poly air bags
Submitted: Tuesday, Oct 12, 2010 at 21:23
ThreadID: 81865 Views:4644 Replies:3 FollowUps:5
My cruiser has been raised at the rear about 40-50mm and has poly air bags. trouble is it dosnt fit in my carport. if I go back to standard hight springs will my air bags still fit . Will they be to big for the lower springs. the bags are red does this tell what brand they are.
Reply By: Wilko - Tuesday, Oct 12, 2010 at 22:03
Hi Dave,
Are you airbags adjustable for height, Can you let them down a bit to get into the carport.
Cheers Wilko
AnswerID: 432836
Follow Up By: Member - david m2 (SA) - Wednesday, Oct 13, 2010 at 08:24
They are fully deflated to about 5lb . I wish it was that simple.
FollowupID: 703611
Reply By: Member - Wayne B (NSW) - Tuesday, Oct 12, 2010 at 22:27
The air bags come in different lengths to cater for high lift springs.
Chances are if you use a 2" longer air bag in a standard height spring it could pinch the side of the bag. The air bags are not to provide additional lift they are to support additional load and maintain a given ride height. when the vehicle is loaded.
Wayne B
AnswerID: 432838
Follow Up By: Hairs & Fysh - Wednesday, Oct 13, 2010 at 06:49
Hi David,
The red bags are Polyair. I've only just recently put a set in my old girl.
They work a treat.
What Wayne said is right, Bags are ordered to suit the lift.
A standard height bag for a standard height vehicle and a bag ordered for a 2" lift is longer in the side wall to suit.
They are an Assist devise, not a product to give suspension lift.
Depending on what your carport is constructed of, is it possible to have it lifted a couple of inches or a bit more. I did this to a friends a couple of years ago. He had a carport that was only 2.1 M high, bought himself a caravan that wouldn't fit under. We raised it 300mm by extending the 70mm metal posts, one Saturday, a few welds and bracing, 250 bucks later in materials and he could put is van under it. He couldn't lower the van, but 250 bucks is a lot cheaper than new suspension.
Just a thought David, I don't know what your carport is constructed of so this price could be a bit more.
Good luck with,
Cheers.
FollowupID: 703607
Follow Up By: Member - david m2 (SA) - Wednesday, Oct 13, 2010 at 08:30
I am in the process of lifting the roller door but can only get 40mm . I may fit by about 2mm but i would like a little more clearance just in case. New tyres, door not open enough . I don't want to change springs if I don't have to.
FollowupID: 703612
Follow Up By: Rangiephil - Wednesday, Oct 13, 2010 at 10:07
On Range Rovers , the same Polyair is used for a standard height and 2 inch lift.
For a 2 inch lift a 2 inch spacer is placed under the bag.
Have alook under the cruiser and see if there is a big block of rubber under the airbag. If there is , just take it out when lower springs are fitted.
Regards Philip A
FollowupID: 703619
Follow Up By: Member - michael (BOXHD) r (VI - Wednesday, Oct 13, 2010 at 19:41
hi i have just put on the black poly air bags as i had a 2 ; lift as well i had same prob getting in my shed as well i have a arb rooftop tent on mine as well so mine wood not fit as well i had to put new longer tracks on my rooler door so i could rise it up enuff and just made it by 15mm so u may have to see if u can lift your door up a bit more
cheers mick
FollowupID: 703668
Reply By: Mikee5 (Logan QLD) - Wednesday, Oct 13, 2010 at 11:33
Hi David,
The polyairs do come in different lengths for the 100 series depending on the springs. I would assume your vehicle would have the longer ones if they were fitted at the same time (or after) the springs were done. As said above they will crease and crack if fitted into shorter springs. Other suggestions could be lower your rear tyre pressures a bit, lower the polyairs to 2 or 3 psi, get a second set of wheels and tyres for around town in a smaller overall diameter and only fit the good ones when going away, put something heavy in the back like a bag of cement or - fit a small electric winch under the body to pull down the rear of the body like the rock hoppers!!!
AnswerID: 432871
