Sunday, Oct 03, 2010 at 18:54
Not sure of your local dealer is a Goodyear outlet or something else. If it's a Goodyear one then he had better get his product knowledge up to speed in my book. If it's someone selling tyres always consider a second opinion.
Having had the opportunity to back to back test the old MTr against the new one using the same vehicels I can assure you they are a noticeable improvement in grip and steering response but I reckon the old one wasn't that bad anyway
On wet bitumen then grip less than a D694 by a lot but that is not a criticism of the tyre as anything with such an open tread will always be the same. Simple answer is to drive to the conditions.
I have investigated plenty of issues with fleet vehicles and most generally the issue results from
the nut or nuts behind the wheel. All care and little accountability in many instances so the vehicle gets flogged. Something they hardly ever do to their own vehicle.
Given the strength and load carrying capicity of this tyre we have found we can run considerably lower pressures all round. For example our Prado runs them at 32 PSI for normal use and 30 is fine as
well. Loaded we to go 34 and 36 if not towing and if we put the XTrak on the back we go up to 38. The car weighs 2950 kgs for a tour
Sand we have been down as low as 14 with no problems and 12 in the trailer. In rocky terrain we are using 24 rather than 26 with noticeably improvements in comfort and grip
RobA
702859
