power draw problem
Submitted: Tuesday, Oct 26, 2010 at 22:42
ThreadID: 82150 Views:2631 Replies:5 FollowUps:1
Hi all, my mate has a hj60 an is having trouble with power drawing and has flattened a new battery in half an hour of leaving it parked. he has pulled the starter motor out to clean put it back in and it has started to do this. he has pulled the starter out again but has found nothing wrong. Can this be an earthing problem?? Or has anyone had this sort of problem before? Any help would be greatly appreciated thanks Ray.
Reply By: Member - Stuart P (WA) - Wednesday, Oct 27, 2010 at 00:55
what else has he fitted to the vehicle,?
AnswerID: 434320
Reply By: Member - Bucky - Wednesday, Oct 27, 2010 at 04:54
Ray
Certainly sounds like the Starter is staying on, Spinning up but not engaging.
Once in an old truck I found same problem.
Next time after you start with a fully charged battery, remove the lugged lead to the starter solenoid, and insulate it, and let it hang.
GO do your thing, come back 1 hr later and test battery with a milti meter.
Should be a good indicator there is a problem with starter, or solenoid.
Bucky
AnswerID: 434325
Follow Up By: Member - Bucky - Wednesday, Oct 27, 2010 at 04:56
The Lugged lead will be power from your key, easily spotted and located
FollowupID: 705416
Reply By: greenant - Wednesday, Oct 27, 2010 at 17:11
Hi Ray
To me it sounds like the diodes are shot in the alternator and they are shorting to earth and draining the battery. Easy to check disconnect the alternator and wait or put an ammeter in series with the charge wire to the battery and check what is happening. Let us know what you find
Greenant
AnswerID: 434368
Reply By: Robin Miller - Wednesday, Oct 27, 2010 at 19:04
If he has flattened a new battery in half an hour then this means a large current of 20 amps + must be being drawn all the time.
This is equivalent to a starter soleniod being always on.
Such a current will cause sparking when the +ve lead is taken off battery.
Just remove leads in turn and watch for sparking to stop.
i.e. it should spark when batt lead comes off/on -check - put lead back on then move to starter soleniod or anything else in the loop taking each off/on checking for spark.
AnswerID: 434377
Reply By: StormyKnight - Thursday, Oct 28, 2010 at 20:21
Other than whats already mentioned, the only other thing i can think of is the glow plug relay is shorted closed.....
AnswerID: 434451
