Colorado 3LTD ideling rough
Submitted: Tuesday, Oct 26, 2010 at 23:01
ThreadID: 82151 Views:9156 Replies:5 FollowUps:1
My 08 3ltd Colorado has this intermittent problem it idles rough shaking the gear stick really bad and when I go to drive off it sounds like a old tractor it doesn't do it all the time, have taken it to the Holden dealer and they can't find anything wrong, anyone got any ideas?
Reply By: Member - Bucky - Wednesday, Oct 27, 2010 at 04:34
Cozzie
1) Have you recently serviced the Rodeo, if so bo back over the fuel filter and lines, and check for loose fittings.
......I do all my servicing, and once got a dodgy fuel filter, which caused a similar problem.
2) Your injectors may bleeding
3) You may have got some dirty fuel.
4) Change garages/service centres. A propper diesel machanical workshop may be the go.
5) try increasing your idle 200 revs
As you can gather I am not a mechanic, but for what it's worth, this is where I would look.
Cheres
Bucky
AnswerID: 434324
Reply By: Member - Tour Boy ( Bundy QLD) - Wednesday, Oct 27, 2010 at 09:02
The egr may have blocked up the inlet manifold. These are the first symptoms. Common on tritons, pajeros, hiluxes and most common rail motors with 80,000+km.
HERE is a forum page with pics from the pajero site to give you an idea.
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 434334
Reply By: D200Dug- Wednesday, Oct 27, 2010 at 11:30
Forget the Holden dealers and find a good mechanic :-)
AnswerID: 434342
Reply By: TerraFirma - Wednesday, Oct 27, 2010 at 13:15
Injectors..! Cross your fingers you haven't done a Commonm Rail Injector, otherwise write us a story about the repair bill..!
AnswerID: 434347
Reply By: Member - Cozzie Toodyay (WA) - Wednesday, Oct 27, 2010 at 19:39
It's back at the Holden dealers they reckon the problem is injectors, hope injectors are covered by warranty will find out tomorrow.....thanks for the replies much appreciated.
AnswerID: 434379
Follow Up By: westozal - Wednesday, Oct 27, 2010 at 21:32
I drive a Isuzu Dmax which is basically the same as your Colorado. I would suggest taking your vehicle to a Isuzu dealer where they deal with diesels all day long and Isuzu's to boot.
JEM trucks in Bunbury are very good.(Isuzu dealers)
Regards Alan
FollowupID: 705476
