Mounted panels on Van Roof
Submitted: Thursday, Oct 07, 2010 at 14:00
sandk33
About to mount the panels on the van roof ...when getting the stuff ready in my mind that I would mount the brackets onto some 6mm nylon I have, to allow for ventilation ...oops thinking on, is it a good thing, will the air pressure while mobile build up and maybe damage panels themselves.
So what is the general rule hard down or as I thought I would do.
Thank you Kevin
Reply By: Member - Phil B (WA) - Thursday, Oct 07, 2010 at 16:04
Hi Kevin,
By panels I presume you mean solar. From my point a view ventialtion is a good thing. Years ago a mate siliconed his panel;s onto the roof, got condetion under neath and then corrosion of wires in terminal box. Also putting them on nylon blocks with allw fr abit of flex as wqell, another good thing.
432331
Reply By: Member - Phil B (WA) - Thursday, Oct 07, 2010 at 16:06
Oops clicked submit and not spell check - sorry.
Hi Kevin,
By panels I presume you mean solar. From my point a view ventilation is a good thing.
Years ago a mate silicon-ed his panels onto the roof, got condensation under neath and then corrosion of wires in terminal box.
Also putting them on nylon blocks with allow for a bit of flex as
well, another good thing.
432332
Reply By: Member - John and Val - Thursday, Oct 07, 2010 at 17:37
Kevin,
Suggest allow for a bit of air circulation underneath to allow cooling. (The panels performance drops off at high temperatures.) I can't see pressure buildup being an issue unless you create some kind of air scoop at the front. There'll be a small pressure deficit on top due to air flow, but nothing worse than naturally occuring wind could generate.
| J and V
- Albert Einstein
432341
Reply By: Member - Boobook - Thursday, Oct 07, 2010 at 18:27
Mainey has a very nice panel mount set up.
you can search any solar thread and find him.
Click on his profile, he has ( or had) some pics there.
432347
