PowerSaver - Smart Battery Charger, fitting a second barrery.
I am about to fit a second battery to the system in the Caravan.
Does anyone have information that might help, no info in the manual (only shows single battery set up). Cheers, Maca.
Reply By: Stu-e - Sunday, Oct 10, 2010 at 23:47
hi Maca
its not a very big job, if your fitting it in the same compartment right next to the origonal battery simply hook it up in paralell (pos to pos, neg to neg) however if its a bit further away and you need significant wiring you may have to use fuses as well
stu
AnswerID: 432663
Reply By: Member - Carl- Monday, Oct 11, 2010 at 06:52
Supercheap have the battery cables already made up as well as jaycar. If you are fitting a AGM battery the terminals are different.
AnswerID: 432667
Reply By: Maca's - Monday, Oct 11, 2010 at 08:42
thanks for the info., just what i needed! I wasn't sure if it should be fitted direct to the existing battery or to the charger. Cheers Maca.
AnswerID: 432674
Follow Up By: Evakool - Wednesday, Oct 13, 2010 at 17:24
I will no doubt be corrected if wrong, but you can connect a 2nd battery to the first battery and it just acts like a larger battery.
ie, if you connect 2 * 100 amp batteries together it acts like 1 200 amp battery, it will take twice as long to charge but last twice as long.
Note that it is normally recommended to use batteries of the same age, type, brand and capacity.
FollowupID: 703647
