Has anyone tried these electronic ignition kits for a GQ Patrol
Submitted: Monday, Oct 11, 2010 at 10:08
ThreadID: 81844 Views:15031 Replies:5 FollowUps:3
hi, we are looking at putting electronic ignition on our GQ 4.2 lpg/petrol carby and noticed these on Ebay ELECTRONIC IGNITION Pertronix Nissan Patrol GQ TB42 Item number: 300455186529 and we are unsure how good they are, so can anyone comment on them as we have looked into getting a new one and are looking at around just under $500 for just the part.
thanks from chris.
Reply By: Ray - Monday, Oct 11, 2010 at 10:59
I converted a 186 (red) Holden with electronic ignition years ago. The kit that I used was called Luminition. It worked great. Never did ignition timing again. I don't know if they are still available. They had various types for different distributers and worked on a 'magic eye" princable and did not have any ignition points.
AnswerID: 432682
Follow Up By: Allan B, Sunshine Coast, - Monday, Oct 11, 2010 at 17:39
I put a "Lumenition" kit into a Cortina way back in 1977 (blimey, that's 33 years ago!) in order to improve performance and reduce maintenance.
It added about 10kph to the maximum speed in 3rd by presumably eliminating "points bounce" which was just what I wanted to assist with highway overtaking. (Mind you, valve bounce cut in at that point!)
It also totally eliminated points adjustment which is largely due to the "rubbing-block" wearing down on the cam and progressively closing the points gap setting.
In short, I was very satisfied and pleased to see that they are still available. (The Lumenition, not the flamin' Cortina!)
FollowupID: 703478
Reply By: garrycol - Monday, Oct 11, 2010 at 12:11
Pertronix certainly have a good name as cost effective electronic ignition for various vehicles. Not sure how well they work on Nissan's though.
I would have thought $500 is a but expensive though - kits for a carby V8 Rover were less than 100 pounds a little while back.
Before buying I would do a google and see what comes up - may be much cheaper from overseas.
Garry
AnswerID: 432685
Reply By: Member - Rob S (NSW) - Monday, Oct 11, 2010 at 18:37
Your best to have a look at the patrol forum i was looking at the petronix for my sons tb42 and there is a lot of info there if you do a little searching.
Site Link
I ended up getting a pirahna ignition second hand on ebay
Site Link
And that worked very good .A little more to set up but simple.
Petronix are distributed in Aus buy proquip and very helpfull .Site Link
And get an extended rotor button, will improve the spark, as the gap in the dizzy to the rotor is too big, you can get a new rotor $90 or $40 exchange from performance ignition will make a lot of difference on lpg. http://www.performanceignition.com.au/who-we-are
If you call them they will know what you want, i had one the next day Melb to Syd
The electronic ignition was a vast improvment on lpg over the standard points
Rob.
I only ever made one mistake
AnswerID: 432726
Follow Up By: Member - Rob S (NSW) - Monday, Oct 11, 2010 at 19:47
Not sure what your paying $500 for.
But on ebay they are $189 from patrolapart.Site Link
I have also bought parts from them direct not through ebay and found them very good for parts.just phone them direct if you don't like ebay.
And as for the pertronix haven't heard of any problems.
FollowupID: 703491
Follow Up By: Member - Rob S (NSW) - Monday, Oct 11, 2010 at 19:51
I should have read the patrolapart piece on ebay first. i copied this below.
NEVER CHANGE POINTS AGAIN !!!!
For sale - new Pertronix Ignitor Electronic Ignition conversion to suit Nissan Patrol and Ford Maverick GQ with TB 42 Carby engines, with points type ignition.
***Please note Ad is for original Hall Effect module We can supply Lobe sensing at the same price but are reluctant to do so***
We have 3 Years of experience selling these units and have decided to offer only the Hall effect unit for sale.
Last year we had many Lobe sensing units returned and decided to return to selling the original Hall effect type.
We have found these to be the most stable and reliable type and in our opinion the 10 minutes extra fit time is easily offset by the added reliability and stability..
FollowupID: 703493
Reply By: MAVERICK(WA) - Monday, Oct 11, 2010 at 20:04
For what it's worth I removed the points and went electronic after moving down to Perth many years ago - seems it didn't like running around the city. Has not caused any problems and has now been fitted for 10yrs. It also does not get used around the city or suburbs anymore as I have a small car to do that so maybe they might not be so good if you are doing stop-start running over small distances. $500 seems an awful lot of money though - I think you can do a lot better than that. rgds
AnswerID: 432738
Reply By: Member - peter f (VIC) - Monday, Oct 11, 2010 at 21:29
I put Pirana ignition on the old GQ many yrs ago , stopped the bloody back firing on gas , put a system on the you don,t have to modify the dissy , ie Pirana .
cos if it fails you can go back, to the standard ign .
mechpete
AnswerID: 432745
