What difference do after market shockers make?
Submitted: Tuesday, Oct 26, 2010 at 20:49
Member - Jeff P (SA)
Inspired by Allan's honest question re lifts I will ask
mine. I understand why lifting a vehicle is a good thing, and why fitting heavier duty springs will help with loads, but I want to know what difference putting upgraded shockers in will make, especially on corrugations.
My previous 4wd was back in the '70s, a SWB FJ40 with leaf springs fore and aft and very few if anyone stuffed around with the
suspension then, so if I put in different shocks, what difference will I find. I know that in theory they should last longer and not over heat as quickly but will they smooth out corrugations etc thus improving the ride compared to standard? and is there any advantage in adjustable ones?
Reply By: Madfisher - Tuesday, Oct 26, 2010 at 22:09
Jeff if you had put monroe magums or a similar shocks on your fj40 you would have noticed a huge diff in bump steer and gereral driveability. They where much easier to improve then modern day vehicles. heavier shocks will help control hd springs as
well. But if you go to firm you will end up with a harder ride.
Cheers Pete
434312
Follow Up By: AlbyNSW - Tuesday, Oct 26, 2010 at 22:23
I found that changing shocks only to Bilsteins in a brand new Hilux improved the ride and handling characteristics dramatically over the standard setup.
705398
Reply By: Crackles - Tuesday, Oct 26, 2010 at 22:38
Standard springs & shocks are supplied by the manufacturer at a cost effective price to suit the average person who buy's their vehicles. After market shocks are available in various configerations to suit particular needs which may be to match the higher spring rates of heavy duty load carrying suspensions, valving for firmer improved handling or large
bore & remote resivoirs for increased oil capacity to keep the shock cool in competition or severe offroad use. They are also often longer to increase wheel travel to keep the tyres on the ground.
In short after market shocks can improve the ride, handling, braking & longivety & yes even your 40 series would have beneifted from a shock upgrade, it's just back then after market assesories simply were not available nor were they that good a quality either.
As for corrugations a good quality shock will smooth them out to some degree but more importantly not fade or fail as quickly.
Cheers Craig.................
434313
Reply By: equinox - Tuesday, Oct 26, 2010 at 23:46
I upgraded my perfectly good standard
suspension for an after market version; New springs and shockies all round.
The biggest reason for doing this was to gain better articulation in the rear as it gave a big creaking noise whenever I was to cross a dry
creek diagonally.
This problem was solved immediately with the upgrade. The shockies provided great absorption on corrugations. I was very happy for about a year until the front ones failed and I was forced into a quick downgrade warranty job in
Port Hedland.
As for heat - this picture is one of my second after market set of shockies, taken 1 day after it was installed new, just after all those corrugation north of Kunawaritji.
Image Could Not Be Found
Go for the shockies, as they do a good job, but choose wisely.
434316
Follow Up By: Member - Duncan W (WA) - Wednesday, Oct 27, 2010 at 00:20
Alan out of interest what brand of shocky was the one that melted?
705413
Follow Up By: equinox - Wednesday, Oct 27, 2010 at 00:24
mmm, one model down from those yellow ones with the extra canister...
705414
Follow Up By: Kimba10 - Wednesday, Oct 27, 2010 at 16:55
OME ??? They run a yellow shock with plastic shrouds ??
705450
Reply By: Rangiephil - Wednesday, Oct 27, 2010 at 09:30
IMHO aftermarket shocks provide such a good ride on 200 series cruisers that the driver drives much faster over corrugations, overheats the shocks causing failure and then is stuck for a week waiting for replacements.
I spoke to three couples at
Drysdale River Station who were stuck for a week or so after bursting either one or two front aftermarket shocks.
IRONY eh.
Yet the standard shock equipped renter Cruisers seemed to hurtle along oblivious to the heat and not visibly fail.
It seems to be the Japanese makers who put poorly riding shocks on their vehicles. Europeans such as Range Rover/ Mercedes/VW use Boge, or Bilstien which are pretty optimum for ride, although you may prefer a stronger damper on rough roads with a heavy load. Just remember that this translates to a rough ride unladen .
In my experience ( and the experience of Rover specialists) only Bilstien will survive long periods of corrugations and bounce back, and are rebuildable. I have tried TJM ( too stiff), ARB (ditto on RRC ), Boge (best comfort, but died after a lot of corrugations. I had Koni on a Patrol once and they were good.
Forget all the "boutique " brands as they are most often cheap shocks only branded by some small Australian company to give them a USP. Many are made by COFAP in Brazil including TJM. The suppliers may have changed ove rthe yeas but the principle doesn't.
I got the last Comfort valved Bilstiens in Australia for my RRC and they have now done 40KK, with over 10K of corrugations GRR etc. Three are good but one has a leaking top seal. I plan to have them tested
and if necessary rebuilt before the next big trip. Try to get "comfort" valved Bilstiens as Sport usually give a poor ride and can skip on corrugations.
Regards Philip A
434337
Follow Up By: Mr Pointyhead - Wednesday, Oct 27, 2010 at 12:02
I used these boutique shocks:
http://www.foxracingshox.com/offroad
I found they give a more comfortable on road ride than Bilstiens without comprimising handling or offroad performance. Similar to your coment about Bilstiens, you need to ensure you get them with the correct valving for comfort.
705427
Follow Up By: Gronk - Wednesday, Oct 27, 2010 at 19:38
I have Fox shocks in my CT ( A KK ) and their rersearch claims that these ( on outback tests ) had no heat builup problems as compared to other brands !!!
Whether this is 100% true is debatable, but goes to show what a quality shock is ( or may be ) compared to a "normal" shock is ???
705465
Reply By: Robin Miller - Wednesday, Oct 27, 2010 at 09:57
In that other post I was explaining some disadvantages of lifting a car, but with shocks it goes the other way.
Most peoples lift is with heavier springs and this throws out the spring/shocks balance and you have to get better and bigger shocks because the force required to dampen a heavier spring increases. This then in turn puts a bigger kick into the spring/shocks mounts and on and on you go (this is why some breaks these).
In the case of a standard Patrol the shocks are undersized but work
well till overheat so you have to get bigger shocks for this reason as
well as to match any change in spring high so shocks don't bottom/top out.
By having (easily) adjustable shocks you can wind them back on bad roads so that heat build up in them is less.
Others like me remove swaybars increasing articulation and this requires that not only do you need shocks for length but you must also get shocks with some protection against this top out because the shocks then hold the weight of axle at max articulation.
All in all better shocks are a good idea.
434338
Reply By: Steve63 - Wednesday, Oct 27, 2010 at 13:30
Hi Jeff,
As with most commercial products you need to take the marketing garbage out of the equation. If with the usage you normally have with your vehicle there is a definite advantage to make a change (either ride height or
suspension changes) then go ahead. Just remember everything is normally a compromise. Increased ride hight = higher centre of gravity and increased roll over risk. Changing
suspension elements alters the ride, articulation and handling of the vehicle. Something that improves one thing can have an adverse effect on another. I have a 79 series Toyota ute with very few mods. It does what I want with ease. Why would I change it? The other point is that it is often difficult to source non standard parts in remote
places. But chances are they have a replacement standard shock etc.
If you go to ARB or TJM they will tell you you need $10,000 worth of changes and extras to drive down a dirt road. They are there to sell stuff to you. Only you can decide if it is really warranted in your specific case.
Steve
434348
Follow Up By: Member - Phil G (SA) - Wednesday, Oct 27, 2010 at 20:30
Yep, I'm with you Steve. Lots of flash marketing and Hype out there.
I've seen plenty of standard Toyota (Japanese made Tokico brand) shocks go
well over the 200,000km mark and I've seen big name aftermarket shocks (often from Brazil or USA) fail on the first trip.
I run aftermarket shocks at the moment - main reason is that I want the longer travel that you can't get from the factory shocks.
And replacement Toyota shocks are usually cheaper than aftermarket.
705470
Follow Up By: Steve63 - Thursday, Oct 28, 2010 at 08:58
I know what you mean about the price. I was highly surprised. On our first trip I bought most spares you would likely need. This was from a dealer and they gave me a goood price. I've been surprised a few times. I think a new wing mirror with bracket was $55. On the other end of the scale are the sealed beam headlights at $300! The original shocks are still on the vehicle at 110,000km so I'm not complaining.
Steve
705493
Reply By: petesgq - Monday, Nov 01, 2010 at 13:33
Tried a few, and one has always stood out for simple robust build with rebuild ability.
Koni Heavy trak 88 series
These have done 35 thousand plus K's of corrugations with out fail. prior to this had a
well known yellow brand around the same price which lasted 600klms rear two total failed and front 2 where leaking badly.
Avoid the hype and stick with the proven performers.
434758
