96 troop carrier seats?
Submitted: Wednesday, Oct 06, 2010 at 14:50
Rhooka
hello there
i have just got a 96 troopy only thing is its only got the 3 seats at the front. my thinking is getting the back seats from a wreckers some where and putting them in.
but i have been told that some times its not that simple and it can be hard to get them to pass road worthy?
has any one done this before and care to shed some light on the subject for me
thanks in advance
Matt
Reply By: garrycol - Wednesday, Oct 06, 2010 at 15:34
Check the compliance plate to see the seating capacity - it may have had seats when complianced and had them removed later. If the plate has the higher capacity then you can put the original seats back in - if not you will have to get the seats engineered.
Garry
432243
Reply By: Ozhumvee - Wednesday, Oct 06, 2010 at 16:17
Depending where you live and how many seats you fit will also influence rego cost and here in NSW if you go up to the full eleven seats you will need twice yearly over the RTA pit inspections.
Fitting the rear seats to a 3 door troopy can be pretty expensive as none of the original mou8nting points for seats and belts are fitted to a 3 seater. if it was originally sold as a 11 seater/bus or a six seater with the forward facing rear
seat then you can just bolt the correct seats in and change it with registering authorities.
If not originally fitted then full engineering for
aftermarket seats has to be done.
432248
Follow Up By: get outmore - Thursday, Oct 07, 2010 at 03:05
we just got one as a work vehicle, 5 seats in the back, absalute pearlers, bust seats ive sat in as
well as a side door
it has a mddified vehicle compliance plate
hate to think what it was worth my guess is around 20k but I have nothing to base it on
703092
Reply By: Member - Andrew H ( - Wednesday, Oct 06, 2010 at 18:49
Hi Matt ,
have a look in the back and see if there are any bolt holes for the seats and belts as the seats may have been removed at some stage, if there is just bolt the another set in.
Depending on what state your in you mave have to check your reg papers and get the seating capacity altered.
If it has no
seat mount and belt holes everything will have to be certified by an engineer.
Andy
432258
Reply By: Rock Ape - Wednesday, Oct 06, 2010 at 19:19
Matt,
I had to have
mine engineered and certified.
I built the base for the seats and installed the seats and belts on my Troopy.
It was a plated 3 seater and I had to drill and reinforce all the anchor points.
Under the floor they were 150mm long 10mm thick and shaped to fit the grooves under the floor, I then taped the bolt holes, placing the reinforcing in the pillars was done by welding a stick onto the plate and feeding it up the pillar between the windows. All bolts were grade 8.8
I am at work at the moment and arn't logged in as a member but if you leave an email address in this thread, I will send some photo's and more info when I get home in about a week +.
Have a good one.
432261
Follow Up By: Rhooka - Wednesday, Oct 06, 2010 at 22:01
thanks that would be great
email is cassierhook@bigpond.com
703079
Follow Up By: Rock Ape - Thursday, Oct 07, 2010 at 07:00
Ok, will do in about 10 days time
703095
