Hilux offroad with standard tyres?
Submitted: Thursday, Oct 28, 2010 at 11:04
willy1818
Im new here.
I am about to get a Hilux from work and will have private use of it and was wondering what the standard tyres are like offroad?
I am looking to do the Plenty hwy in June next year.
I am sure that my employer will only allow the tyres to be replaced with the same that are on it new and only when worn out.
So will the standard one do alright on the Plenty?
I understand i will need spares this is no problem, i can get 2 but don't want to use them unless needed as they will be borrowed and i would have to replace them.
Michael
Reply By: Member - Tour Boy ( Bundy QLD) - Thursday, Oct 28, 2010 at 11:16
As long as you are not overloaded, running high pressures or are driving too fast they will be ok if more than 60% tread.
434414
Follow Up By: willy1818 - Thursday, Oct 28, 2010 at 11:57
Thanks for the info.
Michael
705501
Follow Up By: Fab72 - Thursday, Oct 28, 2010 at 12:50
Tour Boy,
I'm in a similar situation as you, but with a diesel Holden Captiva. We just finished a 7000km 3 week trip that took us up the
Birdsville Track and into the
Simpson Desert.
Although the tyres weren't brilliant in the
sand dunes of the Simpson, with the correct tyre pressures and appropriate speeds, they should do fine.
I hate the thought of spending money on a work car, however thought it appropriate to buy a puncture repair kit, a spare tube and a GOOD air compressor. The first two items will save costly tyre replacements until you can get back to town and
shop around for a tyre, and the second will give you the ability to maintain and alter your tyre pressures to best suit the track conditions without having to compromise.
BTW....we had zero tyre problems and ran our donuts at 28psi, down from a factory standard 36psi when on the dirt. 22 in the sand, although there wasn't much bagging our happening with the lower profile rubber bands.
Fab.
705507
Follow Up By: Fab72 - Thursday, Oct 28, 2010 at 12:51
Woops...sorry, reply was meant for willy.
705508
Reply By: TerraFirma - Thursday, Oct 28, 2010 at 14:50
You could always buy a 2nd hand set of Sunraysia
wheels or something like that with some offroad tyres, and swap the rims when you go offroad etc, just a thought if it becomes an issue, would be worth it if you were borderline in the conditions.
434428
Reply By: Member - Paul S (VIC) - Thursday, Oct 28, 2010 at 17:37
G'day willy,
Good advise on pressures above, but be aware that highway tyres are made for highways and may not necessarily have the grip or staking resistance that offroad tyres offer.
Your boss may not be too pleased about having to replace tyres staked by sharp sticks & rocks etc.
If the hilux is new & yet to be collected, see if he will allow you to change over to A/T's. The dealers will usually arrange this for you and all you have to do is pay the difference.
If you don't mind a little more highway cruising tyre hum and a firmer ride, choose an A/T of light truck construction; you won,t regret it once you get into the rough.
I'll leave the choice of tyre brand advice to others; you'll not be short of opinions in that area.
Paul
434439
Follow Up By: AlbyNSW - Thursday, Oct 28, 2010 at 20:39
I agree with your advise, if you are planning on doing a bit of offroad driving it is better to have a stronger , more durable tyre. It could still be of a type that should not cause you grief with Company car policy.
Do a trade up whist they are still new, it would be worth the little bit extra that you have to pay out of your own pocket for peace of mind in the outback.
705547
Reply By: mikehzz - Friday, Oct 29, 2010 at 06:53
I did the Plenty with street tyres. I lowered the pressure and took it easy on the speed. It's a long way at lowish speed that's for sure. The temptation to go faster is pretty overwhelming after a while especially when you hit a graded stretch. Mike
434493
