not just self interest
Wrt the spare tyre - I too have a central bolt on to the Rhino - but I also have a tri-strap on to eye bolts as
well, as the thought of the spare being launched into space is a bit daunting - and the extra coast is minimal.
Now even if no charges, I still don't want it on my conscience.
Andrew
701858
Follow Up By: Member - Mark G Gulmarrad - Wednesday, Sep 22, 2010 at 18:46
fair dinkum you blokes!!!!
you would argue about the colour of the sky sometimes i reckon.
if you cant carry a gas bottle in the car........nor on the outside.........just how the hell do you get the damn thing home?????
*shaking head*.
701859
Follow Up By: pmk03 - Wednesday, Sep 22, 2010 at 19:08
Are we assuming the roof rack will stay on the vehicle in an accident? So no matter how
well you secure anything up there it's at risk of leaving the vehicle.
Lets all calm up a bit hey, This is supposed to be a site for ideas but it always ends up an ego fight.
Lighten up a bit,
I Guess you don't swim in the sea because of the "Risk" of sharks also
The worlds gone mad with the worrying about "what if"
PMK
701865
Follow Up By: mullyman - Wednesday, Sep 22, 2010 at 19:26
Been carrying gas bottles secured in the boot for 35 years. You're sitting in a cage doing 100k plus with 80+ litres of
fuel on board and a dirty great caravan or camper trailer dragging behind you. What is the problem here? Unbelievable.
701868
Follow Up By: Member - Graham H (QLD) - Wednesday, Sep 22, 2010 at 20:04
Mullyman
Would you travel with petrol in the boot.
Gas is just as dangerous as several people have found out.
Always one who wont observe the law isnt there.
It wont happen to me is alive and
701875
Follow Up By: SDG - Wednesday, Sep 22, 2010 at 20:52
Was a time i use to carry a
fuel can, and a gas bottle in the back of the car. This was before I got a larger vehicle, roof racks, long range tanks etc. Still carry smaller versions on the bike
701882
Reply By: AntandNat - Wednesday, Sep 22, 2010 at 18:09
I think that the point everyone is suggesting, but not actually saying is that a proper cylinder bracket is what is required. Why some carry on and on with digressions and not answer the question happens way too much.
431089
Follow Up By: Member - barry F (NSW) - Wednesday, Sep 22, 2010 at 18:28
Well spoken & very good advise. It was ADVISE that the original poster was asking for. But the do gooders had to come out with everything but advise.
So put your lump of 4x2 away fellahs & girls, AntandNat has just put the question into perspective and offered a bit of fair dinkum advise!!
701857
Follow Up By: Glenndini - Wednesday, Sep 22, 2010 at 19:34
or ADVICE even.
701870
Follow Up By: Member - barry F (NSW) - Wednesday, Sep 22, 2010 at 19:37
This post has been read by the moderation team and has been moderated due to a breach of The Personal Attacks Rule
Forum Moderation Team
701871
Follow Up By: Glenndini - Wednesday, Sep 22, 2010 at 19:43
I'm offering ADVICE on the difference between the verb "to advise" and the noun "advice".
701872
Follow Up By: Member - barry F (NSW) - Wednesday, Sep 22, 2010 at 19:53
701874
Follow Up By: AntandNat - Thursday, Sep 23, 2010 at 07:25
Sorry for the typing error. Does every typing error draw such attacks, or is it just from those who don't like what is said? The amount of entries moderated by the FMT interests me - more examples of unecessary entries.
701909
Reply By: Outa Bounds - Wednesday, Sep 22, 2010 at 18:09
Well then I guess you better switch to a dual fuel
camping stove and siphon petrol out of your fule
tank then!
431090
Follow Up By: garrycol - Wednesday, Sep 22, 2010 at 20:05
And following the logic of some people, my vehicle LPG
tank that is also inside just behind the front passenger would have to be emptied. I have no issue carrying fuel and gas inside a vehicle as long it is in a correct container and properly secured and double checked.
Yes accidents can happen but so they do wherever they stored.
As some one has said - if you cannot carry on these items on the roof or inside where do you carry them.
On my last big 4wd trip I slept just above the 110l of petrol in the main
tank while cuddled up to the 90l LPG
tank with 100 litres of petrol in jerries stored above lpg
tank and did my cooking inside using my gas gear.
Not an issue because all the gear is in top condition and securing stowed against movement with adequate padding to prevent chafing etc.
701876
Follow Up By: Dave(NSW) - Thursday, Sep 23, 2010 at 07:45
This is what can go wrong cooking inside a vehicle with gas.
Image Could Not Be Found
Cheers Dave..
701914
Follow Up By: Member - Phil G (SA) - Thursday, Sep 23, 2010 at 20:30
Dave,
I've seen the same result from someone running their 3-way fridge overnight in the back of their wagon.
Also saw a 3-way fridge explode overnight at
Palm Valley a couple of months ago. It was out in the open too - destroyed everything around it.
Can't be too careful with LPG - main problem is that its a fair bit heavier than air so it can pool down low and is explosive.
702001
Follow Up By: Dave(NSW) - Thursday, Sep 23, 2010 at 21:34
"Can't be too careful with LPG - main problem is that its a fair bit heavier than air so it can pool down low and is explosive."
That's exactly right, Things might be good 99% of the time but it only has to go wrong once to be a disaster, Using gas inside a vehicle is not worth the risk.
702004
Reply By: lindsay - Wednesday, Sep 22, 2010 at 20:27
Isn't it funny ,opinions are like backsides, everyone has one!!!!!
431106
Reply By: Bazooka - Wednesday, Sep 22, 2010 at 21:35
Incredible to me that anyone would want to risk the lives of their families/passengers carrying filled gas bottles inside a vehicle, or relatively unsecured, for any great length of time. Plenty of examples of what can happen with leaking gas in confined spaces.
Well-secured on the roof rack seems a reasonable option.
431115
Reply By: Member - Geoff H (QLD) - Wednesday, Sep 22, 2010 at 22:54
That has me thinking.
I use zip ties to hold all sorts of things together, even held the tray on an old Nissan on a trip to the cape once.
Never really thought about the force exerted in a 100k accident.
I'll use two zip ties from now on.
Geoff
431126
Reply By: Hairy (WA) - Thursday, Sep 23, 2010 at 10:43
Gday,
I would be a bit careful with the sun....depending when and where you go.
The big cylinders at servos have a sprinkler set up on them that comes on automatically when the cylinders get too hot.
Ive seen the sprinklers come on plenty of times in summer, so that tells me it could be an issue in really hot conditions.
431175
Reply By: Member - Tony V (NSW) - Thursday, Sep 23, 2010 at 12:20
bdare,
Fascinating post and options from the downright "scary" to the "she'll be aright mate"
So I thought that I would get some expert advise.
So I went to the
NSW Fire Brigade infor page (click here)
They also have a fact sheet
LPG Cylinder fact sheet.
431187
Follow Up By: Nev (TAS) - Thursday, Sep 23, 2010 at 16:01
In this fact sheet it says permissible to carry up to 9kg in car, preferably in the boot. I have always carried my gas cylinder in the boot, upright and with packing around it. I thought I was told that was OK (legal) but this thread got me worrying a bit. So it turns out I have been doing it correctly which to me is a relief. I have always tended to store it away from the end of the boot towards the back
seat, thinking it would be more cooler with the car roof over it than the just the boot lid.
Nev
701963
Follow Up By: Member - Tony V (NSW) - Thursday, Sep 23, 2010 at 18:02
Nev,
Its different for tradies as they are covered by Workcover and require ventilated cubicles etc.
The main concern is leakage...
I was always told to ensure that LPG cylinders are plugged as
well as turned off. (plastic bungs are ok but I still have some brass plugs from way back).
Kept out of direct sunlight and if possible, placed low for weight distribution.
By the way, I have seen an LPG cylinder put in a fire until it vented, no explosion, unless the pressure relief is damaged or blocked.
Lots of flames....
701977
Follow Up By: Member - Tony V (NSW) - Thursday, Sep 23, 2010 at 18:07
Opps that didn't work unluess you follow the link.
This one is more appropriate...
701978
Follow Up By: bdare - Friday, Sep 24, 2010 at 20:46
Thank you, Tony, for going to the effort of researching this for me.
702088
Reply By: cycadcenter - Thursday, Sep 23, 2010 at 23:53
I just got one of these for our use back at our house in California and love it. About 30% lighter than a steel one and you can see exactly how much gas you have and how full they fill it.
Composite Propane Cylinder
Also has the OPD Safety Valve so the tap can be turned on and no gas will escape until connected to an appliance.
Bruce
431272
Reply By: bdare - Friday, Sep 24, 2010 at 20:45
Wow, what an interesting coversation starter my question turned out to be! Thank you to everyone who provided me with good advice. I believe I will transport the cylinder's on the roof racks with ratchet straps rather then in the car and hope for the best!
431350
Reply By: Member - Graham H (QLD) - Friday, Sep 24, 2010 at 22:02
