Tow ball weight of tandem axle caravan
Submitted: Monday, Oct 18, 2010 at 12:59
Member - Pat (VIC)
Hi all.
I need to clarify that the tow ball weight on a tandem axle caravan is still a minimum 10% of the weight of the caravan when fully loaded.
Or should it be less as it is a tandem axle.
I have looked at the H/R site but it only shows single axle.
Reply By: OREJAP - Monday, Oct 18, 2010 at 13:10
As far as I am aware the 10% rule regarding t/ball weight is a rule of thumb only. I would think the only way to measure it would be a weigh bridge or a visit to local caravan seller feller & ask them to use their weight gauge on it. At the weigh bridge have
wheels off the bridge & either lower jockey wheel or put a lump of wood or similar under coupling.
433452
Reply By: MrBitchi (QLD) - Monday, Oct 18, 2010 at 13:34
I don't think it makes any difference how many axles you have. You still need weight on the towbar. Another thread on here suggests that anywhere between 5 and 10% should be fine. If you go too light it will be unstable.
433456
Reply By: ob - Monday, Oct 18, 2010 at 15:50
Hi Pat
AFAIK the 10% rule is regardless of number of axles.
I tow a 22' tandem which weighs in at around 2500kg loaded and always aim for about 200kg minimum and 250kg maximum download on drawbar. Tows
well and doesn't wander around in side wind or when passed by or passing roadtrains.
ob
433466
Follow Up By: Gazal Champion - Tuesday, Oct 19, 2010 at 09:23
I agree OB. The heavier the van the less effect from the wind etc.
My van is 2.2 tonne and the weight percentages you quote on the drawer bar are spot on in my opinion. Makes for a stable tow.
Cheers, Bruce.
704446
Reply By: Gazal Champion - Tuesday, Oct 19, 2010 at 09:31
Hi Pat,
I would be aiming for between 8 and 11 percent of the van weight on the draw bar. The 5 percent quoted would be too light in difficult conditions.
At that weight you can use the leveling/stabilizer bars very effectively to stabilize the tow as
Cheers, Bruce.
433534
Reply By: jdbb - Tuesday, Oct 19, 2010 at 18:21
Fully loaded our van weighs 3.2t and tbw is 250kg. We've done two trips in the last year with a total of 16000km travelled and haven't had any problems towing on roads ranging from the Hume Highway to the
Oodnadatta track.
We have a 100 series landcruiser, use a 350kg Hayman Reece wdh, and drive at about 90kph on bitumen and up to 75kph on the dirt.
regards
433579
