forerunner front diff
Submitted: Wednesday, Oct 29, 2003 at 19:21
ThreadID: 8185 Views:2116 Replies:3 FollowUps:0
Hi all ,My son has a 87 2.2 forerunner with a stuffed front diff and axle boots can we remove the complete diff assy to be serviced leaving the front drive shaft in place (securely fastend of course ) so he can still drive to work while the rebuild is being done .Thanks
Reply By: Tony - Thursday, Oct 30, 2003 at 11:59
You can take the diff ass. out and still drive the vehicle why not take the drive shaft out as well. You will need to put a cover on the banjo to keep oit dirt and dust.
Of cause you will have to remove both axles.
AnswerID: 35694
Reply By: Member - DOZER- Thursday, Oct 30, 2003 at 16:56
Gday this is on outerlimits 4wd site
4.875 ratio from petrol lux, independant front diff $175 contact
Garath
43551036
Central Coast
N.S.W
Good luck and if you think you have saved enough money, put $50 towards becoming a member of this excellent site.
Andrew
wheredayathinkwer mike?
AnswerID: 35724
Reply By: Member - Oskar(Bris) - Thursday, Oct 30, 2003 at 18:03
Mudguard
I presume you are talking about an IFS front end and you want to know if you can just wire the right and left drive shafts up to the chassis and make sure the FW hubs are disengaged???
If this is the csae then you would need to make sure that the shafts are free to move with the steering as the CV joints allow for this in a complete assembly.
I have towed a IRS VW with the gearbox removed and just made sure the shafts couldn't drop.
I guess it's possible ...... but..... you'd have to be careful and only as an emergency type of thing.
Good luck
Oskar
The real oskar
AnswerID: 35727
