solar power
Submitted: Thursday, Oct 14, 2010 at 15:35
outrbacker32
Does anyone know where I can get a bp solar regulator repaired would appreciate as heading off on trip. Panel is on offroad van.
Reply By: Battery Value Pty Ltd - Thursday, Oct 14, 2010 at 16:05
what's broken, what's it (not) doing?
Do you have documentation, or at least the type/name of it?
How far away from
Brisbane are you?
cheers, Peter
433011
Follow Up By: outrbacker32 - Saturday, Oct 16, 2010 at 17:37
Its a BP solar GCR1200 that I had in my van, Ive taken it out and changed it with one I have in my shed which had a panel on the roof. It shows low voltage/no SOC/no charging current/no load current but shows the correct battery voltage. When I took it out it had a rattle inside, when I opened it I found 1 of three 75329p had a cracked piece off. I would like to find where I could have it repaired
704129
Follow Up By: Battery Value Pty Ltd - Saturday, Oct 16, 2010 at 18:19
These are low Rdson power mosfets.
We have similar ones in stock.
If you live near Brissy I can do a quick repair attempt.
Did the unit overheat or how did the mosfet crack?
cheers, Peter
704135
Follow Up By: outrbacker32 - Saturday, Oct 16, 2010 at 18:38
I should have mentioned I live in central victoria. I lent the van to my brother inlaw and he told me of the fault ( he takes off a nut with a hammer and chisel so Im not surprised) Syd
704136
Follow Up By: Battery Value Pty Ltd - Saturday, Oct 16, 2010 at 19:29
Syd,
if you can see my profile, there's a link to our web page and on this there's a contact form, in case you want to mail the regulator to us.
cheers, Peter
704147
Reply By: Mandrake's Solar Power- Friday, Oct 15, 2010 at 11:28
You might want to consider an MPPT controller and boost your output a bit ?
Steve
433104
