Nuvi 3780T - How do I get it to read map sets off the mini-SD card?
Submitted: Sunday, Oct 17, 2010 at 10:51
Bonz (Vic)
Hi All,
I have a new Nuvi 3780T, and cant seem to get it to recognise map sets on the SD card. I have a Garmin GPSMAP 60CSx and used a mapset on miniSD when I was on Europe and US this year and it recognised them and worked a treat. Now when I copy the map set to the Nuvi it wont read them? I reckon I have the mapset filename correct, cause it worked on the 60CSx.
How do I get that to work, or for that matter, Shonkymaps? Can I load that on the Sd card and get it to recognise them?
Thanx for the help?
Reply By: Member - Stephen L (Clare SA) - Sunday, Oct 17, 2010 at 11:20
Hi Bonz
I have not had a play with the new 3780T but if it is like all the other Nuvi's this should sort you out.
Power up your unit and when you come to the very first page before you select anything, touch the following and it will get you going:
Tools
Settings
Map
Map info
Deselect the City Nav Aust and NZ
Select your new Map file
Back until you reach your main page. When you go to your Naviagtion page you will now be using your newly added maps.
Try this and you will be up and running in around a minute.
433338
Follow Up By: Bonz (Vic) - Sunday, Oct 17, 2010 at 11:26
Hi Stephen, I tried that and the other map sets arent shown in the select screen, so does it just search then for a mapset and find them?
704195
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Oct 17, 2010 at 11:30
Bonz
I should have stated that you can only use the Garmin CD once for a copy and it will only work on the first Garmin GPS unit that you put it in. If on the other hand it was purchased as the Micro SD Card, then it will work on any Garmin GPS and not locked to the first unit that it is inserted into. You do exactly the same for shonky and it will work also.
704197
Follow Up By: Bonz (Vic) - Sunday, Oct 17, 2010 at 12:10
Are there restrictions with the size of the MiniSD card? The 60CSx only likes up to 2 gig and I have a 8 gig in the Nuvi, I want to put the US and UK maps on the one card
704207
Follow Up By: Bonz (Vic) - Sunday, Oct 17, 2010 at 12:29
Well I tried that and it doesnt allow me to select the new map file ...
704212
Follow Up By: Member - MUZBRY(Vic) - Sunday, Oct 17, 2010 at 12:33
Gday
Is this for the map reading comp at
the Pyrenees?
Murray
704214
Follow Up By: Member - Stephen L (Clare SA) - Sunday, Oct 17, 2010 at 12:34
Hi Bonz
I am not sure re the maximum size that can be loaded but somehow I think from memory it is only 2gb???
Lets hope that Doug T or The Explorer will come to your help.
Sorry that this is all I can offer.
704215
Follow Up By: Bonz (Vic) - Sunday, Oct 17, 2010 at 12:39
Thanx Stephen. This year Muz I think there will be a insert and go competition, just waiting to confirm the prize!
704218
Follow Up By: Member - MUZBRY(Vic) - Sunday, Oct 17, 2010 at 12:42
Gday
Insert what and go where ?
Murray
704219
Follow Up By: Bonz (Vic) - Sunday, Oct 17, 2010 at 12:48
Well I am thinking of a "choose your GPS coord and track there" type of competition
704222
Reply By: Member - Doug T (NT) - Sunday, Oct 17, 2010 at 14:32
If you installed the map correctly then like this, (should be same as the 765)
1...Tools
2...Settings
3...Map
4...Map Info
5...Untick CN and tick the map you want to use.
Another way would be to follow the instructions in the Owner manual
433356
Follow Up By: Member - Doug T (NT) - Sunday, Oct 17, 2010 at 14:36
Forgot to add,....if you don't untick the CN installed map it will always over ride any added maps you install.
704253
Follow Up By: Bonz (Vic) - Sunday, Oct 17, 2010 at 17:44
How do I install it correctly Doug? It works on the 60CSx
704279
Follow Up By: Member - Doug T (NT) - Sunday, Oct 17, 2010 at 17:59
What brand/type maps are they.
704281
Follow Up By: Bonz (Vic) - Thursday, Oct 21, 2010 at 18:08
Hi Doug they are Garmin City Navigator Europe maps, they work fine in the 60CSx but not in the Nuvi
704767
