Information please
Submitted: Monday, Oct 18, 2010 at 19:24
Kiwi Ray
Hi Folks
Thanks for the help with the Toyota
forum address.
I now need to find the site that gave you the info on tweeking the injector pump on an 80# LC
also how to stop the centre diff lock up when low range is selected
Some kind person on here gave me the address about 3 years ago and I seem to have misplaced it
Thanks in advance
Ray
Reply By: Member - Tony V (NSW) - Monday, Oct 18, 2010 at 20:26
LCOOL technical section has all the details on disconnecting the centre diff lock in low, do a search for the injector pump
LCOOL technical section (click here)
433487
Reply By: pop2jocem - Monday, Oct 18, 2010 at 23:06
Try
Site Link
433510
Follow Up By: pop2jocem - Monday, Oct 18, 2010 at 23:08
Well that worked
well
NOT
Sorry
704414
Reply By: Gazal Champion - Tuesday, Oct 19, 2010 at 09:15
Hi Ray,
The article referred to the pump on a 1HD FT motor. If your motor is the 24 valve turbo then it covers your model. There are some differences on these models to the previous ones, such as high pressure injectors etc.
If your pump has not been done up by around 270 000 Ks you might be
well advised to have it seen to.
Mine had worn out in the casing and virtually had to be replaced. There was not much that was serviceable from the old one.
A Toyota mechanic at the local dealership, who had nothing to do with the work I had done on the pump, said I was lucky that it had lasted to 270,000 Ks.
Reason I suggest this is it may not give you the required results if it is worn out.
Cheers, Bruce.
433530
Reply By: Kiwi Ray - Tuesday, Oct 19, 2010 at 22:04
thanks for all the help fellow 4 wheelers
Ray
433611
