Spot Satellite Messenger
Does anyone know anything about the Spot Satellite Messenger - pros and cons would be appreciated.
Reply By: Member - Graham H (QLD) - Sunday, Oct 31, 2010 at 12:29
There are several on here that have posted threads about them so doubtless a "Search " On "Spot messenger" will tell you most of what you want to know.
Also they have a www address.
AnswerID: 434679
Reply By: TerraFirma - Sunday, Oct 31, 2010 at 12:32
The pros I think are obvious in terms of its safety & locating potential. It has other features over a personal EPIRB such as allowing you to contact people asking for assistance without sending a life threatening signal etc. Early reviews stated the GPS was a little weak in comparison to other handheld devices. Not sure if this has been rectified but if you were injured and in an area of poor coverage, dense trees, canyon, crevice etc you may not get a signal out.? Off course this could apply to an Epirb as well however I don't have any current information on the strength of the GPS receiver today. Some of the tracking functions may be considered expensive?? In summary however it offers a lot if you are in area without mobile phone coverage because it bridges the gap between a conventional EPIRB and mobile phone. Arguably cheap security if it does everything successfully for you.
AnswerID: 434680
Reply By: Dennis Ellery - Sunday, Oct 31, 2010 at 14:04
I use one extensively to inform my family of our location – now on our second lap around Australia.
It has a function to tell you when its message has been successfully sent - I also have my computer set up to receive the message. It hasn’t failed yet and I wouldn’t travel without it.
Regards Dennis
AnswerID: 434689
Reply By: Member - Graham H (QLD) - Sunday, Oct 31, 2010 at 14:34
As I understand it the device uses Globalstar for communication.
This is rated as the worst sat system ever. Almost no one uses it for phones so how much better it is for Spot I would wonder.
AnswerID: 434693
Follow Up By: Wayne (NSW) - Sunday, Oct 31, 2010 at 14:47
Graham,
Regardless of what system it uses it does work and work well.
I have been using SPOT for a couple of years now and my wife knows exactly where I am all the time that I am away. (If I remember to turn it on).
Wayne
FollowupID: 705777
Follow Up By: Ayita5 - Sunday, Oct 31, 2010 at 15:01
Graham,
I thought this too when looking into a SPOT, however, from reading some info from other members on here (can't remember who or where, sorry) the problem with Globalstar and phones is that the communication needs to work both ways and there is a problem with this. Because the SPOT communication only needs to go out, it uses the network without an issue. - So I've heard from others - open to being corrected.
FollowupID: 705780
Follow Up By: Member - Graham H (QLD) - Sunday, Oct 31, 2010 at 15:05
Thats fine but the original Poster asked for good and bad.
Good it works for you. Bad it is on Globalstar.
It has been said that one way communication wiith Globalstar is OK but phones are not (obviously).
There have been numerous posts on here about people ditching this satellite phone system and going to Iridium and even getting refunds so it cant be all that good.
I havent got a Spot but my Iridium phone worked everytime I wanted it to no matter where I was.
FollowupID: 705781
Follow Up By: The Landy - Sunday, Oct 31, 2010 at 17:35
Spot worked perfectly on our trip North in July. Used Spot tracking and it logged the route without problem.
I also sent an 'arrived' message each day that was received by the SMS recipient within minutes of being sent each time.......
The Spot website is claiming a 99.4% reliability rate based on 6 million messages per month......
i'd have no hesitation recommending to anyone who wants a reliable tracking and safety device.
Cheers, The Landy
FollowupID: 705796
Follow Up By: Member - John R (cQld) - Sunday, Oct 31, 2010 at 18:58
Here's a quote from a Wikipedia site re the technical issues why the phone service is crap but SPOT is OK:
"According to documents filed with the SEC on January 30, 2007, Globalstar's previously identified problems with its S-band amplifiers used on its satellites for two-way communications are occurring at a rate faster than expected, possibly eventually leading to reduced levels of two-way voice and duplex data service in 2008. The company's simplex data services used to support the asset tracking products as well as the SPOT Satellite Messenger are not affected by the S-band satellite issue mentioned above." (Love their use of the word "possibly" above!! - LOL)
Further details re the L-band receivers used by SPOT can be found here for anyone interested.
Cheers, John
FollowupID: 705802
Follow Up By: Member - Morry H (WA) - Sunday, Oct 31, 2010 at 21:11
Graham H (QLD)
if you dont own one i fail to see how you can judge it , ours has worked for 3 years now and all ok would not be without it regards morry
FollowupID: 705807
Follow Up By: Member - Graham H (QLD) - Sunday, Oct 31, 2010 at 21:30
I wasnt knocking Spot if you read my post correctly.
I was questioning the reliability of Globalstar.
As previously posted a reason has been given why it doesnt work with phones but does with one way communication.
If you are happy thats fine. I was merely replying to the original post who asked for good or bad.
Spot apparently is fine phones are not, make you happy I hope so.
FollowupID: 705811
Follow Up By: Member - Ian F (WA) - Sunday, Oct 31, 2010 at 22:04
G'day,
Just out of interest can you cancel your annual membership fee or are you permanently locked in if it isn't required?
Ian
FollowupID: 705817
Follow Up By: Bonz (Vic) - Monday, Nov 01, 2010 at 16:18
You mean your spot membership Ian? I was wondering that myself
FollowupID: 705871
Reply By: OzTroopie - Sunday, Oct 31, 2010 at 16:07
SPOT is a good system, but just remember you're required to pay an annual subscription to keep the service active. The basic service is $US115 per year. Unlimited Check-in/OK, Help, and Custom Message emails are included. It also includes to 200 annual Check-in/OK, Help, or Custom Message text messages to any mobile phone, worldwide. Your credit card is charged an additional $US0.10 for each additional text message.
To allow people to track your progress online. You're required to pay an additional $US49.99. When activated, SPOT Track Progress automatically sends your GPS location waypoint to a Google Map every 10 minutes.
So while you might only pay $229 for the SPOT, your up for at least $US115 per year to use it, plus another $US49.99 for people to track your progress via Google Maps
SPOT is a private service, which has an agreement with the Australian Maritime Safety Authority, however remember that when a SPOT is activated in an emergency, the signal is first sent to the US, before a phone call is made to the Australian authorities. With an Australian registered PLB or EPIRB, the signal is sent through to Australia's Rescue Coordination Centre straight away, no middle man.
Good features are the ability to "check in" and request non-life threatening help from family and friends. Though this may have limited use, for example, you can't ask for a specific spare part to be brought to you. All that your friends/family will know if that you need non-life threatening help. If you program in a custom message before you go, it may not be the custom message you need to send out in the field.
The other option is a Personal Locator Beacon (PLB), similar to an EPIRB, but designed mainly for use on land. A GPS enabled PLB retails for approx $AU589. Drawback is you can't use it to ask for for non-life threatening help. You pay your $589 and your unit is good for 10 years before requiring a service and battery swap.
Probably a good unit to invest in if you're going to use it regularly, or doing a long trip such as the big lap. Good also to let people know you're ok if stuck or delayed by rain, etc. You can't do this with an EPIRB or PLB.
Probably worth considering also a PLB, in conjunction with UHF radio, HF/ Sat Phone (you can hire photh of these).
AnswerID: 434705
Follow Up By: Dennis Ellery - Sunday, Oct 31, 2010 at 17:42
You don’t need the spot tracking facility at $US49.99.
Just send your OK message manually and your GPS coordinates and Google map link still gets sent out.
For me this the preferable option as I send my OK message to about 10 email contacts once a day when on the move.
FollowupID: 705799
Reply By: Member - Mary W NW VIC - Sunday, Oct 31, 2010 at 17:53
I purchased one recently and did a trip up to the Cooper ferry.As i was travelling for a lot of the journey solo it was good for those at home to be able to track.
Apart from the OK message have one saying "RACV to this location" and another "delayed but OK.".
I'm happy with it -does what's reqd quickly .
I just have a question for the experts.
Can I download my track to Google earth?Whick one of the download formats should I use?
Thanks,
MARY
"Some people walk in the rain,others just get wet."
AnswerID: 434711
Reply By: Zebra400 - Monday, Nov 01, 2010 at 06:23
Hi Bob
We have been using SPOT for a couple of years now. Initially we were concerned with SPOT being linked to Globalstar, but all of our trips have shown us that the down side of Globalstar is not related to SPOT.
Late last year, SPOT released a new model (commonly known as SPOT2). So I call my units SPOT1 & SPOT2 (SPOT1 being the first model).
Although SPOT1 has longer battery life (we got 12 months out of the 2 AA litium batteries), it suffered from sending a weaker signal, so the hit rate was lower than the new model (SPOT2).
SPOT2 runs on 3 AAA lithium batteries and only gives approx 2 months battery life. Of course, these times will be different if you run you unit more often. Our unit is usually on for about 6 - 8 hours per day while we are travelling. The battery life will be shorter if you run the unit 24 hours a day in tracking mode.
I decided to test SPOT's ability to send positions in tracking mode, so I ran both units (SPOT1 & SPOT2) side by side on a 4WD trip we did earlier this year. Both units performed well while travelling along the highway with open view to the sky. It was when we went offroad with mountainous & tree covered tracks that SPOT2 showed its value.
The total trip was 1,200kms and based on a tracking position every 10 minutes, the SPOT1 unit had a 60% hit rate (130 recorded positions), while SPOT2 had an 80% hit rate (170 recorded positions).
You can view both of these trips if you want to see the comparisons, by clicking on the following links.
SPOT1
SPOT2
AnswerID: 434737
Reply By: Going Bush - Monday, Nov 01, 2010 at 11:55
I would not go anywhere without SPOT messenger. Dont take any notice of the Globestar bunkum.
I have had ours since mid 2008 and it has operated flawlessley. It keeps getting better & better too with the number of Apps you can hook it up to like the EO Maps.
We are just home from our 2010 3 month trip and it was all logged using SPOT, if you are clever you can even geotag your photos with it.
You can see a real example of its capability here on my
GPS Tracking page
Also an example of how geotagged images can work at the bottom of the blog page on same site
Also the makers claim the Spot V1 has a battery life of 2weeks, we only changed our batteries once during the 3 months & they were still going strong.
The SOS / 911 feature works too as I know the Vic Alpine area Station Sgt that was called to a GPS coordinate on the High plains to find a Trailbike rider with a broken leg !
AnswerID: 434753
Follow Up By: Going Bush - Monday, Nov 01, 2010 at 12:00
the above Tracking Page url wont work . (typo?)
try this www.goingbush.net and select the gps tracking button on the menu bar
FollowupID: 705850
Follow Up By: Member - Andrew (QLD) - Monday, Nov 01, 2010 at 12:06
Type http:// in front of your links for it to work GB ;)
Thanks for the link and the information,
Andrew
FollowupID: 705852
Follow Up By: Member - Mary W NW VIC - Monday, Nov 01, 2010 at 14:11
Thanks for the info
Would like to know more about available applications I can use with Spot 2 and where might I find this info.Love to be able to do the photo bit too.
Mary
FollowupID: 705857
Reply By: TerraFirma - Monday, Nov 01, 2010 at 12:19
In summary after reading this thread the Spot system sounds like good value when you consider Epirbs costing around $500-600. The added functionality and customer testimonials here make it a winner imo. No doubting if you really want a complete system you would supplement this with a satellite phone. Money well spent when safety is paramount.
AnswerID: 434754
Reply By: PeteS - Monday, Nov 01, 2010 at 16:33
Howdy Bob
I have used Spot for 3 years now and would not be without it as one of the options we have if all goes wrong while we travel.
The only thing I warn anyone about is that Spot is owned by a private company and could go bust at anytime (I doubt it would happen but it has to be considered).
PeteS
AnswerID: 434777
Reply By: Member - Yogibob - Thursday, Nov 04, 2010 at 12:06
Thanks so much everyone.... so much to consider... but I now have a much better base from which to make an informed decision.
AnswerID: 435051
Reply By: Member Dick (Int) - Thursday, Nov 04, 2010 at 14:48
I own two of the original SPOT units. One stays in the vehicle (SPOT1) and one (SPOT2) is carried if I leave the vehicle. They sometimes do not report on time, but they are certainly reliable enough to let my Son know where I am. They work well in the desert where there is seldom anything to block the view of the sky. In mountain country you will certainly have some gaps in the reporting.
I have a series of messages worked out with my Son in Newcastle in case we lose all communication from the vehicle. If I am stationary the position of the two SPOT's tell him what sort of a problem I have and if I need help and the degree of urgency. These signals are used when the problem might be serious but not life threatening enough to use the emergency button or turn on the EPIRB.
I would not leave home without them.
Dick
Dick
AnswerID: 435059
