Cannot loosen fuel filter help?
Submitted: Saturday, Sep 25, 2010 at 22:59
ThreadID: 81552 Views:3085 Replies:4 FollowUps:8
I have a 1998 prado 3.4 ltr petrol auto and cannot loosen nuts that secure to the petrol filter, maybe locktite was put on, someone know of way to loosen without stripping nut.Much thanks.
Reply By: Kimba10 - Saturday, Sep 25, 2010 at 23:28
I'm not sure the correct name of the tool but it is like a ring spanner with a slot cut out of it which allows the spanner to go over the fuel line and onto the nut, normally need two of them. They are normally done up that tight its ridiculous, BUT if you try and use a shifter or open ended spanner it will strip the edges of the nut and you guessed it you will need to buy a complete new fuel line so make sure you have the correct tool. They are available from most tool stores, not sure if you have a book on the vehicle to find the correct size of the nut but if you don't let me know I will get my old gregorys book from the roof and have a look for you, either that just slipping an open ended spanner on the nut will at least give you the right size spanner required. Regards Steve
AnswerID: 431422
Follow Up By: Member - MYPRADO - Sunday, Sep 26, 2010 at 01:03
Would appreciate any info as well as name of tool and size, have book on order still waiting.
Cheers Mario.
FollowupID: 702169
Follow Up By: Member - Mark G Gulmarrad - Sunday, Sep 26, 2010 at 08:25
MYPRADO
i think this is the tool Steve is talking about
Image Could Not Be Found
FollowupID: 702181
Follow Up By: Member - Mark G Gulmarrad - Sunday, Sep 26, 2010 at 08:27
it is called a Brake Pipe Spanner,cheers.
FollowupID: 702183
Follow Up By: Member - mazcan - Sunday, Sep 26, 2010 at 15:58
hi
to the best of my knowledge that spanner is called a
crows foot
FollowupID: 702247
Follow Up By: Member - Tony H (touring oz) - Sunday, Sep 26, 2010 at 23:36
Hi guys, As mark G says....it is a pipe spanner.
mazcan.... a crows foot spanner is basically an open ended spanner with a square hole just behind 'the jaws' to take the male end of a ratchet or breaker bar
FollowupID: 702338
Follow Up By: Member - Andrew (QLD) - Monday, Sep 27, 2010 at 06:25
Image shown above normally referred to a "flare nut spanner" if you need to find in a store ;)
Andrew
FollowupID: 702352
Reply By: Member - Bucky - Sunday, Sep 26, 2010 at 06:05
MTPRADO
Have you thought of putting a tight open ender spanner on the nut, and giving it a "crack", with a hammer ?
Are you actually loosetning it ?... are you turning the nut the right way.
Can you take the fuel line off from a different loaction.. ie further down the lines, and once removed, placing the filter in a vice ?
There are lots of ways to do the job..
When all else fails, take it back to the garege, that put it on, and get them to do it !
Bucky
AnswerID: 431431
Follow Up By: Kimba10 - Sunday, Sep 26, 2010 at 10:51
Hi Bucky, mate these nuts are so soft that if not the correct spanner will take all the edges off the nut, they seem to like tightening them up so tight that they are nearly impossible to crack the nut from the fuel filter. I wouldnt be using no hammer on it thats for sure, if out in the scrub and no other chioce then you do what you have to but when he probably has a spair parts shops within a 20k radius then I wouldnt risk damaging the nut. Regards Steve
FollowupID: 702197
Follow Up By: Member - Bucky - Sunday, Sep 26, 2010 at 14:52
Kimba
so does the cut and dump theory work with the high pressures of the modrn fuel injection motors..ie Common Rail ??
or
Am I barking up the wrong tree ?
FollowupID: 702231
Reply By: Member - Graham H (QLD) - Sunday, Sep 26, 2010 at 13:20
Had the same trouble with my sons Camry Couldnt get the nut undone.
Mangled the filter and the line
Ended up cutting the line and getting some connectors from Qld Hoses and fixing it that way. HAs been Ok for two years.
AnswerID: 431456
Reply By: Member - MYPRADO - Monday, Sep 27, 2010 at 00:40
Thanks guys the info is help full will buy spanners.
Cheers Mario.
AnswerID: 431539
