Level System with Chock
Submitted: Tuesday, Sep 28, 2010 at 14:16
ThreadID: 81599 Views:2996 Replies:3 FollowUps:4
Have just bought a Fiamma set of ramps and chocks which look very sturdy. However the top notch on the ramp is near the back edge and if you put the chock on it ,it doesn't appear that there is room for the wheel.
Has anyone had experience with these?
Reply By: Member - Graham H (QLD) - Tuesday, Sep 28, 2010 at 15:42
yes and never had any trouble with them Usually you dont have to get the van that high anyway. Just shift it a bit to get a better site.
We normally only use the smaller straight ones and rarely use the three level ones.
Also if you have a tandem axle van it pays to chock BOTH axles as one isnt deigned to hold that amount of weight.
We just back it up till its level and whack the chock as close as possible.
Sometimes have to back up a bit more and let it run down on it after putting it in the slot. Its not an exact science really
AnswerID: 431661
Reply By: Nomadic Navara - Tuesday, Sep 28, 2010 at 17:17
If you are referring to this one, you only need a chock on the lower side of the wheel. The ramp has its own built chock on the upper side, if you don't think it is enough then chock the wheel on the other side of the van.
AnswerID: 431675
Reply By: Wizard1 - Wednesday, Sep 29, 2010 at 07:14
Been using this really simple and inexpensive levelling system for years with great success.
Just get a piece of treated pine offc ut 250mm x 40mm x 600mm
No fiddly bits just make sure you get the wheel centered on the board and it is a no brainer. If you need more height wack another on top!
AnswerID: 431698
Follow Up By: Ray - Wednesday, Sep 29, 2010 at 08:25
Same here
FollowupID: 702550
Follow Up By: Fred G NSW - Wednesday, Sep 29, 2010 at 10:00
SAME HERE # 3. It's also a hell of a lot cheaper. Can pick up offcuts from most builders sites, if ya ask nicely.
Fred
FollowupID: 702551
Follow Up By: Member - Graham H (QLD) - Wednesday, Sep 29, 2010 at 12:22
It appears the poster has bought them and wants advice on using them and not asking for. alternatives.
FollowupID: 702559
Follow Up By: Fred G NSW - Wednesday, Sep 29, 2010 at 13:51
He can always take our advice, and get his hard earned refunded, Graham :-)))
FollowupID: 702564
