Mounting an Anderson plug on a GU Patrol
Submitted: Monday, Oct 18, 2010 at 19:28
Bonz (Vic)
Hi All,
I am about to mount an Anderson plug on the back of a GU to connect to an aux battery in the trailer and was wondering where people have mounted theirs. The trailer plug is mounted to the rear surface of the tow bar and I was thinking of using the same area but that would mean mounting it
well right of centre and then turning may pull the plug out. So where have others mounted theirs? A pic would be great, and if you cant display them here maybe email them to me please. My email addy is behind my rig pic.
Thanx for your help.
Bonz
Reply By: trilogy - Monday, Oct 18, 2010 at 21:48
Not sure about Patrols but the anderson plug holders let you mout them just about anywhere.
ARB has the too.
http://www.sidewinder.com.au/page16.html#Anchor1
433500
Follow Up By: Lex M (Brisbane) - Tuesday, Oct 19, 2010 at 21:32
I put one of those covers on. Mounted on top of a plate on the towbar. The door doesn't seal when closed, there's an opening where the spring is, so the plug still filled up with dirt.
I wasn't using the door to hold the plug in, but the door broke off anyway in the first 1000km of dirt.
Not worth the money IMHO
704539
Reply By: Paul75 - Monday, Oct 18, 2010 at 21:57
G'day Bonz,
I've mounted one under the aluminium step on my patrol. Screwed and glued. Hopefully the picture shows the location.
Paul.
433503
Follow Up By: Mad Cowz (VIC) - Monday, Oct 18, 2010 at 22:24
hey Bonz,
Mine is in a similar spot although on the opposite side and closer to the tow bar.
Hopefully we will see you at the pair of knees
MC
704409
Follow Up By: Bonz (Vic) - Thursday, Oct 21, 2010 at 18:11
Thanx Guys, yes youll see me ar Pair O Knees, and hopefully I will have this plug mounted or installed
704769
Follow Up By: Member - MUZBRY(Vic) - Friday, Oct 22, 2010 at 05:40
Gday Bonz
Do it on site for a Pair o Knees project . Just think of all the help you could get.
Murray
704834
Follow Up By: Bonz (Vic) - Friday, Oct 22, 2010 at 17:39
Competition sorted - Fit Anderson Plug to Bonz's car!
704911
Follow Up By: Mad Cowz (VIC) - Friday, Oct 22, 2010 at 19:14
That'd be way too cool, a GU with 18 anderson plugs!!!
704922
Reply By: Rod W - Monday, Oct 18, 2010 at 23:11
Why don't you say install instead of mounting as mounting has other conenations and you could hurt yourself.
433511
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Oct 19, 2010 at 19:45
Rod, Why dont you write "connotations" instead conenations.. :)) Michael
704522
Follow Up By: Rod W - Tuesday, Oct 19, 2010 at 22:13
I would have but the spell checker didn't identify the correct word.
704544
Reply By: Member - Bucky - Tuesday, Oct 19, 2010 at 09:07
Bonz
Hope this foto helps
Just piggy backed onto the main trailer plug
Image Could Not Be Found
Cheers Mate
Bucky
433528
Reply By: Member - MUZBRY(Vic) - Tuesday, Oct 19, 2010 at 16:06
GDAY bonz
They should be mounted above
water level , so you should mount it on the roof.
Murray
433566
Follow Up By: Who was that again? (Vic) - Thursday, Oct 21, 2010 at 20:48
Murray, he has been known to get bogged before. You never know how deep he can get himself in mate.
704787
