Toyota split rims- are rings interchangeable?
Submitted: Tuesday, Oct 26, 2010 at 13:39
Oznuggets
Hi All,
I am up for some new rubber on my 97 troopy ( 6 stud splits ). I have to clean the rims up first as I've been getting problems with loose rust scale piercing the tubes (rust works loose on rough corrugations and is more of a problem than dirt entering IMHO). I will have access to some late model split rims (5 stud) and I'm wondering if anyone know if the rings on these rims are the same as the older 6 stud? I haven't had a look at the new rims yet but thought I would ask here first. Would be good if they are the same as my old rings have seen better days.
Regards,
Reply By: get outmore - Tuesday, Oct 26, 2010 at 17:04
dont know but try them
its not rocket science, if they fit in nice and snug then the answers yes, if lips etc are mismatchedand you get gaps then no
434272
Reply By: Going Bush - Tuesday, Oct 26, 2010 at 17:43
they fit but i would not use them, the 6 stud ring has a good inch flange under the rubber and the 100 series ring has only about 1/2" flange , no worries using hilux ifs silver rings on the
grey 6 studs rims tho
434275
Follow Up By: Oznuggets - Tuesday, Oct 26, 2010 at 18:54
OK good to know, thanks.
705350
Reply By: Member - Scott M (NSW) - Tuesday, Oct 26, 2010 at 19:36
there are differences - both Dad (80 series GL) and I (HJ47) both use split rims with same stud pattern, however they're not interchangeable .... subtle differences in stud length and rim profile .... in an emergency you could interchange, but my local mechanic (who knows his stuff) reckons you shouldn't run them permanently
434284
Follow Up By: get outmore - Tuesday, Oct 26, 2010 at 22:52
just the splitte rings hes talking of
705402
