need some help or advise
Submitted: Monday, Sep 27, 2010 at 20:51
panama2008
hi all need some help or advise, i have a 1990 22r 4runner that im converting to a V6. im at the stage of putting in the engine but found out that the engine mounts are out by 2inches, was wondering if there is a bracket to mount the new engine so that i dont have to cut and weld the mounts on the chassy any help or advise will be very apriciated. I can be contacted on my email evansmainar@hotmail.com or txt on my mobile 0414459422
Reply By: 3.0turbob - Tuesday, Sep 28, 2010 at 09:42
Try marks4wd.com
they may be able to help
431637
Follow Up By: baldman - Tuesday, Sep 28, 2010 at 17:43
Try this site, it has sections on transplants and other mods, personally if your going the GMH V6, you should consider a Lexus 1UZ transplant, heaps more grunt and about the same cost, plus it keeps the runne all toyo
http://www.toyotasurf.asn.au/forum/
702510
Reply By: panama2008 - Tuesday, Sep 28, 2010 at 19:25
sorry i should have stated a petrol 4runner and am putting in an 3VZE 3L enginge
431679
Follow Up By: baldman - Tuesday, Sep 28, 2010 at 20:56
word of advice, the 3vze is a thirsty underpowered motor,
Mine still runs the 3vze and I am honestly waiting for it to die so I can put a 1uz or a prado engine in there
Secondly trying to find a good 2nd hand 3vze with the complete wiring harness and and all the other bits and pieces (ecu, air box, radiator, and the rest)is going to be really hard, plus the fact it probably wont marry up to your gearbox.
702524
Follow Up By: baldman - Tuesday, Sep 28, 2010 at 20:58
just another challenge, as most 3vze engines are between 15 - 19 years old most of the ecu's that are aound will have to be rebuilt as
702526
Follow Up By: panama2008 - Tuesday, Sep 28, 2010 at 23:34
have everthing i need to finish project from a parts donator sr5 v6 limited including cruise control and also lpg from my original 4runner, the only problem is the engine mounts r at least 2 inches out
702541
Follow Up By: baldman - Wednesday, Sep 29, 2010 at 13:52
As far a sI know there is no enginr mount kit to do what you want to do, you will have to gut and reweld the new engine blocks to your chasiss and then get it engineered.
702565
Reply By: Member - Tour Boy ( Bundy QLD) - Wednesday, Sep 29, 2010 at 08:17
Can you swap your body onto the SR5? rather than swapping the running gear.
431702
