Emptying second water tank on Jayco Flamingo ST
Submitted: Wednesday, Oct 13, 2010 at 00:04
Flamingo
Hi, I was hoping someone might help with a little problem I have emptying the second
water tank on my Flamingo ST. There is a problem accessing the rear
tank drain plug, it butts up right onto a metal box and can't be removed. Whereas the front
tank plug is fully exposed. I know the two tanks are joined, but this is only in supplying the shower, basin etc, not for draining. Has anyone got any ideas. Any help would be appreciated.
Cheers.
Reply By: Member - Alastair D (NSW) - Wednesday, Oct 13, 2010 at 07:39
If the join is low down on the problem
tank can you tilt the van so the majority of the
water flows to the one you can drain? Otherwise it might be worth getting out the hole saw and putting in a second drain point.
If you have 2 tanks it would be better to have them separate so if you get a leak you do not lose everything.
432857
Follow Up By: Member - Johny boy (NSW) - Wednesday, Oct 13, 2010 at 08:37
Hi all, just a thought but if you can access the
tank at all try a small tube and a pump ?
703613
