advice on fuel consumption please
Submitted: Saturday, Oct 16, 2010 at 10:21
ThreadID: 81937 Views:2739 Replies:5 FollowUps:0
Have sold my 2002 manual 3litre patrol it weighed 3000kg with many accessories and used to return 8 klm/litre,purchased 2007 auto 3litre patrol swapped accessories so same weight BUT it returns 6 klm/litre,changed filters ,no smoke visible but exhaust is VERY black,anyone have any advice on what consumption is normal or what to look for ???
Reply By: Member - Bucky - Saturday, Oct 16, 2010 at 12:29
pepper2
Check out your driving habbits.
That kind of economy is a bit heavy, and it sounds like you have unburnt fuel in your exhaust. You may also have an overfueling problem.
Get your boost checked, 17 - 18 psi max, but you should be made aware that the 3.0lt models have a reputation of boosting up to 30 psi, and that is dangerous.
Just get it tuned on a Dyno, by a reputable firm, an there are plenty about.
Get your injectors changed, and you should get about 9km/lt
Do not do this and your economy will stay the same.
But do not believe what I tell you, become a member of the the Patrol Forum
Patrol Forum
There are a million articles on the topic you want to know
Bucky
AnswerID: 433254
Reply By: Member - mazcan - Saturday, Oct 16, 2010 at 13:18
hi pepper
have noted that you have gone from a manual to an - auto--
this could have a bearing on the increase in consumption
as you can resist changes in the manual where the auto's can have a habbit of hunting up and down where you would just leave the manual to cruise on over hills etc without a change down
but like said the patrol forum is your best bet
AnswerID: 433262
Reply By: Patrol22 - Saturday, Oct 16, 2010 at 13:49
I don't think you are compaing apples with apples pepper2 - I believe that these are two different engines. While both are basically built on the 3 ltr block that is about where the similarities end. If my recollection is right (and I could be very wrong here) the 2002 engine is direction injection whereas you newer 2007 donk is common rail. Also you are running an auto transmission vice a manual and this will always result in higher consumption. I have read on the Patrol4x4 forum that some folks are not at all too happy with the fuel consumption of their crdi patrols.
Re the black exhaust - ignore that if you are not making smoke then this is normal. I think the colours we use to try and achieve in the past with tuning our EH holdens etc are no longer valid in these days of injection systems and complex emission control systems.
AnswerID: 433263
Reply By: pepper2 - Saturday, Oct 16, 2010 at 19:03
thankyou for the replies so far,i have fitted a scangauge and drive it as carefully as possible to conserve fuel,will get it dyno tuned may try the mob at berrima about 40 mins from here.
AnswerID: 433287
Reply By: Madfisher - Sunday, Oct 17, 2010 at 20:25
Peppar we own a man and a auto Jack and the diff in economy is about 2k per litre, so could just be the auto.
Cheers Pete
AnswerID: 433391
