Cleaning fuel tanks
Submitted: Sunday, Oct 03, 2010 at 19:24
ThreadID: 81704 Views:2729 Replies:6 FollowUps:6
Had some problems with fuel sucked up from the bottom of the tanks (so series LC). I reckon I need to clean the tanks out fully. Are there any quick and easy ways to do this, or do the tanks have to be taken out?
Reply By: Member - Oldplodder (QLD) - Sunday, Oct 03, 2010 at 21:33
Had a simiilar problem.
Ran the tank down to about 20 litres and removed the bottom bung/drain point.
Poured diesel through a few times straining it each time.
Got the worst out.
Later installed a 2nd fuel filter and lift pump and change filter on a regular basis.
John C
AnswerID: 432059
Follow Up By: Member - Mfewster(SA) - Monday, Oct 04, 2010 at 20:34
Ta John C. This is probably a dumb question, but what's an uplift pump? I have the main tank plus a reserve. When I switch to the reserve tank (via a solenoid switch), I believe the same fuel pump operates. An interesting aspect of my problem is that I was running on the main tank and noticed that the fuel level wasn't dropping. Turns out that fuel was being sucked from reserve tank into the main tank. When the reserve tank was absolutely dry, my problems started.
FollowupID: 702934
Follow Up By: Member - Oldplodder (QLD) - Monday, Oct 04, 2010 at 21:26
I get dirty fuel about every 2nd trip.
Some people have problems with tyres, I have problems with fuel. :o)
I only have the one 135l tank, and the mechanical fuel injection pump on the engine has a small low pressure lift pump, and there is the one fuel filter in the system. When I put in the 2nd filter near the tank the lift pump had problems getting enough fuel and I couldn't get full power.
So I put in a electric fuel pump near the tank to act as a lift pump to help lift the fuel to the engine. It will run without it, but I don't get full power due to fuel starvation.
That 2nd filter is on the side of the chassis rail nice and easy to get y\to, but up out of the way. It is a landcruiser filter and the replacement costs about $9.00 ea,. I take a few on a trip and it is only a 5 minute job to replace it if I feel the power drop off due to dirt building up.
Wish you luck.
regards
John C
FollowupID: 702937
Follow Up By: Member - Bucky - Tuesday, Oct 05, 2010 at 03:18
Mfewster
Must use both tanks. all the time !
no question about it !
Bucky
FollowupID: 702947
Follow Up By: Member - Mfewster(SA) - Tuesday, Oct 05, 2010 at 08:34
Hello Bucky. I don't understand how my main/auxilliary tank are connected, but I don't think they are both on line all the time (Well, I don't think they have been in the past). Previously I have been able to choose either tank with the solenoid switch and the chosen tank would drop in level as i drove while the other reamined full. If I wasn't paying attenion and ran a tank out, I needed to swap to the new tank and prime the pump before I could run again. This seems to show that they ran independently. Last week, I was running on the main tank and it definitely kept filling itself up from the aux tank which ran completely dry, which is when my problems started.
Suggestions from anyone as to what is happening welcomed.
FollowupID: 702956
Reply By: Member - Longtooth (SA) - Sunday, Oct 03, 2010 at 22:07
Is there any secret to draining both 2000 GU Patrol diesel tanks?
Longtooth
AnswerID: 432062
Reply By: Member - Bucky - Monday, Oct 04, 2010 at 06:17
Bite the bullet mate !
A weekend job.
Do it once, do it properly.
Bucky
AnswerID: 432072
Follow Up By: Hairs & Fysh - Monday, Oct 04, 2010 at 18:44
Agree mate.
Why muck about trying to save only a couple of bucks.
Either pay someone to do it for you, or get dirty and do it yourself.
FollowupID: 702926
Follow Up By: Member - Oldplodder (QLD) - Tuesday, Oct 05, 2010 at 08:37
Agree with hairs and bucky.
Best solution is to pull the tank out to clean it.
But a quick clean pouring fuel through gets the worst out.
When at home and you can run the tank down to only 10 litres or so left, not such a big job. About an hours work to get it out or put it in, now I know where to put the jack and where the fuel hoses connect.
Usually give it a repaint at the same time to cover the scratches. My after market tank is now 17 years old and been out a couple of times. I put the standard tank in while I do up the replacement tank.
FollowupID: 702957
Reply By: Member - Christopher P (NSW) - Monday, Oct 04, 2010 at 19:53
Hi guys, yeah had a bad batch of fuel in my laser, and finally replacedthe filter two days ago, thing runs like a two bob watch, for us youngin's thats 20 cents
worth.LOL
Another tip too is to check your crankshaft sensor for iron filings, which can be picked up off the road!!!!
easiest way is to use a cheap old speaker, from a old surround sound, not too big. but big enough to remove iron filings without causeing a reverse polarity on the css.
works a treat.
AnswerID: 432119
Reply By: Member - Mfewster(SA) - Monday, Oct 04, 2010 at 20:30
Thank you one and all. Some dirty hands coming up.
AnswerID: 432125
Reply By: Member - Mfewster(SA) - Tuesday, Oct 05, 2010 at 15:53
Biting the bullet. Draining tanks, then disconnecting the aux tank and putting in new line from it to the main tank. New line will have a filter and a pump so I transfer fuel from the Aux tank to the main tank.
Thanks everyone for the help.
AnswerID: 432166
