buying on spec
Submitted: Sunday, Oct 24, 2010 at 02:36
ThreadID: 82098 Views:3304 Replies:3 FollowUps:1
Gday
I am about to buy a 6.5 L Chev Nissan on spec. I know most people are ok with doing this and they do it with no re-percussions.
but i guess i am a bit old fashioned...i was wondering if anyone out there can describe to me how the 6.5 L Chev engine feels? How does it pull off the mark, is it sluggish, quick, lots of noise with no movement, etc etc. The engine in this particular vehicle is an NA diesel.
i mean even better if someone had a short clip they could send me. Preferably not in youtube format.
yes strange request i know...but....
anyway, thanks for any and all inputs, or short movie clips.
Reply By: On Patrol & TONI - Sunday, Oct 24, 2010 at 09:36
a well recognised conversion that gives more power & torque than the original motor, great for towing, a bit thirsty sometimes, and SOME have temperature control problems.
I looked at this conversion before putting the 1 HT FTE Toyota engine in my GU.
Check my blog on this subject.
Project TONI
AnswerID: 434040
Reply By: Roach"ee" - Sunday, Oct 24, 2010 at 09:39
John, I have a 6.5 Chev/Patrol in NA form too. Mine pulls very well from idle, but it is a slow and low revving engine, so I often joke that I can easily beat a B-double in a traffic light drag!!! However, I am a bit older too (at 55), so my days of flogging an engine are well and truly long gone.
I try to drive mine like I drive a large truck....slow and deliberate clutch action, steady pressure on the LOUD pedal etc. You need to keep in mind that these engines are literally "agricultural" by design.....they were meant for tractors and trucks.
On the other hand I have a mate who also has a similar rig (except his is still a GU wagon, whereas mine is a dual cab) and he tends to drive his a bit harder...accelerates harder etc.
One factor that will have an effect is what diff ratios are in it? Mine is fitted with 3.9:1 diffs.
They are a great engine, but do have their "issues". Here is a link to a great deal of information: 6.5 Chev Diesel info
AnswerID: 434041
Reply By: Robin Miller - Sunday, Oct 24, 2010 at 10:11
Hi John
I'd have to say I could see no valid reason for such a choice but we all have different priorites I guess.
I have seen some V8 petrol coversions (on gas) though and the thing that gets me is the NHV that usually comes with them.
You would need to be comfortable with that side of things as this vibration can get very annoying, and you sort of wonder about clutch life.
What I have observed with the normal 4.2 is a body resonance developed by the engine vibration at around 100-110kmh and its quite annoying in the standard diesel - much less in 3lt and non-existant in the 4800 petrols.
AnswerID: 434042
Follow Up By: Member - DOZER- Sunday, Oct 24, 2010 at 12:09
I have never owned a 6.5, but i have drove a 6.5 turbo in an 80 series. It was comparable in acceleration to the factory turbo diesel in the 80 (what i owned) but where the factory t/d ran out of acceleration at 100 km/hr, the 6.5 turbo kept going.
Another way i have heard it explained is a trip with a heavy load takes 6 hours with a std motor and 4 with the 6.5.
Now, as far as longevity goes, they dont seem to be too good, the latest 6.5's were ok, but earlier ones had issues with everything from pumps, oil leaks, heads cracking, overheating, not enough oil in the sump.....i would beware if i were you.
Andrew
FollowupID: 705073
