Aftermarket shocks lift
Submitted: Wednesday, Oct 27, 2010 at 22:39
ThreadID: 82163 Views:2504 Replies:4 FollowUps:2
Lift? Can longer aftermarket shocks lift my Toyota hilux surf? If so, how does it work and how much will it cost?
Reply By: Wayne (NSW) - Wednesday, Oct 27, 2010 at 22:45
Lee,
Shocks will keep the tyres on the ground, springs will keep the vehicle off the ground.
Shocks alone will not raise your vehicle.
Wayne
AnswerID: 434392
Reply By: Member - Mark G Gulmarrad - Wednesday, Oct 27, 2010 at 22:46
Lee
no.
only a lift kit will give you the lift you are after,and then you will, require longer shocks to suit.
AnswerID: 434393
Reply By: 3GoBush - Thursday, Oct 28, 2010 at 01:02
No but these can
AnswerID: 434395
Follow Up By: Hairs & Fysh - Thursday, Oct 28, 2010 at 06:34
If you can sneak it through REGO.
FollowupID: 705489
Reply By: Mick O - Thursday, Oct 28, 2010 at 07:32
Lee, did you check out these recent threads.
Why Lift?
Aftermarket shocks
Also check out the EO article on suspension.
Suspension
Cheers Mick
AnswerID: 434400
Follow Up By: Member - Lee E (WA) - Thursday, Oct 28, 2010 at 11:28
Cheers for your responses. My mates had me a little confused. I researched lifting my vehicle a little and then one mate told me that just by installing longer shocks I could get the desired result. The reason why I want a lift is to limit the amount of wear to the underside of my vehicle up and around the dunes.
FollowupID: 705497
