Friday, Oct 15, 2010 at 16:51
Obviously you have a battery in your van and this is charged via Anderson Plug whille you are travelling.
How do you charge this van battery when on 240?
My old Freedom had a battery in van and if I needed to charge it , I used a Ctek 7000 which had been modified.
The modification was a cut in wiring above the two clips and rejoined by 2 Anderson Plugs so that clips could be used in the normal way.
However, the modification was such that if the Anderson plugs were separated the top one could be plugged into the van Anderson plug and this would charge the battery.
I also have a Prado with a second battery (120amp AGM) in back and this is charged while I travel via wiring connected to alternator and to the Power In via Anderson Plug.
It looks like this
When I pulled into a caravan
park I would pull out alternator wired Anderson plug (from Power In) connect the Ctek to 240 in back of Prado and charge battery via the top Anderson plug to the Power In on battery box.
While travelling my 2 Waeco's ran off AGM battery via modified Waeco leads .
When on 240 the smaller Waeco(CF18) continued to run off battery whilst the CF 50 ran off 240 until disconnected when it would swith over to using the AGM battery.
The 2 Waeco's look like this
The battery in back is secured by ratchet strap
This might give you some ideas.
Pedro
703944
