Question on Road/Tyre noise!!!
Submitted: Wednesday, Sep 29, 2010 at 18:37
Glenn76
Hi all, Im chasing a weird throbbing/rumbling noise, sounds similar to driving on a corrugated road but not as bad, but Im on bitumen. This noise gets worse between 90 to 100kmh and then fades out again. This does happens with 2 sets of mud tyres. I know its not the tread noise as that makes a different and more like a humming noise.
Question is can Mud tyres have this type of noise zone in at these speeds and then disappear. Also does any one else have this noise?
Its just annoying because i like to sit at 95kmh on the hwy, dead smack at its noisiest.
Reply By: Nutta - Wednesday, Sep 29, 2010 at 18:51
I've had muddies on and they're noisy at any speed.
Before you go to to much trouble i'd be borrowing someone elses
wheels for a run first.
431747
Reply By: Hairs & Fysh - Wednesday, Sep 29, 2010 at 19:09
Not a Uni on either the front or rear drive shaft that's packed it in?
431750
Reply By: QLD Blake - Wednesday, Sep 29, 2010 at 19:25
Just had the same problem, ended up being my front passenger wheel bearing
431754
Reply By: Member - Jeff P (SA) - Wednesday, Sep 29, 2010 at 20:34
Sounds like a wheel bearing or UV joint to me
431771
Reply By: Member - Tony V (NSW) - Wednesday, Sep 29, 2010 at 22:12
Glenn,
Check the other suggestions but..
It can be the wear on the tread block, the lead edge wears quicker that the trailing edge. (feathering) You can measure this is you want
A qucik what to check is to swap the tyres on the same axle over so you effectively reverse the block angle and see if that changes the resonance.
Good luck
431783
Follow Up By: Member - Tony V (NSW) - Wednesday, Sep 29, 2010 at 22:14
Fat fingers....
should read
702603
Follow Up By: Member - Tony V (NSW) - Wednesday, Sep 29, 2010 at 22:15
Lets try that again...
A quick way to check
702604
Reply By: Glenn76 - Thursday, Sep 30, 2010 at 19:06
Ta guys Ive ruled out the unis and wheel bearings thats why i was wondering if tyres can make a similar noise. yes I get the humm from tread of the mud tyre which is normal but its a deeper throbbing/rumbling noise that plays with my ears Im getting as
431840
