Difference between a DP chip and a DTronics chip?
Submitted: Sunday, Sep 26, 2010 at 08:20
ThreadID: 81557 Views:14804 Replies:4 FollowUps:6
Hi All,
Can somebody out there tell me the difference in performance etc, between a DP chip & a DTronics chip for a 3.0 ltr Nissan Patrol Please ?
Cheers P&J
Reply By: Bonz (Vic) - Sunday, Sep 26, 2010 at 08:44
As far as I can work out it works like this:
DP - P + Tronic = DTronic
The DTronic isnt adjustable, but the DP Chip is I have been told. I have a DTronic on my Patrol and found that a 3" exhaust made more improvement to the performance. But it all helps
AnswerID: 431439
Follow Up By: Member - Graham H (QLD) - Sunday, Sep 26, 2010 at 09:03
I agree I have a Dtronic in a 100TD and found that the 3" exhaust actually helped more than the chip.
Certainly wouldnt chip it without doing the exhaust.
Would seriously wonder about chipping a Grenade without doing the preventitive measures to stop it going bang.
More opportunity to overfuel it with the DP as you can wind it up hence perhaps creating more heat.
FollowupID: 702188
Follow Up By: Skippype - Sunday, Sep 26, 2010 at 09:16
That formula looks about right to me.................heheheheh
FollowupID: 702189
Follow Up By: Bonz (Vic) - Sunday, Sep 26, 2010 at 09:19
I have run the DTrocin for about 8 years and its still going only had the exhaust for the past two, it made a huge difference. The exhaust is a Taipan XP
FollowupID: 702190
Reply By: Member - Porl - Sunday, Sep 26, 2010 at 09:01
One of the 4WD mags did a comparo last month, should still be on the shevles, I'd scan and post but it's a bit early and I think they'd get cranky. 4WDMonthly I think.
AnswerID: 431440
Reply By: Chaz - Sunday, Sep 26, 2010 at 18:19
There should be very little difference in performance between the two. They both basically do the same thing, but in slightly different ways. The Dtronic alters the sensor signals to the ECU and the DP Chip alters the signals to the IP after the ECU. The issue now is that the Dtronic is no longer available, so the DP/Steinbauer etc are the only options. There were rumours of manufacturing quality issues with many Dtronics that didn’t work, which may have had something to do with it’s demise and why ARB have dropped them.
I’ve had a Dtronic in my ZD30 Patrol since day 1 and have had no issues. On the dyno, it does what the manufacturer states and for the record the Dtronic can be re-programmed, but needs to be returned to Safari to be done. Unfortunately there never was a Dtronic for the CRD, but the CRD DP Chip is now also a plug in affair.
AnswerID: 431492
Follow Up By: Member - Graham H (QLD) - Wednesday, Sep 29, 2010 at 17:14
Hmm very strange as I thought they could be programmed and rang them to get
one done and was told they were factory programmed to each model of motor and
NO they cant be redone for individual engines.
So what do you know that I dont seeing my answer came from the Aussie distributor.
FollowupID: 702568
Follow Up By: Chaz - Wednesday, Sep 29, 2010 at 19:01
Hi Graham,
I read a report in one of the popular 4WD magazines back in 2003 (I think) when I was looking to buy a performance chip for my ZD30 Patrol. It was a promotional report by Safari and consisted of dyno testing a ZD30 Patrol before and after fitting the Dtronic, but the vehicle in question had a 3” sports exhaust fitted to it, so the Dtronic was sent back to Safari for reprogramming as it was said that it would be benificial to do so after further modifications to the car and it would be advisable if fitting larger free flowing exhaust. It mentioned that only Safari could do the reprogramming, so it may be the case that the Aussie Distributor may not even know about it. To my knowledge, ARB were the Aussie distributors and no longer sell any performance chips. My Dtronic has a 4pin socket on it that isn’t used and I suspect that this may be the programming port. It's most likely just a case of having the cable and software, but Safari would probably never release it.
Chaz
FollowupID: 702578
Follow Up By: Member - Graham H (QLD) - Wednesday, Sep 29, 2010 at 21:36
I rang the Safari people not ARB and asked about that set of pins and was told no they couldnt do it. I was also told that the 3" exhaust should be fitted as well as the chip as it was tuned for it.
So I di and it went from 145 to 165 at the wheels
FollowupID: 702600
Reply By: PandJ - Wednesday, Sep 29, 2010 at 16:22
Hi to all,
Thank you for all the replies, will fit the DTronics then the exhaust once the original is buggered. Cheers P&J
AnswerID: 431726
