another 12v waeco problem....
Submitted: Tuesday, Oct 19, 2010 at 20:16
chucky d
ok so I've read a lot of waeco probs on here looking for the same as
mine but couldn't find it.
so hope fully someone can help......
I have a 60l waeco, about 2 months old, it runs
well on 240v but when I run it on 12v it does one of two things, it either flashes 3 times every 5 seconds which I read is a motor start error ??? or it runs for about 5 seconds and turns off for 5 seconds and turns the digital screen off every time the compressor stops... on 5 off 5 on 5 off 5 and so on.
I tried it on emergency override and it seems to run solid.
AAHHHGG !!!! what the hell is going on??
I'm running 240 electrical lighting wire I think it's 1.5mm straight from battery to a cig lighter in the rare of the dual cab.
Reply By: TTTSA - Tuesday, Oct 19, 2010 at 20:19
Quite possibly the wire size is too small, I get confused on wire sizes, but definately the bigger the better for sive of wire. Someone else will point you in the right direction re wire sizes.
433593
Follow Up By: dbish - Tuesday, Oct 19, 2010 at 20:46
Hi Chucky, Definitly to light wiring. Quote from my Waeco owners manual 12V 4Meter run use 7MM square copper cable. Daryl
704528
Reply By: AlbyNSW - Tuesday, Oct 19, 2010 at 20:24
Sounds like undersized wireing to me too, try plugging in to a direct 12v source using the plug supplied and see how it goes
433596
Reply By: GT Cruiser 80 series - Tuesday, Oct 19, 2010 at 20:28
Hi Chucky d,
Im not an expert but Id say the wiring is definetly to small. You need to be running 6mm auto cable as minimum. I run a 110 ltr Waeco when away on the back my 80 series cruiser using 6mm auto direct to the second battery. I've never had a problem.
GT
433597
Reply By: Kevin Jackson - Tuesday, Oct 19, 2010 at 20:29
i had the same problem, simple answer for me is to cut the cig plug off and put an anderson plug in it's place. doesn.t matter about the wire as much it is more about the contact in the join i found.
433598
Follow Up By: Dennis Ellery - Tuesday, Oct 19, 2010 at 22:44
What a strange thing to say
704549
Follow Up By: Kevin Jackson - Wednesday, Oct 20, 2010 at 21:57
It may be strange to some but, you can have the largest dia wire that carry 1000amp but if you can't get the power to the fridge then it is worth a pinch of sh*t. Which is what those cigerette plug are worth.
This being my trouble and hours spent trying to figuring this out, rewiring with bigger wiring, hours of testing and hot beer and off steak when getting somewhere and it was as easy as a $7.50 anderson plug and was all done.
Just a note, when you have a look at the wire in the lead to the fridge it is not very large anyway.
Kev
704679
Reply By: Member - Wayne D (NSW) - Tuesday, Oct 19, 2010 at 21:09
thread 81984 raised similar problem. I would say wiring too. If the wiring is too light could cause overheating and in worst case electrical fire.
433607
Reply By: Crackles - Tuesday, Oct 19, 2010 at 21:12
You have 3 issues. 1.5mm Cu is far too small to run a 12 Volt fridge & building wire should never be installed in a car as it is far too ridgid & will snap from vibration over time. Run red/black 6mm multi strand auto wire direct from battery to fridge keeping as short as possible to avoid voltage drop. Replacing cig lighter type connectors with quality Anderson or Clipsal plugs will improve reliability.
Cheers Craig...............
433608
Follow Up By: Joe n Mel - Tuesday, Oct 19, 2010 at 21:33
please put a fuse in at the battery end or carry a BIG fire extingisher ...
704540
Follow Up By: Member - Serendipity(WA) - Tuesday, Oct 19, 2010 at 22:47
Crackles has hit the answer spot on so I second what he says.
Also I agree with Joe n Mel about adding a fuse. The last thing you want is a burning car in the outback.
David
704550
Follow Up By: Hairy (WA) - Wednesday, Oct 20, 2010 at 10:01
Yep...... I third that. (both comments)
704581
Reply By: The roadrunner - Tuesday, Oct 19, 2010 at 21:37
Gday you should at least be runnig at least 6mm wire or go into any BCF and gets a raps kit it includes everything to run a waeco fridge
433610
Reply By: Dennis Ellery - Tuesday, Oct 19, 2010 at 22:28
Waeco’s faults are more often than not due to bush electricians’ not understanding volt drop calculations and subsequently under sizing their cabling. Try and keep your volt drop to under 5% and you won’t have a problem. If you can’t do the calcs – reply with the current draw of your fridge and the length of cable and I will do the numbers.
433615
Reply By: SDG - Tuesday, Oct 19, 2010 at 23:11
Running to thin a wire will cause voltage drop as had been mentioned above. The reason this causes the Waeco to malfunction/error/turn off etc, is if there is a drop in voltage by the time it reaches the fridge, the fridge thinks that your battery is getting low, therefore shutting off before you have a flat battery. Just doing what it was programmed to do.
433617
Reply By: ozzie4x4 - Wednesday, Oct 20, 2010 at 14:07
Im hereing this running to thin a cable to your fridge all the time. I run 4 mm cable at a 50 amp rating to my fridge, I have done so now for about 10 years, , running from a 80 litre weaco to now a 60 litre weaco, I have a circuit breaker up near the battery and got rid of the cig lighter plug ( they loose a lot of amps) .
upto today still no problems (touch wood)
433663
Reply By: bks - Wednesday, Oct 20, 2010 at 21:38
Without doubt its due to the wiring being too thin compounded by the cigarette lighter socket. I played around with this problem and the best solution is to buy the wiring kit from Waeco. It has the right size wire plus correct fuse and most iimportantly the correct connector a merit plug.
433714
Reply By: PradOz - Wednesday, Oct 20, 2010 at 22:15
Chucky d
just buy and fit yourself a Waeco Raps kit. Cost about $120. Google it or better still search EO here for it and you will see how it works as I have put links up for them plenty of times before. If you need to contact someone to buy 1 let me know and I will forward an EO Member details who supplies these and othe RV/4WD gear. Short of that just look at any
camping, 4WD access
shop or buy over the net. Very very simple to fit and you have everything you need in the kit, cheers....
433717
Reply By: Member - Lyndon C (TAS) - Wednesday, Oct 20, 2010 at 23:55
G'day Chucky, bought a 60lt waeco fridge/freezer last year myself. Went over to W.A. and the same thing happened to
mine. Had a hell of a time trying to sort out the prob. Stayed with the cable that came with the unit. Had to push the 12v plug into the Waeco until it was a tight fit. Found out the unit will not run correctly if your battery is down on voltage. Error messages and flashing starts for a number of reasons. Found most of these. Firstly back to the battery, run a multimeter on your battery and check voltage. If it is down below 11.5v, then disconnect the fridge and charge up your battery until back up to 13.7/13.8volts. Plug your fridge back in with the standard plug and hit the reset button and hold down for 5 seconds and release. The unit should be working okay now. Another thing that will cause the problem you are having is the unit does not like being operated on a lean and MUST HAVE adequate ventilation around the corner Air Vents, otherwise this problem will persist over and over. Do what I did Chucky, read the instructions that accompanied the unit 3 or 4 times over again. You will pick up bits you missed before and all of a sudden there will be the answer to your problems if what I have already told you doesn't work. Another thing, keep the fridge/freezer full at all times, even if you have to put plastic bottles of
water in the unit as it helps maintain an even temperature and the fridge doesn't have to work as hard over a long period of time once it is cool/cold. Hope this helps mate. Cheers, Lyndon.
433730
Reply By: chucky d - Thursday, Oct 21, 2010 at 08:51
Thanks to all your replies, very grateful.
seems like everyone says the same thing... so makes me think i should change the the wire to 6mm and change over to anderson plugs.
thanks guys.
433744
Follow Up By: Member - Bill B1 (NSW) - Friday, Oct 22, 2010 at 23:15
Hi chucky,
Another problem with the wiring issue is that the staandard horizontal 6 pin Britek plug is rated for 10 amps only. Everybody uses them, usually to connect the caravan or trailer to the car.
My Prado was wired with Red-arc bits but the fridge wire for the caravan, was only 1.5 mm. The current draw through the wire and the plug, melted the plastic around the socket and the socket pulled out reducing what little current was flowing through the system.
I disconnected the 6 pin wire and re-wired the fridge current through an Anderson plug. The fridge is working better and the Red-arc has stopped complaining.
Worth thinking about.
Bill
704950
