coleman Hot water unit
Submitted: Monday, Oct 04, 2010 at 11:36
ThreadID: 81712 Views:5634 Replies:7 FollowUps:13
Hey guys just wondering if anyone can shed any light on battery issues on the coleman hot water unit. I've only used it twice and on each occassion the battery has not lasted very long at all. Whilst I do need to have a second battery for changeover on the latest trip the battery lasted 1 night with 6 people having quick showers. I've yet to speak with coleman themselves but was wondering if anyone else has had problems?? I charged the unit for a full week prior to going away.
Reply By: Battery Value Pty Ltd - Monday, Oct 04, 2010 at 13:41
Mate, what do you expect from a battery? miracles?
Look, your average 100Ah battery is good for 3600kWs of energy storage.
Take an inlet water temperature of 23, and outlet of 38 degrees, a differential of 15 degrees. To heat one litre up by one degree you need about 4kWs.
Doing a back of the envelope calculation reveals you can heat up 60 litres of water by 15 degrees.
Divide this by 6 people and everyone gets his/her share of 10 litres of warm shower water.
cheers, Peter
AnswerID: 432090
Follow Up By: GT Cruiser 80 series - Monday, Oct 04, 2010 at 13:55
Nah mate not looking for miracles Id just thought the battery may last longer then 1 evening!! Do they expect you to take a new battery for each night your away to keep it running?? Thanks for your info though.
FollowupID: 702894
Follow Up By: Member - Andrew (QLD) - Monday, Oct 04, 2010 at 14:18
The battery is only used to fire the unit and pump some water, not heat.....gas does all the hot work ;)
Andrew
FollowupID: 702896
Follow Up By: Battery Value Pty Ltd - Monday, Oct 04, 2010 at 14:34
thanks guys,
I knew there'd be more to it :)
I remember vaguely looking at a similar unit once and was wondering how on earth a small battery can be expected to provide a fair amount of hot water.
Minutes later I read something about LPG....
Seriously, if the pump battery only lasts for 6 brief showers it's either a very small unit or it's defective in some way.
Or, the battery charger doesn't do the right thing.
If the battery's fully charged, a voltmeter connected to it should read 12.9 or more Volts.
If you can, check for an Ah rating printed on the battery, or you could take some LxWxH measurements from which the Ah rating can be estimated.
If the pump motor has an amp rating, what is it? Shouldn't be more than 3~5 as a rough guesstimate.
Let us know.
cheers, Peter
FollowupID: 702897
Follow Up By: Member - Andrew (QLD) - Monday, Oct 04, 2010 at 14:39
Peter,
It's only a 6v job, (3Ah from memory), that is heavily abused in its discharging and recharging regime. LOL
Andrew
FollowupID: 702898
Follow Up By: Member - Andrew (QLD) - Monday, Oct 04, 2010 at 14:50
Just another thought.....could the battery be cooked from the excessively long charge? I don't recall there being a cutoff on the charging side but may be wrong. See here for some details of the charging specs:
http://www.exploroz.com/Forum/Topic/78014/Coleman_HWOD_charging_voltage.aspx
Andrew
FollowupID: 702899
Follow Up By: Battery Value Pty Ltd - Monday, Oct 04, 2010 at 14:59
...a 6 Volt jobby!
gosh I give up :P)
FollowupID: 702901
Reply By: DirtDevil - Monday, Oct 04, 2010 at 14:24
Hi GT Cruiser,
I have a Coleman unit (gas heating). The last trip I did the unit did approximately 25 showers before recharging. Shower were kept to about 4 minutes at most. Our method was to wet ones self down, turn unit off, soap up then turn unit on and wash off. We also needed to conserve water so kept the showering as quick as possible. Hope this helps.
Mike
Evil will always triumph when the good do nothing.
AnswerID: 432096
Reply By: Member - Andrew (QLD) - Monday, Oct 04, 2010 at 14:37
Define quick showers? LOL
In high usage situations it may be better to use the HWOD unit to heat the water in a bucket, then use a cheap shower unit like as shown in the following thread (reply 2 of 5) to do the showering:
- http://www.exploroz.com/Forum/Topic/68788/Coleman_Hot_water_on_Demand.aspx
The batteries are a smallish capacity 6v one, probably designed to last 30 minutes continous at most or even one gas bottle worth as a guess. Intermittant use may be better for the battery rather than 6 x couple minutes continous as a guess. Other factors may affect the life of the battery, including the suction and head heights. I tend to run ours with the bucket/plastic container at the same height as the unit, with the unit placed as high as practical to achieve minimal head.
Would be interested in what Coleman have to say about your situation.
Hope that helps,
Andrew
Andrew
AnswerID: 432098
Follow Up By: Member - Andrew (QLD) - Monday, Oct 04, 2010 at 14:58
Just read an online manual (page 3) that mentioned a 40 minute run time.... http://www.coleman.com/coleman/images/pdf/2300-700.pdf
The continous drain on the small 4Ahr battery and a max flow of 150 litres may be enough to make the battery dead in 1 night given the wrong conditions. ;)
Hope that helps,
Andrew
FollowupID: 702900
Follow Up By: GT Cruiser 80 series - Monday, Oct 04, 2010 at 15:01
ALL,
Thanks for the responses this morning. I've just now sent an enquiry through to Coleman to ask their thoughts. I'll keep everyone posted. Andrew I'd hoped to use the unit as per your post above and not use it as an actual shower. This would have been fine except the small 12V BCF shower had stoped working again and I couldnt use it. Never seem to have too much luck with these either...not sure about anyone else. I think it would be better to make a small one using a small good quality 12v pump with a low amp draw.
Thanks.
FollowupID: 702902
Follow Up By: Member - Andrew (QLD) - Monday, Oct 04, 2010 at 15:09
I agree GT, might be worth the extra dollars to buy a quality Whale or Rhule bilge pump and attach the showerhead.
Strangely enough i've had my original battery in the HWOD for around 6 years, hardly ever charge it, and it seems to work for several days when camping.....go figure ;)
Andrew
FollowupID: 702904
Follow Up By: GT Cruiser 80 series - Monday, Oct 04, 2010 at 15:20
Andrew,
Yeh strange. Another mate of my mine has one he hasnt any problems either as far as I'm aware. He does carry a spare battery though so he may change it over at some point. One thing that does worry me though after reading the post with the link to charging is it possible to have been supplied an incorrect charger given that its only a 6volt battery. I remember the day I bought it the charger wasnt in the unit but the staff went out the back and found one to suit. If as it says in the post there are different charges needed even though they look the same it could be the wrong one. Just a thought??? Is there a way to check?
By the way I would'nt have heated anywhere near 150 litres of water on the last trip. Id say 40 - 50 absolute maximum.
Thanks.
Grant
FollowupID: 702905
Follow Up By: Member - Andrew (QLD) - Monday, Oct 04, 2010 at 15:26
I guess there may be several chargers over the years, based on their bulk buying availability at the time. Could be the wrong one, does your match any of the details in the other thread? What does it say on the black box?
Andrew
FollowupID: 702906
Reply By: OREJAP - Monday, Oct 04, 2010 at 16:20
I had a similar problem with our Coleman & s/t a Coleman Tech who said to charge the battery for 24 hrs prior to going away & rechargeables must be recharged every 3 mths. I pump the water required through the Coleman or heat up water by the fire. Once water is to my liking I use a $29.95 Yellow shower which runs off 12v. The shower unit comes equiped with cigarette (male) connector & aligator clamps onto car battery. The shower unit has an off/on switch & you can see how much water you have actually used because the shower motor is in the bucket next to you. The only problem I have ever had with this unit in 6 years (Chinese made) was the impellor got stuck with a bit of dirt. Easy to clean and a spray of WD-40 & away it goes. Buy a second battery from battery world & keep both charged.
AnswerID: 432103
Follow Up By: Member - Christopher P (NSW) - Monday, Oct 04, 2010 at 17:52
Hi All , i went to bunnings and bought a big yellow tub about 600 x 8oox 125mm, from the stroage isle, then got a bcf shower, running thru a cheap jumpstart pack with a new battery in it, heat the water up roughly 3L and 5- 6 cold water, by the third person you heat up another 1 litre of water and that does four people. total useof 10 litres of water or less.
oh by the way i have modified my bcf shower by taking the rose apart and in creasing the size of the holes/ pores of said head, good for in sandy conditions.
because water is recirculated by the yellow tub. i also use said water to douse any fires for the night.
FollowupID: 702921
Reply By: Flynnie - Monday, Oct 04, 2010 at 19:30
I took my second Coleman unit on the Canning this year. It was a borderline decision as the first one had failed last year. It worked well throughout. It handled two showers of about 20 litres one after the other with no fuss. Used it most days. The Coleman was plugged into one of my auxiliary 12 volt sockets during the day so it was always at a full charge come late afternoon or evening when used for showers.
The battery should handle six short showers. It might be expecting too much to handle six 20 litre showers. I doubt an incorrect power supply is a contributing factor. I see no reason for a second battery at all. One is good enough.
My Coleman is rather temperature sensitive. If operated below an ambient temperature of about 10 degrees Celsius it displays a "low battery" light. Warm it up to 12 degrees and it functions OK. For showering I can live with this limitation but it makes the unit unreliable as a source of hot water for washing up etc. I don't know if mine is faulty or this 10 degree thing is common to them all.
As your showers were in the evening could the temperature have been dropping below 10? If so that might be the problem.
With the Coleman it is not really necessary to preheat a bucket of water. Adjusting the temperature during a shower is a bit difficult so better to make sure the adjustment is right in the first place before showering.
Flynnie
AnswerID: 432115
Reply By: Duncanm - Monday, Oct 04, 2010 at 22:08
My coleman will do 4 showers each night for 2 or even 3 nights without a charge. I have not had any battery issues. I would estimate the volume at approx 40 to 50 litres per night. Hope this helps.
AnswerID: 432133
Reply By: Member - Ian F (WA) - Tuesday, Oct 05, 2010 at 09:38
Just on a different line is it possible to change the shower head to a switch on/off type or will this damage the the unit due to no water flow?
Ian
AnswerID: 432151
Follow Up By: GT Cruiser 80 series - Tuesday, Oct 05, 2010 at 09:44
Thanks Duncan thanks Flynnie.
Hadnt though of the temperature Flynnie, however the temp wouldnt have been below 10 degrees. Probaly would have been 15 - 20.....I guess.
Ian I'm pretty sure if the flow is turned off then the heating function will cut out and I guess could also damage the unit. I think its all realted to the water constantly flowing and the pilot light using the gas/fuel to heat the water to the required temp.
Thanks again guys.
FollowupID: 702962
