Trail a Mate Jack
Submitted: Wednesday, Sep 29, 2010 at 00:12
ThreadID: 81605 Views:7511 Replies:4 FollowUps:1
Arriving in Perth tomorrow after 4 mnths on the road.wondering if anyone knows where I could get my trail a mate serviced/repaired. this is my second one that has continually failed me when travelling but for some reason I persist because it is much easier to pump than wind for us 2 old ladies !! ( this time though I brought a spare Jockey wheel) I have topped up the oil twice on this trip. first time worked, 2nd time no go, it won't pump up! The previous one failed four times and had seals replaced twice. This one is on its first trip. any help would be appreciated.
Cheers Mac
Reply By: Member - Graham H (QLD) - Wednesday, Sep 29, 2010 at 07:24
You can buy a seal kit off them which I did and it wasnt a success.
The guy who does them is in Adelaide and when I got there I took mine to him.
He put in a whole new piston and seals and put it under 1300kg of pressure for 15 mins. It held OK and has been good since.
main thing is keep them dry I have a long skinny plastic bottle I put over mine and it is OK now.
Mostly they blow seals if you overload them or let the plunger shaft get wet and it gets pits in it and destroys the seals as you pump it up and down.
Thats what the man told me.
I suggest you buy a new piston and assembly as I did and just screw it on.
Cost me $60
Also use the correct oil which I think called 32
Will look in van and repost later
AnswerID: 431699
Follow Up By: Member - Graham H (QLD) - Wednesday, Sep 29, 2010 at 12:31
I bled mine about 5 times after getting seals done and it still leaked.
The correct oil is Gulf Western Hydraulic Jack Oil Part no 30194
Viscosity 32
Look at the piston as you pull the handle up If its rough and rusted seals wont fix it.
FollowupID: 702561
Reply By: Navigator 1 (NSW) - Wednesday, Sep 29, 2010 at 09:03
Hi Outback Mac C,
Met a mobile caravan service/repair guy in a Freemantle CP the other day who may be able to help you - 0423086978.
Rob
The outback calls
AnswerID: 431704
Reply By: new boy - Thursday, Sep 30, 2010 at 08:01
Interesting read I also am cuttently doing a 12 mths lap and had 2 guys tell me they are the best thing since sliced bread.
Question is are they appears to be a bit of a failure rate and at $300 I think I will stick to my jockey wheel. Warrant 4 failures in 4 months plus new seals is there ANY????
AnswerID: 431801
Reply By: seejay - Thursday, Sep 30, 2010 at 21:01
Have had no problems at all with our jack. Had it at least three years. It is the best piece of equipment - so much easier. Would recommend to anyone.
AnswerID: 431849
